The installation runs to about 6% then I get the "Installation Failed" error.
I've tried everything including cleaning disk permisions but nothing is working.
Below is my Installer Log.
Please help. Seems I can't do without Flash Player afterall.
2012-05-22 15:32:58 +0300 ---------- log start ----------
2012-05-22 15:32:58 +0300 All install checks pass
2012-05-22 15:33:10 +0300 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-05-22 15:33:17 +0300 [install started]
dyld: Symbol not found: _OBJC_CLASS_$_CWInterfaceManager
Referenced from: /System/Library/PrivateFrameworks/Install.framework/Frameworks/OSInstall.framework/Versions/A/OSInstall
Expected in: /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
in /System/Library/PrivateFrameworks/Install.framework/Frameworks/OSInstall.framework/Versions/A/OSInstall
2012-05-22 15:33:18 +0300 [install completed]
2012-05-22 15:33:18 +0300 [install failed]
2012-05-22 15:33:25 +0300 ---------- log end ----------
2012-05-22 15:33:26 +0300 ---------- log start ----------
2012-05-22 15:33:26 +0300 All install checks pass
2012-05-22 15:33:31 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-05-22 15:33:31 +0300 [install started]
2012-05-22 15:33:32 +0300 [install completed]
2012-05-22 15:33:32 +0300 [install failed]
2012-05-22 15:33:50 +0300 ---------- log end ----------
2012-05-22 15:33:52 +0300 ---------- log start ----------
2012-05-22 15:33:52 +0300 All install checks pass
2012-05-22 15:34:05 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-05-22 15:34:05 +0300 [install started]
2012-05-22 15:34:06 +0300 [install completed]
2012-05-22 15:34:06 +0300 [install failed]
2012-05-22 15:37:31 +0300 ---------- log end ----------
2012-05-22 15:40:19 +0300 ---------- log start ----------
2012-05-22 15:40:19 +0300 All install checks pass
2012-05-22 15:40:37 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-05-22 15:40:37 +0300 [install started]
2012-05-22 15:40:38 +0300 [install completed]
2012-05-22 15:40:38 +0300 [install failed]
2012-05-22 15:49:09 +0300 ---------- log end ----------
2012-05-22 15:49:14 +0300 ---------- log start ----------
2012-05-22 15:49:14 +0300 All install checks pass
2012-05-22 15:49:20 +0300 User has 2 processes that need to be closed before the Flash Player can be installed.
2012-05-22 15:49:28 +0300 [install started]
2012-05-22 15:49:29 +0300 [install completed]
2012-05-22 15:49:29 +0300 [install failed]
2012-05-22 16:03:03 +0300 ---------- log end ----------
2012-05-22 16:29:28 +0300 ---------- log start ----------
2012-05-22 16:29:28 +0300 All install checks pass
2012-05-22 16:29:38 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-05-22 16:29:39 +0300 [install started]
2012-05-22 16:30:11 +0300 [install completed]
2012-05-22 16:30:11 +0300 [install failed]
2012-05-22 16:30:16 +0300 ---------- log end ----------
2012-05-22 16:30:26 +0300 ---------- log start ----------
2012-05-22 16:30:26 +0300 All install checks pass
2012-05-22 16:30:33 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-05-22 16:30:33 +0300 [install started]
2012-05-22 16:30:34 +0300 [install completed]
2012-05-22 16:30:34 +0300 [install failed]
2012-05-22 16:37:33 +0300 ---------- log end ----------
2012-05-22 16:51:52 +0300 ---------- log start ----------
2012-05-22 16:51:52 +0300 All install checks pass
2012-05-22 16:52:02 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-05-22 16:52:02 +0300 [install started]
2012-05-22 16:52:03 +0300 [install completed]
2012-05-22 16:52:03 +0300 [install failed]
2012-05-22 16:52:19 +0300 ---------- log end ----------
2012-05-22 17:17:29 +0300 ---------- log start ----------
2012-05-22 17:17:40 +0300 User has 1 process that needs to be closed before the Flash Player can be uninstalled.
2012-05-22 17:17:57 +0300 ---------- log end ----------
2012-05-22 17:23:41 +0300 ---------- log start ----------
2012-05-22 17:23:41 +0300 All install checks pass
2012-05-22 17:23:49 +0300 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-05-22 17:23:49 +0300 [install started]
2012-05-22 17:24:06 +0300 [install completed]
2012-05-22 17:24:06 +0300 [install failed]
2012-05-22 17:39:26 +0300 ---------- log end ----------
2012-05-22 17:41:03 +0300 ---------- log start ----------
2012-05-22 17:41:03 +0300 All install checks pass
2012-05-22 17:41:10 +0300 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-05-22 17:41:16 +0300 [install started]
2012-05-22 17:41:17 +0300 [install completed]
2012-05-22 17:41:17 +0300 [install failed]
2012-05-22 17:41:19 +0300 ---------- log end ----------
2012-05-22 17:50:11 +0300 ---------- log start ----------
2012-05-22 17:50:11 +0300 All install checks pass
2012-05-22 17:50:19 +0300 User has 1 process that needs to be closed before the Flash Player can be installed.
It appears you're missing a required system library (/System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN). This is definitely abnormal.
You could try the following: After mounting the Flash Player dmg, right click the "Install Adobe Flash Player" icon and select "Show Package Contents". From there, go into the Contents/Resources folder and run the file named "Adobe Flash Player.pkg".
You my friend, are a GENIUS!! Worked like a charm.. Thank you very much.
