12 Replies Latest reply on May 25, 2012 6:15 AM by goodychurro1
    Set a date two days in the future
    goodychurro1 Newcomer
      Hi all
      This code works fine to set a value if there is no value in form.MEETING (so I can insert the value into my db with sql):
      <cfset isMEETINGNull = iif(len(trim(form.MEETING)) EQ 0, true, false)>
      How can I set the value to a date two days from now if it is empty(instead of null as it is at the moment, seomthing like this?)
      <cfset isMEETINGNull = DateFormat(DateAdd("d", +2, Now()), "MM/DD/YYYY")>
      Thank you!
      Message was edited due to google research possible answer
        • 1. Re: Set a date two days in the future
          Dan Bracuk Rockstar
          if (len(trim(form.meeting)) > 0
          theDate = dateAdd("d", 2, now();
          else
          theDate = something.
          But it's not that simple.  You might also have to ensure that form.meeting actually is a date and if so, that it meets whatever other criteria you have.  Finally, don't use dateformat in this situation.  It's a display function that returns a string.  You want to send a date object to your db.
          • 2. Re: Set a date two days in the future
            BKBK Rockstar
            Here is yet another suggestion. It includes validation.
            <cfset meetingDate = trim(form.meeting)>
            <cfif not isDate(meetingDate)>
            <cfset meetingDate = dateAdd("d", 2, now())>
            </cfif>
            The value to store in the database is then meetingDate.
            • 3. Re: Set a date two days in the future
              Thanks BKBK I put this code but I get an error:
              <!--- UPDATE QUERY --->
              <cfif isDefined("form.UPDATEADDBTN")>
              <cfif FORM.ENTID GTE 1>
              <cfset isCOMMENTSNull = iif(len(trim(form.COMMENTS)) EQ 0, true, false)>
              </cfif>
              <CFQUERY name="updatecompany" datasource="salesdb">
              update COMPANY
              SET COMMENTS= <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(form.COMMENTS)#"
              null="#isCOMMENTSNull#" />,
                 MEETING= <cfqueryparam cfsqltype="cf_sql_timestamp" value="#trim(form.MEETING)#"
              null="#isMEETINGNull#" />,
                 WHERE ENTID = #FORM.ENTID#
              </CFQUERY>
              <cfelse>
              Error:
              Variable ISMEETINGNULL is undefined.
              75 :    MEETING= <cfqueryparam cfsqltype="cf_sql_timestamp" value="#trim(form.MEETING)#" null="#isMEETINGNull#" />,
              • 4. Re: Set a date two days in the future
                BKBK Rockstar
                I said, "The value to store in the database is then meetingDate". You yourself say, implicitly, at least, that there will be no null meetingDates. I therefore expected to see
                MEETING = <cfqueryparam cfsqltype="cf_sql_timestamp" value="#meetingDate#"/>
                • 5. Re: Set a date two days in the future
                  Ok thanks BKBK, I changed it to meetingDate:
                  null="#meetingDate#" />
                  I now get this error:
                  Cannot convert the value of type class coldfusion.runtime.OleDateTime to a boolean
                  75 :    MEETING= <cfqueryparam cfsqltype="cf_sql_timestamp" value="#trim(form.MEETING)#" null="#meetingDate#" />,
                  In my database MEETING is a varchar field, length 255, decimals 0 and allow null. Default: NULL, character set: utf8
                  I tried to change it to timestamp in my mysql program but it doesn't let me (maybe because I already have value in that field? I can delete the column and create it again there if required)
                  • 6. Re: Set a date two days in the future
                    Dan Bracuk Rockstar
                    Whatever you have to do to change that field from varchar to timestamp, do it.
                    • 7. Re: Set a date two days in the future
                      Thanks Dan, I have now changed the MEETING field in the db to:
                      type: timestamp
                      length: 0
                      decimals: 0
                      allow null
                      default: NULL
                      I get this error in coldfusion?:
                      • 8. Re: Set a date two days in the future
                        BKBK Rockstar
                        No, you didn't!
                        I said nothing about nulls. Here it is again: MEETING = <cfqueryparam cfsqltype="cf_sql_timestamp" value="#meetingDate#"/>
                        • 9. Re: Set a date two days in the future
                          BKBK Rockstar
                          I wouldn't go changing many things at once. That would lead to complexity. Start with your original code, and just tweak it a little, using the suggestions. For example
                                  <cfelse>
                                      <!--- Here, apply Dan's advice to convert from string to datetime object. Use, for example, parseDatetime, createdate or createdatetime --->
                                      <cfset meetingDate = parseDatetime(meetingDate)>
                                  </cfif>
                                  update COMPANY
                                  SET COMMENTS = <cfqueryparam cfsqltype="cf_sql_longvarchar" value="#trim(form.COMMENTS)#" null="#isCOMMENTSNull#" />,
                                  MEETING = <cfqueryparam cfsqltype="cf_sql_timestamp" value="#meetingDate#" />
                                  WHERE ENTID = <cfqueryparam cfsqltype="cf_sql_integer" value="#FORM.ENTID#" />
                              </CFQUERY>
                          <cfelse>
                          • 10. Re: Set a date two days in the future
                            Dan Bracuk Rockstar
                            Regarding, "
                            Cannot convert the value of type class coldfusion.runtime.OleDateTime to a boolean"
                            What is the line of code creating this error?
                            • 11. Re: Set a date two days in the future
                              BKBK Rockstar
                              Dan Bracuk wrote:
                              Regarding, "
                              The error was caused by the attribute null="#meetingDate#". I had suggested that this attribute be left out altogether.
                              • 12. Re: Set a date two days in the future
                                Thanks for the help it works great
