Hi everyone,
there is my problem, when I select a particular page in the "table of contents" RoboHelp Crash . I only have a title and a picture. And when a create a new page with the title everything it's fine, but when I try to insert my picture the program crash again My picture format is ".jpg". I try every width to see if the reason was the size of the picture, but nothing change. CRASH! CRASH and CRASH again.. really not friendly. I don't know if somebody can help me, but it will appreciate to have some help...
Try creating a new blank test project in your c:\projects\ folder - then try inserting the image. If that doesn't crash, then you know that it's something to do with your project; if it does crash, then it's probably something to do with the image.
Thanks. but it's crash again. I never had problem with the format jpg before (like web site). So I really not understand what I doing wrong.
Thats a good suggestion, Can you also verify wheer this jpg is located, (Network drive or Local machine), try to move it to your C drive and then import it again to your page.try to use this .Jpg in MS paint or any application and observe, like jeff said, Image might be a culprit, tryy other images on same porject too, just to be very sure.
Anjaneai
Really thanks, I don't know why but now it's working.
