Life cycle of Java CFX tags
Guide ,
Oct 27, 2006 Oct 27, 2006
http://livedocs.macromedia.com/coldfusion/7/htmldocs/wwhelp/wwhimpl/js/html/wwhelp.htm
A new instance of the Java CFX object is created for each invocation of the Java CFX tag. This means that it is safe to store per-request instance data within the members of your CustomTag object.
If you run the attached, the output is:
num message isOdd
2 InputCounter=2 false
3 InputCounter=3 true
4 InputCounter=4 true
5 InputCounter=5 true
6 InputCounter=6 true
7 InputCounter=7 true
9 InputCounter=9 true
11 InputCounter=11 true
13 InputCounter=13 true
If a new instance is created for each invocation, then the initial value of isOdd should be false. So why does <cfx_test inputCounter="4"> return true and not false? What am I missing?
Advanced techniques
478
Guide , Oct 27, 2006 Oct 27, 2006
Yes, I thought it seemed like a bug. Thanks for the confirm.
Advisor ,
Shouldn't your link be: http://livedocs.macromedia.com/coldfusion/7/htmldocs/00001095.htm ?
Also, notice that that page says that you can use your custom tag to store data during the request.
CF only invokes the tag once per request (barring shenanigans) -- even though you call it multiple times.
That text is telling you that you do not normally have to worry about crosstalk between requests on any temporary data stored in the CFX.
Guide ,
Exactly how are you defining request here? It can't be per http request because the behavior is different if you move the tag outside the cfloop.
Advisor ,
Yeah, you are right.
The object appears to be invoked or not, willy nilly, depending on what kind of flow control structure it is in!
See the attached code.
This is definitely a bug.
Guide ,
Advisor ,
Oct 28, 2006 Oct 28, 2006
Forgot to add:
Using an explicit tag close, IE <cfx_test inputCounter="#num#" />, has no effect.
Guide ,
For kicks I added hashCode() to the cfx tag response. The hashcode is always the same within the cfloop.. but different outside the loop. So the loop is definitely reusing the same object.
Documentation
