7 Replies Latest reply on May 25, 2012 6:05 AM by Venkom
    problem
    Venkom Level 1
      last time sinious help to me.
      i using that script with little changes.
      if i add "Kbps" in that bandwidthHandler my tests failing.
      if i remove 'Kbps' that working good.
      function bandwidthHandler(e:AppEvent):void
        downSpeeds.text = e.params.bandWidth +"Kbps";
        downTest();
      function downTest()
      if (Number(downSpeeds.text) >= 512)
        Pass.visible = true;
        Fail.visible = false;
      else
        Pass.visible = false;
        Fail.visible = true;
        • 1. Re: problem
          Ned Murphy Adobe Community Professional & MVP
          Your problem is adding a string to a number and trying to compare it as a number...
          Try passing the e.params.bandWidth as an argument to the downTest function instead of using the textfield.
            downTest(e.params.bandWidth);
          function downTest(dnSpeeds:Number)
          if (dnSpeeds >= 512)
          else
          • 2. Re: problem
            Venkom Level 1
            yes
            working. Thank you Ned Murphy
            • 3. Re: problem
              Venkom Level 1
              and one more same issue pls..
              this is already string so ......
              upSpeeds.text = String( int(( ( uploadFile.size/tm.currentCount ) / 1024 ) * 8 )) + " Kbps";
              function uploadTest()
              if (Number(upSpeeds.text) >= 256)
                        upPass.visible = true;
                        upFail.visible = false;
              else
                        upPass.visible = false;
                        upFail.visible = true;
              • 4. Re: problem
                Show you learned something from the other and solve it.
                • 5. Re: problem
                  Venkom Level 1
                  no, no
                  first i trying after i asking for solution. this is already i tried the as last time but not working.
                  • 6. Re: problem
                    no, no
                    this involves solving the same problem so you should learn from the first one and apply it to the second.  If you tried, you should show what you tried.
                    1 person found this helpful
                    • 7. Re: problem
                      Venkom Level 1
                      yaa i tried night, finally i got it.
                      Thanky you for ....
                      var upSpeeds:int;
                      upSpeeds= (( ( uploadFile.size/tm.currentCount ) / 1024 ) * 8 );
                      upSpeeds.text = upSpeeds + " Kbps";
                      if (Number(upSpeeds) >= 256)
                      else
