13 Replies Latest reply on Jun 4, 2012 9:27 AM by -==cfSearching==-
    SQL Question actually. Select items for all 12 months
    wmkolcz
      I am trying to create a reporting query where I SUM up all the amounts in the database for all 12 mont and come up with a result even if there isn't an amount totalled. I created a table called monthsInYear that has the ID (unique identifier) 1-12 and the months Jan - Dec. I want to SUM up the amounts per month and come up with 12 results (one per month).
      I tried the query below but it only comes up with 1 month and all the amounts totalled to it.
      March484714.13
      I am using:
      SELECT monthsInYear.month, IFNULL( SUM(income.amount), 0 ) AS amount
                      FROM monthsInYear
                      LEFT OUTER JOIN income ON EXTRACT(MONTH FROM income.dateAdded) = monthsInYear.monthID
                      WHERE income.orgID = 10031
                      AND YEAR(income.DateAdded) = '2011'
                      ORDER BY EXTRACT(MONTH FROM income.dateAdded) ASC
      Can anyone tell me what I am doing wrong. I would much much prefer something like:
      January       3000
      February     3000
      March         4000
      April           0
      May           5000
      June           6000
      July            5465
        • 1. Re: SQL Question actually. Select items for all 12 months
          Dan Bracuk Level 5
          Are you sure your query is even running?  You are requesting a field and a sum, but you don't have a group by clause.
          • 2. Re: SQL Question actually. Select items for all 12 months
            wmkolcz Level 1
            Ahhhh..thanks. My orginal did have a group by but the example I found and modified did not. Thanks for the clue!
            Wally Kolcz
            Lead Application Developer
            PetPal Manager
            http://petpalmanager.com
            586.808.2847
            • 3. Re: SQL Question actually. Select items for all 12 months
              BKBK Adobe Community Professional & MVP
              I would start from something this
              SELECT monthsInYear.month, IFNULL(income.amount, 0 ) AS amount
              FROM monthsInYear
              WHERE EXTRACT(MONTH FROM income.dateAdded) = monthsInYear.monthID
              AND income.orgID = 10031
              ORDER BY EXTRACT(MONTH FROM monthsInYear.month) ASC
              • 4. Re: SQL Question actually. Select items for all 12 months
                wmkolcz Level 1
                Thanks! Solved it right after mentioning the group by statement was missing and it runs like a charm!
                Wally Kolcz
                PetPal Manager
                586.808.2847
                • 5. Re: SQL Question actually. Select items for all 12 months
                  wmkolcz Level 1
                  Ok...maybe not. Seems the IFNULL isn't working. I have a view 'getExpenses' that unions a bunch of sources to produce a list of expenses. The view works perfectly
                  But when I run this, it gives me total for only the months that have a total and not the 0 for the ones that come up as null. Any ideas?
                  SELECT monthsInYear.month, monthsInYear.monthID,IFNULL(Sum(getExpenses.cost), 0 ) AS amount
                  FROM monthsInYear, getExpenses
                  WHERE EXTRACT(MONTH FROM getExpenses.dateAdded) = monthsInYear.monthID
                  AND getExpenses.orgID = 10031
                  AND YEAR(getExpenses.DateAdded) = '2011'
                  GROUP BY monthsInYear.month, monthsInYear.monthID
                  ORDER BY monthsInYear.monthID ASC
                  Also tried
                  SELECT m.month, IFNULL( SUM(i.cost), 0 ) AS amount
                  FROM getExpenses i LEFT OUTER JOIN monthsInYear m
                  ON m.monthID = EXTRACT(MONTH FROM i.dateAdded)
                  WHERE orgID = 10031
                  AND YEAR(i.dateAdded) = '2011'
                  GROUP BY m.month
                  ORDER BY EXTRACT(MONTH FROM i.dateAdded) ASC
                  WHEN I DO a direct query, it does come up as NULL (Since there is no value for April)
                  SELECT SUM(cost) FROM getExpenses
                  WHERE EXTRACT(MONTH FROM dateAdded) = '4'
                  AND orgID = 10031
                  • 7. Re: SQL Question actually. Select items for all 12 months
                    wmkolcz Level 1
                    Didn't change the results unless I am missing something
                    SELECT m.month, m.monthID, IFNULL(SUM(e.cost), 0) AS amount
                    FROM getExpenses e LEFT JOIN monthsInYear m
                    ON m.monthID = EXTRACT(MONTH FROM e.dateAdded)
                    WHERE e.orgID = 10031
                    AND YEAR(e.dateAdded) = '2011'
                    GROUP BY m.month, m.monthID
                    ORDER BY EXTRACT(MONTH FROM e.dateAdded) ASC
                    June695.00
                    July71015.00
                    August8272.00
                    October10105.00
                    December12100.00
                    • 8. Re: SQL Question actually. Select items for all 12 months
                      Dan Bracuk Level 5
                      Do a left join the way you did in the opening post.  In other words, the table from which you want all the rows should be left of the word left.
                      • 9. Re: SQL Question actually. Select items for all 12 months
                        Sreeindia
                        Hi
                        As Dan Baruk rightly said try something like below
                        FROM monthsInYear m
                        LEFT JOIN getExpenses e ON m.monthID = EXTRACT(MONTH FROM e.dateAdded)
                        Here is a got article related to joins
                        http://www.devx.com/dbzone/Article/17403/1954
                        Regards
                        Sreekar
                        • 10. Re: SQL Question actually. Select items for all 12 months
                          wmkolcz Level 1
                          Unless I am missing something, it produces the same results. Only the months where a total is found. No 0's
                          Wally Kolcz
                          PetPal Manager
                          586.808.2847
                          • 11. Re: SQL Question actually. Select items for all 12 months
                            Dan Bracuk Level 5
                            It might be your grouping fields.  Group by the non-aggregate fields in your select clause.  Once again, I'm surprised the query actually ran the way you presented it.
                            • 12. Re: SQL Question actually. Select items for all 12 months
                              FROM monthsInYear m
                              I think it is sufficient to group by just one column, using the table to the left of the join, like this:
                              FROM monthsInYear m
                              GROUP BY m.monthID
                              ORDER BY m.monthID ASC
                              • 13. Re: SQL Question actually. Select items for all 12 months
                                -==cfSearching==- Level 4
                                Also tried
                                WHERE orgID = 10031
                                GROUP BY m.month
                                There are two problems. First, the tables in your join are reversed. A LEFT JOIN returns all records from the left hand table (expenses) even if there are no matching records in the right hand table. What you want is the opposite. So the months table must on be on the left side of the JOIN:
                                            FROM    monthsInYear m LEFT JOIN getExpenses i ON m.monthID = EXTRACT(MONTH FROM i.dateAdded)
                                Second, when there is no matching expense record, the column values will all be null. So as soon as you use one of the expense fields in your WHERE clause, ie
                                            WHERE i.orgID = 10031
                                ... those missing records are dropped, because a null value is never equal to anything. So you are negating the outer join altogether. You need to move those conditions into the JOIN clause instead:
                                              FROM   monthsInyear m LEFT OUTER JOIN getExpenses i
        AND i.orgID = 10031
        AND YEAR(i.dateAdded) = 2011
                                             GROUP BY m.month
                                             ORDER BY m.month
