I have a timestamp field in my db.
In my mysql program I clicked on the box that says "On Updated Current_Timestamp" which works fine for updating rows in the database and adds the time.
Now I want it to add the time for NEW rows, so in the default box I put now(); but I get an sql error. I am doing it in the database to lessen the load on coldfusion but maybe something like this is better in my cfquery insert into sql?:
<cfqueryparam cfsqltype="cf_sql_timestamp" value="#now()#" />
What do you think I should do? Thanks
Thanka for all the input I played around a lot with it and I made it work, this is what I did to the timestamp mysql field:
Field length 0.
Decimals 0
Allow null NO
Checkbox for On Update Current_Timestamp selected
Default value CURRENT_TIMESTAMP
It now works fine adding/updating the date for both a new and an exisiting record automatically
Thanks for all the help about dates
What is the code you are running and what is the error?
Hi Dan
The field UPDATED is a timestamp field, it has length 0 because it doesn't let me change it, decimals 0 and allow null.
The Default value I put in the mysql program for the field is: now();
It has the checkbox for On Update Current_Timestamp selected.
I get this error: 1067 'Invalid default value for value updated'
I did a google search on "mysql now" and found this page. http://dev.mysql.com/doc/refman/5.5/en/date-and-time-functions.html
I noticed one synonym for now is current_timestamp(). I'd try that with a 0 in the brackets.
Hi Dan I tried deleting the field UPDATED and then adding it again, I used the following three options:
1) current_timestamp()
2) current_timestamp(0)
3) current_timestamp(0);
But I get this error in mysql: '1067 Invalid default value for UPDATED'
Since I don't actually use mysql, and nobody else has answered, you might have better luck on a mysql forum.
It it is truly a timestamp field, there should be no need for a default value... no?
Field length 0.
Decimals 0
Allow null NO
