Locked
SCUP Installation of 11.2
Guest
May 18, 2012 May 18, 2012
I am using SCUP to update a v10 deployment to v11.2.  The installation appears to work, with the updates agent showing installed status for all four updates which get applied to an x64 system:
Adobe Flash Player 32-bit ActiveX 11.2.202.235
Adobe Flash Player 64-bit ActiveX 11.2.202.235
Adobe Flash Player 64-bit Plugin 11.2.202.235
Adobe Flash Player 32-bit Plugin 11.2.202.235
That said the WindowsUpdate.log file shows a failure as follows:
Windows failed to install the following update with error 0x80070643: Adobe Flash Player 32-bit ActiveX 11.2.202.235
Now Flash Player is working in all browsers but the ActiveX Flash Player does not show in Add/Remove Programs.  IE shows that it is using the ActiveX player.
The FlashInstall.log in SysWow64\Macromedia\Flash shows:
2012-5-18+10-39-54.631 [error] 1226 1062
=O====== M/11.2.202.235 2012-05-18+10-39-52.900 ========
0000 00000010 "C:\Windows\TEMP\{8F50881C-1A05-45FE-AF56-D34F4C74F081}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0006 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash10m.ocx 5
0007 00000018
0008 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash10m.ocx 5
0009 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_235.ocx
0010 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.exe
0011 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.dll
0012 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0013 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0014 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0015 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0016 00001106
0017 00001106
0018 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.2.202.235 2012-05-18+10-39-56.709 ========
and
2012-5-18+10-40-6.910 [error] 1226 1062
=O====== M/11.2.202.235 2012-05-18+10-40-05.769 ========
0000 00000010 "C:\Windows\TEMP\{181D6F14-892A-40BB-A39F-10E973E139E7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0002 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0005 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0006 00001036 Software\Opera Software/Last CommandLine 2
0007 00001036 Software\Opera Software/Last CommandLine 2
0008 00001036 Software\Opera Software/Plugin Path 2
0009 00001036 Software\Opera Software/Plugin Path 2
0010 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_2_202_235.dll
0011 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_Plugin.exe
0012 00000017 C:\Windows\SysWOW64\Macromed\Flash
0013 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0014 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0015 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0016 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0017 00001106
0018 00001106
0019 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.2.202.235 2012-05-18+10-40-08.594 ========
So it clearly thinks there is some kind of failure.
I need to be confident of this update before rolling to 000's of machines so any input appreciated...
EDIT - OK I now know this only happens if intenet explorer it loaded at the time the updates are applied.  There is no way to control this when deploying via SCUP so should the installers be able to handle IE being loaded at installation time?
8.2K
Adobe Employee ,
You should only have to run the 64 bit updates as they contain both the 32 and 64 bit components.
There is no install switch that will ignore an opened browser.  However, with the release of 11.2 this issue should only occur for re-installs of the same version.  You should not see this occurring when updating to new versions.
Guest
May 20, 2012 May 20, 2012
That is interesting, SCUP decides that all 4 installers are requiredusing the prerequisites from the adobe catalog. Question is, does it matter? Still functions just doesn't show as an installed program in the control panel.
Guest
May 21, 2012 May 21, 2012
OK back this morning and had a look at the installable rules for the installer.  Basically the x64 installer has a rule which contains the following...
Processor architecture is x64
However the 32 bit version does not have a rule related to architecture.
Therefore on a 64-bit machine it will attempt to install both the 64bit versions and the 32bit version, which is where the problem exists.
The machines currently have 32-bit flash 10, if we install only version 11.2 64-bit am I right in thinking it will remove the 32-bit 10 and leave only the correct 64-bit version installed?
Adobe Employee ,
May 22, 2012 May 22, 2012
Yes, I believe that is a correct assumption.  Sorry if I wasn't clear in my previous post, your observation of the 64 bit installer's prerequisite and functionality are both correct.
Guest
May 23, 2012 May 23, 2012
I have copied and edited the updates with SCUP so that the 32-bit versions will only install on an x86 system.  This has fixed the issue for 64-bit systems, they now only get the two 64-bit updates pushed at them.  All working fine on the 64-bit front.  Getting a number of 32-bit systems where they fail but actually it isn't a SCUP issue, on those machines if I log in and try to install manually it fails removing version 10 with the Error 2753. The file 'FP_AX_MSI_INSTALLER.exe' is not marked for installation.
I am not sure why this happens, could possibly be down to the methods used to install v10 in the first place.  The Adobe flash uninstaller does not fix this, I had to manually remove registry keys to get v11.2 to install.  We don't have too many 32 bit systems left but if it becomes a major problem I will look to deploy a script to remove the keys so the 11.2 install can function.
Adobe Employee ,
Could we get the following info from you?
1. What are the exact registry paths which still exist in the registry after running the uninstaller?
2. The FlashInstall.log from the following locations on a system that exhibits this issue?
C:\Windows\System32\Macromed\Flash\
Chris
Guest
May 29, 2012 May 29, 2012
Hi Chris,
Is there any plans to change the Installable rules for the x86 Flash updates in future versions published through the official catalogue to limit applicability to only 32bit machines. Just so we don’t need add this additional rule manaully before publishing to SCCM. Ideally we want to be able to have all Flash updates in a single SCCM SU  deployment and let the update Installable rules determine correct applicability.
Ben
Adobe Employee ,
May 30, 2012 May 30, 2012
Hi Ben,
Starting with 11.3 (which is in beta right now), we have a universal installer for both 32 and 64 bit systems.  AFAIK, this will carry over to msi's too.
Chris
Oct 16, 2012 Oct 16, 2012
Hi, I'm using SCCM/SCUP to deploy flash to 32-bit Windows 7 and Vista. Now using the universal installer 32/64. Installing fine for the vast majority of computers, but some are still giving the "Error 2753. The file 'FP_AX_MSI_INSTALLER.exe' is not marked for installation. " error message in Event Viewer Application Log. The same problem is persisting and I just cant see why some machines have it. Currently now pushing out 11.4.402.287, and have same issues.
The Sytem Log says: Installation Failure: Windows failed to install the following update with error 0x80070643: Adobe Flash Player 32-bit/64-bit ActiveX 11.4.402.287.
The SCCM log file c:\windows\system32\ccm\logs\WUAHandler.log says: Installation job encountered some failures. Error = 0x80240022
Guest
Oct 17, 2012 Oct 17, 2012
This link may help you...
http://www.gregorystrike.com/2011/08/16/adobe-flash-player-%E2%80%98fp_ax_msi_installer%E2%80%99-ins...
If you edit this script to make it completely silent you can push it out to all your machines where you are getting the error.  Then push out your Flash updates again and you should be okay.  I don't know exactly why the error comes up but I think it must be related to the method used to install flash in the original instance.
