i create a upload test using FileReference & PHP.
In this scenario user upload files to http server.
Now how can i delete all files in /files/uploads folder in AS3
AS3 Code:
req = new URLRequest();
req.url = ( stage.loaderInfo.parameters.f )? stage.loaderInfo.parameters.f : "http://www.website.com/test/upload.php";
uploadFile = new FileReference();
select_btn.addEventListener( MouseEvent.CLICK, browse );
uploadFile.addEventListener( Event.COMPLETE, complete_func );
uploadFile.addEventListener( DataEvent.UPLOAD_COMPLETE_DATA, show_message );
function browse( e:MouseEvent )
filefilters = [new FileFilter('Images',"*.jpg;*.png;*.gif")];
uploadFile.browse( filefilters );
function complete_func( e:Event )
trace( 'complete !' );
function show_message(e:DataEvent)
if (e.data == 'ok')
label_txt.text = 'The file has been uploaded.';
else if ( e.data == 'error')
label_txt.text = 'The file could not be uploaded.';
PHP Code:
<?php
$uploads_dir = './files/uploads';
if( $_FILES['Filedata']['error'] == 0 ){
if( move_uploaded_file( $_FILES['Filedata']['tmp_name'], $uploads_dir.$_FILES['Filedata']['name'] ) ){
echo 'ok';
exit();
echo 'error';
exit();
You need call another PHP file
<?php
directory = './files/uploads';
getDirectoryList ($
directory);
//This function find all the files in the directory
function getDirectoryList ($directory)
// create an array to hold directory list
$results = array();
// create a handler for the directory
$handler = opendir($directory);
// open directory and walk through the filenames
while ($file = readdir($handler)) {
// if file isn't this directory or its parent, add it to the results
if ($file != "." && $file != "..") {
//$results[] = $file;
// Delete Files
$filename =
$file;
unlink($filename); //this delete a file
// tidy up: close the handler
closedir($handler);
how to call this script from flash?
var request:URLRequest = new URLRequest ("deletFiles.php");
var loader:URLLoader = new URLLoader (request);
//loader.addEventListener(Event.COMPLETE, onComplete);
loader.load(request);
i tried this but not working....
my code:
var request:URLRequest = new URLRequest ("http://www.site.com/test/deletfiles.php");
function onComplete(e:Event):void
trace("Complete");
PHP
<?php
$directory = './files/uploads';
getDirectoryList ($directory);
$filename = $file;
closedir($handler);
Change:
<?php
$filename = $file;
closedir($handler);
for this:
<?php
getDirectoryList ($
directory);
$results = array();
$filename =
$file;
unlink($filename);
closedir($handler);
i'm facing same problem. i think problem is in flash loader.
if i enter wrong path flash showing : trace complete.
if Flash trace "complete" this means that the loader is working.
Copy some files to the folder and try testing the PHP script
in a navigator go to:
(where site is your real domain)
