10 Replies Latest reply on May 28, 2012 8:48 AM by Muppet Mark
    add multiple page
    Raul_rubi Level 1
      to see if anyone can help me.
      I need to define a script, to create multiple pages.
      at the moment:
      it is believed only one:
      the code is this:
      var myDoc = app.activeDocument;
      var myPg = myDoc.pages.item(-1);
      var myLastPage = myDoc.pages.add.(LocationOptions.AT_END, myPg);
      thanks to all !
        • 1. Re: add multiple page
          csm_phil Level 4
          Hi Raul,
          Your script is working fine, the error is pages.add.
          Raul_rubi wrote:
          at the moment:
          the code is this:
          thanks to all !
          var myLastPage = myDoc.pages.add(LocationOptions.AT_END, myPg);
          thx
          csm_phil
          • 2. Re: add multiple page
            Raul_rubi Level 1
            how?
            Explain please
            Thank
            • 3. Re: add multiple page
              csm_phil Level 4
              Hi Rubi,
              The problem is you using the period character after the add text before. so this is the problem.
              For your information if the anwswer is right please check the right answer otherwise lot of people go and read your thread that is waste of time. please do the process yes or no.
              thx
              csm_phil
              • 4. Re: add multiple page
                [Jongware] Most Valuable Participant
                Is your problem that thhe script only adds a single page? That's easily fixed.
                By the way, if you use AT_END you don't need to supply an additional pointer, the new page will always end up there.
                Untested but this ought to work:
                var addPages = 6;
                // Save first added page ...
                var myFirstAddedPage = myDoc.pages.add(LocationOptions.AT_END);
                addedPages--;
                while (addPages > 0)
                   addPages--;
                ..  'myFirstAddedPage' will point to the first one of your newly added pages.
                • 5. Re: add multiple page
                  Hah -- I saw that in my code and thought, "huh why did I do *that*!?" (I copied a part of the original.)
                  Raul, it would have helped if you told us *why* your code failed! The error message would have indicated this mistake right away.
                  • 6. Re: add multiple page
                    Raul_rubi Level 1
                    ok ,
                    I understand that he had got it wrong ( var myLastPage = myDoc.pages.add.(LocationOptions.AT_END, myPg);
                    but even with what you have written:
                    var addPages = 6;
                    addedPages--;
                       addPages--;
                    I can not create multiple pages
                    in my case I have now created 3 pages
                    and after the 3 would create 2 more for example.
                    • 7. Re: add multiple page
                      Please tell us why not! Help us to help you!
                      But, I'm back behind my computer so let's see what's wrong. Running my script now -- oops.
                      JavaScript Error!
                      Error Number: 2
                      Error String: addedPages is undefined
                      File: ...
                      Line: 5
                      Source: addedPages--;
                      Well, that's pretty clear. I mis-typed 'addedPages' on that line, it should have been 'addPages'. With that corrected, the script does indeed add 6 empty pages at the end of my current document.
                      • 8. Re: add multiple page
                        Raul_rubi Level 1
                        Sorry Jongware,
                        I do not understand.
                        and may close the issue but would not be well.
                        but would not help anyone because the issue is not solved.
                        but what I really want is code Script
                        to create several pages after a specific.
                        for example after page 2.
                        eg add 6 pages
                        See if you can write it, and it is operational.
                        • 9. Re: add multiple page
                          That's different from what I understood from your original post, but ... still no problem. Instead of AT_END, which does what it says, use AFTER (this *also* does what it says):
                          var addPages = 6;
                          // Page number 2 is item(1), since page number 1 is item(0):
                          var addAfter = app.activeDocument.pages.item(1);
                          var myFirstAddedPage = myDoc.pages.add(LocationOptions.AFTER, addAfter);
                          addPages--;
                          // .. then add the others AFTER it as well
                             addPages--;
                             myDoc.pages.add(LocationOptions.AFTER, myFirstAddedPage);
                          1 person found this helpful
                          • 10. Re: add multiple page
                            Muppet Mark Level 5
                            You type too quickly jong although I did do it slightly different…
                            app.activate();
                            var midPage = myDoc.pages.middleItem(); // some middle ref
                            var addPages = 6;
                            do {
                                myDoc.pages.add( LocationOptions.AFTER, midPage );
                                addPages--;
                            } while ( addPages > 0 )
                            Just edited that app.activate which was clearly wrong… needed ()
