1. Re: Unexplained problem with PF_TRANSFER_RECT in Premiere
walczakb May 31, 2012 1:30 PM (in response to walczakb)So I guess there will be no help. Has anyone here ever used the PF_TRANSFER_RECT? Succesfully?
2. Re: Unexplained problem with PF_TRANSFER_RECT in Premiere
shachar carmi Jun 1, 2012 2:51 AM (in response to walczakb)hi walczakb!
yes, many including me have used PF_TRANSFER_RECT successfully, but i only tested it in AE.
i never tried it in premier.
are you sure it's the PF_TRANSFER_RECT that giver you the problem?
sounds like it's the input buffer to that function where the error is.
i know some of the following may be obvious, but have you tried:
1. copying the input you were going to send to PF_TRANSFER_RECT, directly into the output and see that it's ok.
2. building a very simple plug-in just to test PF_TRANSFER_RECT in premier without any other process.
it's not impossible that it's simply a bug in premier, so you may not be doing anything wrong.
have you posted the same question in the premier SDK forum?
you can also contact zac lam by mail and ask if this is a known issue.
3. Re: Unexplained problem with PF_TRANSFER_RECT in Premiere
walczakb Jun 1, 2012 5:31 AM (in response to shachar carmi)Hi,
Thanks for your answer.
Yes, I am sure it's PF_TRANSFER_RECT. If I simply PF_COPY the temp world or the mask world to the output, without using the transfer function, they work ok.
I also tried number 2 - just create a mask world with a single color, and overlay it on the output. The results are the same - alpha bleeds into the blue channel, and generally very weird behavior.
I will post it on the Premiere SDK forum then, although it is the AE SDK that I am using, not Premiere, as advised by Premiere SDK pdf.
4. Re: Unexplained problem with PF_TRANSFER_RECT in Premiere
Zac Lam Jun 1, 2012 3:38 PM (in response to walczakb)Hi walczakb,
It sounds like you're working with PPro-specific pixel formats in PPro, such as BGRA and VUYA, right? I believe PF_TRANSFER_RECT() works in PPro if you stick with the default pixel format for After Effects plug-ins, i.e. ARGB. But support in PF_TRANSFER_RECT() for PPro-specific pixel formats has not yet been added. If you can confirm that's what you're requesting, I can log a bug.
Zac
5. Re: Unexplained problem with PF_TRANSFER_RECT in Premiere
walczakb Jun 2, 2012 1:26 AM (in response to Zac Lam)Hi Zac,
Yes, I'm working with PPro-specific pixel formats. I do confirm the request for BGRA and YUVA support in PF_TRANSFER_RECT() then.
I tried working with ARGB (PF_Pixel8), both straight on, and then trying to cheat BGRA by assigning alpha to blue and red to green, but still the results were weird. There must be something about world creation that I don't understand.
It was also funny to see Premiere switching from YUVA to BGRA processing when I clicked on the program interface icon to set a center point.
All the best
Bart
6. Re: Unexplained problem with PF_TRANSFER_RECT in Premiere
Zac Lam Jul 11, 2012 9:14 AM (in response to walczakb)Hi Bart,
This shortcoming with PF_TRANSFER_RECT() in alternate pixel formats has been logged in our bug tracker with ID #3285673.
Cheers,
Zac
7. Re: Unexplained problem with PF_TRANSFER_RECT in Premiere
walczakb Jul 12, 2012 3:11 PM (in response to Zac Lam)Thanks Zac!
Any idea what it actually means timewise?
All the best
Bart
8. Re: Unexplained problem with PF_TRANSFER_RECT in Premiere
shachar carmi Jul 13, 2012 7:00 AM (in response to walczakb)i think that after you delete the file (from the file system, not the
project!),
then you need to rebuild, and not build.
perhaps even clean and then rebuild.
