How to create single instance of an Remote object?
Avatar
Level 1
I am using a remote object and its method to retrieve and
display some data in a datagrid.
The remote object has a method called getEmployeeList and I
have given it an id as "srv" in my mxml application.
But every time I make a call to that getEmployeeList method,
a new instance of that class(remote object) is created (and also
new values for its members).
But what I wnat is to have the same instance of remote object
per browser .
Is there a way to do this?
Pls. anyone suggest.
Avatar
Level 2
Create your employee list as "public static" in another Java
public class. Get/Set the list from/to the public static class in
your RemoteObject instance. This may solve your problem.
Jeffrey
Avatar
Level 2
You'll want to set the 'scope' attribute on the destination
configuration in the configuration file remoting-config.xml.
http://livedocs.macromedia.com/flex/2/docs/00001130.html
The default is request which means that a new object is
created on each request.
If you use, session then a new object is created for each
session. I believe this is what you're looking for.
If you use, application then a single instance is used by the
entire application.
