last time sinious help to me.
i using that script with little changes.
if i add "Kbps" in that bandwidthHandler my tests failing.
if i remove 'Kbps' that working good.
function bandwidthHandler(e:AppEvent):void
downSpeeds.text = e.params.bandWidth +"Kbps";
downTest();
function downTest()
if (Number(downSpeeds.text) >= 512)
Pass.visible = true;
Fail.visible = false;
else
Pass.visible = false;
Fail.visible = true;
Your problem is adding a string to a number and trying to compare it as a number...
Try passing the e.params.bandWidth as an argument to the downTest function instead of using the textfield.
downTest(e.params.bandWidth);
function downTest(dnSpeeds:Number)
if (dnSpeeds >= 512)
else
Pass.visible = fal
else
yes
working. Thank you Ned Murphy
and one more same issue pls..
this is already string so ......
upSpeeds.text = String( int(( ( uploadFile.size/tm.currentCount ) / 1024 ) * 8 )) + " Kbps";
function uploadTest()
if (Number(upSpeeds.text) >= 256)
upPass.visible = true;
upFail.visible = false;
else
upPass.visible = false;
upFail.visible = true;
Show you learned something from the other and solve it.
no, no
first i trying after i asking for solution. this is already i tried the as last time but not working.
no, no
this involves solving the same problem so you should learn from the first one and apply it to the second. If you tried, you should show what you tried.
yaa i tried night, finally i got it.
Thanky you for ....
var upSpeeds:int;
upSpeeds= (( ( uploadFile.size/tm.currentCount ) / 1024 ) * 8 );
upSpeeds.text = upSpeeds + " Kbps";
if (Number(upSpeeds) >= 256)
else
