Hello everyone,
Glad to know about this forum.
I've been converting PPT slides into captivate3 and recording
the narration. At first, we recorded about 20 minutes of
conversation for 15 slides. The sound file was easy to manipulate
(remove hums and bits of speech ;-)), the captivate 3 file was over
120'000 KB but no crash, t'was fine. Excellent sound quality but
the image quality was not so good and the text a bit deformed.
Following advice on this forum, I recorded onscreen the PPT show.
result = Very good image quality.
Then, we decided to introduce 1-2 bullet points of text at a
time. From what I could figure out, each bullet point had to become
a slide in captivate in order to be able to modify its timeline.
Then, also thanks to you all, found Audio>Edit
timing>projects. Took the sound file of hte whole presentation
and have been adding the slide marks. I've had to redo and redo
this several times, and it is not over yet, because, despite the
fact I try to save every 2-3 slides, all the sudden, instead of
it's being slide 15 at 9 minutes of track, it is slide 4 at 9
minutes and all other slide markers previously added disappear. So,
here I am back to the slide 4 "mark" although I am at slide
19...and 20 more to go, an 17 earlier ones to redo....
Here are questions:
Has anyone had this problem in setting up the timing?
Is there an optimal length of sound file to work with
captivate 3 (for ex., don' t go over 5-10-15-30 minutes...)
Is there a way to capture bullet point animation on one
slide?
How would you go about with the project?
I thought of recording in PPT and then link audio in
Captivate, but the sound quality really is v. good in captivate 3.
my temp solution was to save each time and if the above error
occured, to close the file without saving and return to the last
save. Even that doesn't work!!!!
Many thanks!!
