SQL Question actually. Select items for all 12 months
May 27, 2012 May 27, 2012
I am trying to create a reporting query where I SUM up all the amounts in the database for all 12 mont and come up with a result even if there isn't an amount totalled. I created a table called monthsInYear that has the ID (unique identifier) 1-12 and the months Jan - Dec. I want to SUM up the amounts per month and come up with 12 results (one per month).
I tried the query below but it only comes up with 1 month and all the amounts totalled to it.
March484714.13
I am using:
SELECT monthsInYear.month, IFNULL( SUM(income.amount), 0 ) AS amount
                FROM monthsInYear
                LEFT OUTER JOIN income ON EXTRACT(MONTH FROM income.dateAdded) = monthsInYear.monthID
                WHERE income.orgID = 10031
                AND YEAR(income.DateAdded) = '2011'
                ORDER BY EXTRACT(MONTH FROM income.dateAdded) ASC
Can anyone tell me what I am doing wrong. I would much much prefer something like:
January       3000
February     3000
March         4000
April           0
May           5000
June           6000
July            5465
Advanced techniques
3.2K
Valorous Hero , Jun 02, 2012 Jun 02, 2012
But when I run this, it gives me total for only the months that have a total and not the 0 for the ones that come up as null. Any ideas?
Also tried
SELECT m.month, IFNULL( SUM(i.cost), 0 ) AS amount
FROM getExpenses i LEFT OUTER JOIN monthsInYear m
ON m.monthID = EXTRACT(MONTH FROM i.dateAdded)
WHERE orgID = 10031
AND YEAR(i.dateAdded) = '2011'
GROUP BY m.month
ORDER BY EXTRACT(MONTH FROM i.dateAdded) ASC
There are two problems. First, the tables in your join are reversed. A LEFT JOIN returns all
May 28, 2012 May 28, 2012
Are you sure your query is even running?  You are requesting a field and a sum, but you don't have a group by clause.
Ahhhh..thanks. My orginal did have a group by but the example I found and modified did not. Thanks for the clue!
Wally Kolcz
Lead Application Developer
PetPal Manager
http://petpalmanager.com
586.808.2847
May 30, 2012 May 30, 2012
I would start from something this
SELECT monthsInYear.month, IFNULL(income.amount, 0 ) AS amount
FROM monthsInYear
WHERE EXTRACT(MONTH FROM income.dateAdded) = monthsInYear.monthID
AND income.orgID = 10031
ORDER BY EXTRACT(MONTH FROM monthsInYear.month) ASC
Thanks! Solved it right after mentioning the group by statement was missing and it runs like a charm!
Wally Kolcz
PetPal Manager
586.808.2847
Ok...maybe not. Seems the IFNULL isn't working. I have a view 'getExpenses' that unions a bunch of sources to produce a list of expenses. The view works perfectly
SELECT monthsInYear.month, monthsInYear.monthID,IFNULL(Sum(getExpenses.cost), 0 ) AS amount
FROM monthsInYear, getExpenses
WHERE EXTRACT(MONTH FROM getExpenses.dateAdded) = monthsInYear.monthID
AND getExpenses.orgID = 10031
AND YEAR(getExpenses.DateAdded) = '2011'
GROUP BY monthsInYear.month, monthsInYear.monthID
ORDER BY monthsInYear.monthID ASC
Also tried
WHERE orgID = 10031
GROUP BY m.month
WHEN I DO a direct query, it does come up as NULL (Since there is no value for April)
SELECT SUM(cost) FROM getExpenses
WHERE EXTRACT(MONTH FROM dateAdded) = '4'
AND orgID = 10031
Use a left join.
Didn't change the results unless I am missing something
SELECT m.month, m.monthID, IFNULL(SUM(e.cost), 0) AS amount
FROM getExpenses e LEFT JOIN monthsInYear m
ON m.monthID = EXTRACT(MONTH FROM e.dateAdded)
WHERE e.orgID = 10031
AND YEAR(e.dateAdded) = '2011'
GROUP BY m.month, m.monthID
ORDER BY EXTRACT(MONTH FROM e.dateAdded) ASC
June695.00
July71015.00
August8272.00
October10105.00
December12100.00
Do a left join the way you did in the opening post.  In other words, the table from which you want all the rows should be left of the word left.
May 31, 2012 May 31, 2012
Hi
As Dan Baruk rightly said try something like below
FROM monthsInYear m
LEFT JOIN getExpenses e ON m.monthID = EXTRACT(MONTH FROM e.dateAdded)
Here is a got article related to joins
http://www.devx.com/dbzone/Article/17403/1954
Regards
Sreekar
Unless I am missing something, it produces the same results. Only the months where a total is found. No 0's
Wally Kolcz
PetPal Manager
586.808.2847
It might be your grouping fields.  Group by the non-aggregate fields in your select clause.  Once again, I'm surprised the query actually ran the way you presented it.
FROM monthsInYear m
I think it is sufficient to group by just one column, using the table to the left of the join, like this:
FROM monthsInYear m
GROUP BY m.monthID
ORDER BY m.monthID ASC
Valorous Hero ,
Also tried
WHERE orgID = 10031
GROUP BY m.month
There are two problems. First, the tables in your join are reversed. A LEFT JOIN returns all records from the left hand table (expenses) even if there are no matching records in the right hand table. What you want is the opposite. So the months table must on be on the left side of the JOIN:
            FROM    monthsInYear m LEFT JOIN getExpenses i ON m.monthID = EXTRACT(MONTH FROM i.dateAdded)
Second, when there is no matching expense record, the column values will all be null. So as soon as you use one of the expense fields in your WHERE clause, ie
            WHERE i.orgID = 10031
... those missing records are dropped, because a null value is never equal to anything. So you are negating the outer join altogether. You need to move those conditions into the JOIN clause instead:
              FROM   monthsInyear m LEFT OUTER JOIN getExpenses i
                                        AND i.orgID = 10031
                                        AND YEAR(i.dateAdded) = 2011
             GROUP BY m.month
             ORDER BY m.month
Documentation
