1 2 3 Previous Next 114 Replies Latest reply: Sep 3, 2012 6:19 PM by Hudechrome RSS
    Weird Crop tool behaviour with 16-bit files
    erickellerman Community Member
      Shadow areas of my 16-bit files show strange patterns if I use the Crop tool to rotate. I can also replicate the problem by doing the following:
      Make a new empty 16-bit file in PS6 in RGB mode (File>New). Fill it with 100% black. Use the Crop tool and rotate to taste. Press Enter to accept the crop and zoom in to enjoy the black and grey noise patterning reminiscent of a man's suit. The Straighten tool will achieve the same result. Your suit pattern will vary according to the degree of rotation.
      The problem goes away if you subsequently convert the file to 8-bit, or convert to any other mode (Greyscale, Lab, CMYK).
      This patterning is easily visible at 100% view or less, and appears whether the View>Show>Pixel Grid option is on or off. It is decidedly NOT the pixel grid I am seeing.
      This effect can be created with files from both my Canon and Hasselblad cameras.
      I'm using a Mac Pro with OS10.6.8.
        • 1. Re: Weird Crop tool behaviour with 16-bit files
          Chris Cox Adobe Employee
          Which version of Photoshop are you using?
          And which options for the crop tool?
          • 2. Re: Weird Crop tool behaviour with 16-bit files
            Hello Chris
            I'm using PS6. I invoke the Crop tool, Unconstrained, Delete Cropped Pixels unselected. Degree of rotation doesn't matter, though the pattern noise will vary with the degree of rotation.
            I have now discovered that this weirdness ONLY happens with crop rotation of 16-bit files. If I open a 32-bit file and rotate, there is no patterning. If I convert this rotated crop to 16-bit, there is no change. But if I convert the file to 16-bit and THEN rotate, I get the noise again. 8-bit files do not show this behaviour. Saving rotated 16-bit files to TIFF and PSD preserves the patterning. Converting these files to jpeg (8-bit, obviously) removes the noise.
            • 3. Re: Weird Crop tool behaviour with 16-bit files
              Problem 'explained'!!! The video card is implicated.
              Go to Preferences>Performance. If under Detected Graphics Processor, you have checked Use Graphics Processor, then the 16-bit file crop/rotation weirdness will occur as described above. If you leave it unchecked, then restart PS6, the gentlemen's suit patterns will no longer appear upon cropping/rotating.
              • 4. Re: Weird Crop tool behaviour with 16-bit files
                Which GPU are you using?
                We'll have to investigate a bit more to isolate the cause.
                • 5. Re: Weird Crop tool behaviour with 16-bit files
                    Chipset Model:          ATI Radeon HD 4870
                    Type:          GPU
                    Bus:          PCIe
                    Slot:          Slot-1
                    PCIe Lane Width:          x16
                    VRAM (Total):          512 MB
                    Vendor:          ATI (0x1002)
                    Device ID:          0x9440
                    Revision ID:          0x0000
                    ROM Revision:          113-B7710F-176
                    EFI Driver Version:          01.00.318
                  • 6. Re: Weird Crop tool behaviour with 16-bit files
                    I have now heard from owners of the ATI Radeon HD 5800 and the Nvidia 570M that they too suffer from this patterning b ehaviour.
                    • 8. Re: Weird Crop tool behaviour with 16-bit files
                      We have not been able to reproduce this problem.
                      But it could be something about your video card or driver version.
                      • 9. Re: Weird Crop tool behaviour with 16-bit files
                        Noel Carboni Community Member
                        It would be good to get more detail about what version of the driver you have.
                        In Photoshop do Help - System Info, copy, then post the info here.
                        -Noel
                        • 10. Re: Weird Crop tool behaviour with 16-bit files
                          Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
                          Operating System: Mac OS 10.6.8
                          System architecture: Intel CPU Family:6, Model:26, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                          Physical processor count: 8
                          Logical processor count: 16
                          Processor speed: 2260 MHz
                          Built-in memory: 16384 MB
                          Free memory: 10979 MB
                          Memory available to Photoshop: 15749 MB
                          Memory used by Photoshop: 71 %
                          Image tile size: 1024K
                          Image cache levels: 6
                          OpenGL Drawing: Enabled.
                          OpenGL Drawing Mode: Normal
                          OpenGL Allow Normal Mode: True.
                          OpenGL Allow Advanced Mode: True.
                          OpenGL Allow Old GPUs: Not Detected.
                          OpenGL Version: 2.1 ATI-1.6.36
                          OpenCL Version:
                          Video Card Vendor: ATI Technologies Inc.
                          Video Card Renderer: ATI Radeon HD 4870 OpenGL Engine
                          Display: 2
                          Display Depth:= 32
                          Display Bounds:=  top: 0, left: -1920, bottom: 1200, right: 0
                          Video Renderer ID: 16914951
                          Video Card Memory: 495 MB
                          Video Rect Texture Size: 8192
                          OpenCL Version: 1.0 (Dec 23 2010 17:30:26)
                          Display: 1
                          Main Display
                          Display Depth:= 32
                          Display Bounds:=  top: 0, left: 0, bottom: 1024, right: 1280
                          Serial number: 91199850316091008089
                          Application folder: HD1:Applications:Adobe Photoshop CS6:
                          Photoshop scratch has async I/O enabled
                          Scratch volume(s):
                            RAID 1, 3.64T, 1.11T free
                            HD1, 595.9G, 301.3G free
                          Required Plug-ins folder: HD1:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
                          Primary Plug-ins folder: HD1:Applications:Adobe Photoshop CS6:Plug-ins:
                          Additional Plug-ins folder: not set
                          Installed components:
                             adbeape.framework   adbeape   3.3.8.19346   66.1025012
                             AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
                             adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
                             AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
                             AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
                             AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                             AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
                             AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
                             AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
                             AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
                             AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120201
                             AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
                             AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
                             AdobeLinguistic.framework      17206
                             AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
                             AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
                             AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
                             AdobePDFSettings.framework   AdobePDFSettings   1.4
                             AdobePIP.framework   AdobePIP   6.0.0.1654
                             AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
                             AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                             AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
                             AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
                             AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
                             ahclient.framework   ahclient   1.7.0.56
                             aif_core.framework   AdobeAIF   3.0.00   62.490293
                             aif_ocl.framework   AdobeAIF   3.0.00   62.490293
                             aif_ogl.framework   AdobeAIF   3.0.00   62.490293
                             AlignmentLib.framework   xcode   1.0.0.1
                             amtlib.framework   amtlib   6.0.0.75
                             boost_date_time.framework   boost_date_time   6.0.0.0
                             boost_signals.framework   boost_signals   6.0.0.0
                             boost_system.framework   boost_system   6.0.0.0
                             boost_threads.framework   boost_threads   6.0.0.0
                             Cg.framework   NVIDIA Cg
                             CIT.framework   CIT   2.0.5.19287   145486
                             data_flow.framework   AdobeAIF   3.0.00   62.490293
                             dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
                             dvacore.framework   dvacore   6.0.0.0
                             dvamarshal.framework   dvamarshal   6.0.0.0
                             dvamediatypes.framework   dvamediatypes   6.0.0.0
                             dvaplayer.framework   dvaplayer   6.0.0.0
                             dvatransport.framework   dvatransport   6.0.0.0
                             dvaunittesting.framework   dvaunittesting   6.0.0.0
                             dynamiclink.framework   dynamiclink   6.0.0.0
                             FileInfo.framework   FileInfo   66.145433   66.145433
                             filter_graph.framework   AdobeAIF   3.0.00   62.490293
                             hydra_filters.framework   AdobeAIF   3.0.00   62.490293
                             ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                             ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                             image_compiler.framework   AdobeAIF   3.0.00   62.490293
                             image_flow.framework   AdobeAIF   3.0.00   62.490293
                             image_runtime.framework   AdobeAIF   3.0.00   62.490293
                             LogSession.framework   LogSession   2.1.2.1652
                             mediacoreif.framework   mediacoreif   6.0.0.0
                             PlugPlug.framework   PlugPlug   3.0.0.383
                             UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
                             wrservices.framework
                          Required plug-ins:
                             Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                             ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
                             Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Average 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
                             Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Camera Raw 7.1 (354), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                             Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Cineon 13.0 20120315.r.428 2012/03/15:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
                             Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
                             Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
                             Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Crop and Straighten Photos 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                             Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Difference Clouds 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
                             Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                             Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                             Enable Async I/O 13.0 20120315.r.428 2012/03/15:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
                             Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             FastCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
                             Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                             IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                             Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                             Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                             Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
                             Matlab Operation 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                             Measurement Core 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                             Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             MMXCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                             Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Multiprocessor Support 13.0 20120315.r.428 2012/03/15:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                             Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             NTSC Colors 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                             Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
                             OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             PCX 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
                             Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Photoshop 3D Engine 13.0 20120315.r.428 2012/03/15:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                             Picture Package Filter 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                             Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Pixar 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
                             Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
                             Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Radiance 13.0 20120315.r.428 2012/03/15:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
                             Read Watermark NO VERSION - from the file “DigiRead.plugin”
                             Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                             ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                             Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Solarize 13.0 20120315.r.428 2012/03/15:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
                             Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                             Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                             Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                             Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
                             ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                          Optional and third party plug-ins:
                             BWStyler 1.03 BWStyler 1.03 © 2006-11 Harald Heim & The Plugin Site - from the file “BWStyler.plugin”
                             Hidden Topaz Labs Denoise - from the file “TopazRemaskAutomate.plugin”
                             Imagenomic Plug-in Console 1.2 (c) 2010 Imagenomic, LLC. - from the file “ImagenomicPluginConsole.plugin”
                             Nik Selective Tool 2.103, Copyright © 2000-2012 Nik Software Inc. - from the file “SelectivePalette.plugin”
                             PG-Processor 2.0.1 ©2002-2010 PixelGenius LLC - from the file “PG-Processor.plugin”
                             PhotoKit Capture Sharpener 2 2.0.6 ©2002-2010 PixelGenius LLC - from the file “PhotoKit Sharpener 2.plugin”
                             PhotoKit Creative Sharpener 2 2.0.6 ©2002-2010 PixelGenius LLC - from the file “PhotoKit Sharpener 2.plugin”
                             PhotoKit Output Sharpener 2 2.0.6 ©2002-2010 PixelGenius LLC - from the file “PhotoKit Sharpener 2.plugin”
                             PhotoKit Preview Helper 2.1.6 ©2002-2010 PixelGenius LLC - from the file “PG Toolbox Previewer.plugin”
                             PixelGenius Toolbox 2.2.1 ©2002-2010 PixelGenius LLC - from the file “PixelGenius Toolbox.plugin”
                             Portraiture 2.3 © 2004-2010 Imagenomic, LLC - from the file “Portraiture.plugin”
                             Silver Efex Pro 2 2.004, Copyright © 2000-2012 Nik Software Inc. - from the file “Silver Efex Pro 2.plugin”
                             Topaz ReMask 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_remask3.plugin”
                          Plug-ins that failed to load: NONE
                          Flash:
                             Eric's
                             Mini Bridge
                             Kuler
                          Installed TWAIN devices: NONE
                          • 11. Re: Weird Crop tool behaviour with 16-bit files
                            I'm using a Radeon 4870 here at home, with MacOS 10.6.8 -- and cannot reproduce those artifacts.
                            • 12. Re: Weird Crop tool behaviour with 16-bit files
                              Hi Chris
                              The problem has been replicated by other users with different cards (a ATI Radeon HD 5800, for example).
                              The key conditions are: 16-bit file, RGB, with 'Use Graphics Processor' selected in Preferences. Saving as TIFF or .psd preserves the patterning. Saving as jpeg removes it.
                              • 13. Re: Weird Crop tool behaviour with 16-bit files
                                For an example of the patterning, download the file (1mb) at http://www.erickellermanphotography.com/pattern.psd
                                • 14. Re: Weird Crop tool behaviour with 16-bit files
                                  siskin11 Community Member
                                  I assume I'm the affected user Eric is referring to with the Radeon HD 5800. I am running Windows 7 64x on an 17-2600 machine with 12GB RAM. The video-card driver is version 8.961.
                                  This problem has rendered the crop and tilt function on CS6 more or less useless to me at present. It seems to be some kind of interference effect, because, for me, the patterning is remarkably uniform - long, intersecting lines very much like a ghost tartan watermark on the image. The attached image shows the patterning at 500%. This occurred on a 16-bit image after a minor crop and tilt. It is only really visible when zoomed in, but is definitely burned into the image. I use GPU acceleration in Normal mode.
                                  • 15. Re: Weird Crop tool behaviour with 16-bit files
                                    Yes, this is the basic patterning I have too. The degree of rotation determines the final effect.
                                    • 16. Re: Weird Crop tool behaviour with 16-bit files
                                      Here's a weird thing:  I just opened the file http://www.erickellermanphotography.com/pattern.psd on my PC in Photoshop CS6 and it is perfectly black.
                                      I even added two extreme curves adjustment layers above the background.  There is no pattern there.
                                      -Noel
                                      • 17. Re: Weird Crop tool behaviour with 16-bit files
                                        Do you see a difference when you choose different settings in the Crop tool for [  ] Delete Cropped Pixels?
                                        -Noel
                                        • 18. Re: Weird Crop tool behaviour with 16-bit files
                                          I don't know about Eric, but I don't have a Mac. Eric's pattern is certainly there on my screen, though. Oddly, when I select the pattern with the eyedropper, the info palette shows no difference in colour between the pattern and the background - both register as R0G0B0.
                                          The issue occurs whatever you select under Delete Cropped Pixels. Here's another weird thing though - I just noticed on a layered image (multiple image layers) that the pattern wasn't visible until I deselected the top layer - in other words, it only affected the background layer, although the two layers are nearly identical (one is sharpened).
                                          Peter
                                          • 19. Re: Weird Crop tool behaviour with 16-bit files
                                            If 'Delete Cropped PIxels' remains unchecked, the effect occurs. If it's checked, then rotation has no effect. And I just downloaded my own PSD file, and lo and behold! The noise is till there! No adjustment layer has any effect, as far as I can see. And I also fail to pick up any differences with the eye dropper.
                                            I'm a Mac user.
                                            • 20. Re: Weird Crop tool behaviour with 16-bit files
                                              There is in implicational order at work: If 'Use Graphics Processor' is selected in Preferences>Performance, then not checking [ ] Delete Cropped Pixels produces the effect. If 'Use Graphics Processor' is not selected (after restarfting PS), then it doesn't matter whether 'Delete Cropped Pixels' is selected or not.
                                              • 21. Re: Weird Crop tool behaviour with 16-bit files
                                                Bingo! If I download my .psd file, and then  open it in PS6 with 'Use Graphics Processor' unselected, guess what? Yes, NO patterning! So UGP is the cucial element.
                                                • 22. Re: Weird Crop tool behaviour with 16-bit files
                                                  Seems to me it's a video driver issue then, and it may only be affecting your display when pixels extend beyond the boundary of the visible canvas.
                                                  • I have an ATI Radeon HD 5670 with Catalyst 12.2 drivers (internally numbered 8.950.0.0) and don't see the problem.
                                                  • Eric has an ATI Radeon HD 4670 with the drivers shipping with Apple's OSX 10.6.8 and DOES see the problem.
                                                  • Peter has an ATI Radeon HD 5800 with Catalyst 12.4 drivers (internally numbered 8.961) and DOES see the problem.
                                                  My conclusion is that it's a problem recently introduced by ATI.  This is not surprising, their recent driver versions have not worked well with Photoshop.  The last good version was Catalyst 12.2.
                                                  Eric, you pretty much need to wait on Apple to provide new drivers with an OS update.
                                                  Peter, you could either uninstall Catalyst 12.4 and drop back to 12.2, or you could move forward to ATI's 12.6 beta version.
                                                  -Noel
                                                  • 23. Re: Weird Crop tool behaviour with 16-bit files
                                                    The artifacts are in the transparency channel, not the color channels.
                                                    Layer -> Layer Mask -> From transparency to get them into a visible mask
                                                    They do look like interpolation artifacts (like something used low precision math for the transparency channel).
                                                    But I still can't reproduce that on my system with Photoshop CS6 (10.6.8, Radeo 4870).
                                                      Type:          GPU
                                                      Bus:          PCIe
                                                      Slot:          Slot-1
                                                      Device ID:          0x9440
                                                      Revision ID:          0x0000
                                                      ROM Revision:          113-B7710C-176
                                                    • 24. Re: Weird Crop tool behaviour with 16-bit files
                                                      Chris, did you have a look at my psd file with GPU checked in PS Prefs?
                                                      • 25. Re: Weird Crop tool behaviour with 16-bit files
                                                        You PSD is what I was referring to -- it's an example of artifacts in the transparency channel.
                                                        The artifacts are already present in that file, so I can't use it to reproduce anything.
                                                        I need to know how to get the artifacts to start with.
                                                        • 26. Re: Weird Crop tool behaviour with 16-bit files
                                                          Chris, when I look at the pattern.psd file Eric posted, there are no artifacts.  Not even in the transparency channel.
                                                          Honest!
                                                          It must be something that's happening to the file when being opened on your particular system.
                                                          I did a Layer - Layer Mask - From Transparency, copied the mask, and pasted it as a new layer.  It's pure white.  The histogram says so and two layers of extreme curves adjustments say so.
                                                          The artifacts are NOT present in that file!
                                                          Edit:  Scratch that.  I went through it again and saw something different.  Eric, did you update the file at the link posted above?
                                                          -Noel
                                                          • 27. Re: Weird Crop tool behaviour with 16-bit files
                                                            It's a 16 bit file, and the errors are small.
                                                            Open patterns.psd, Layer -> Layer Mask -> From Transparency, option/alt click on the layer mask to show it, Levels and change the black point to 245, commit the levels adjustment, now repeat the same levels adjustment and you should see the artifacts.
                                                            The errors appear to be in the least significant 2 bits of the result.
                                                            But resampling solid white should always result in solid white -- so something when wrong before we saw that document.
                                                            • 28. Re: Weird Crop tool behaviour with 16-bit files
                                                              No, Noel. No updates! My strong feeling is that the Graphics Processor is involved, as if I have it switched off, even my own psd file looks clean.
                                                              • 29. Re: Weird Crop tool behaviour with 16-bit files
        I probably made a mistake the first time somehow in processing the image.  Here's what I see.  The curves layers are as extreme as they can be.  Looks like maybe a 1 or 2 level error in the 16 bit data.
        -Noel
        • 30. Re: Weird Crop tool behaviour with 16-bit files
        And that's exactly what I'm seeing.
        The file is already dirty because of those artifacts in the transparency channel.
        Something happened to the file before we saw it to cause the artifacts.
        • 31. Re: Weird Crop tool behaviour with 16-bit files
        Chris I've been able to reproduce the issue in a new document.  Here's how:
        • File - New, 400 x 300 px x 96 ppi, 16 bits/channel, Transparent
        • Set foreground color to pure black
        • Bucket fill
        • Choose Crop Tool
        • Uncheck [  ] Delete Cropped Pixels
        • Click the Straighten Button
        • Drag a line across the image right and upward until 5.0 degrees is indicated.
        • Complete the crop.
        This reproduces the problem whether a Grayscale or RGB image is created.
        I'm thinking another inaccuracy is making this ultra slight transparency error visible on some GPU-accelerated modes with some drivers.
        -Noel
        • 32. Re: Weird Crop tool behaviour with 16-bit files
        I see. But still, if my file is 'dirty' before it go to you two, how come I can clean it myself if I view it with the GP turned off in Prefs? Or convert to 8 or 32-bit. Or save it to jpeg?
        • 33. Re: Weird Crop tool behaviour with 16-bit files
        Eric, normally you would not expect to see a 1 or 2 level (out of 32768) transparency difference on-screen.  I suspect your particular drivers are showing that where others are not because of an error unrelated to the transparency channel glitches.
        There are just bugs all over this windshield!
        -Noel
        • 34. Re: Weird Crop tool behaviour with 16-bit files
        It looks clean because the error is very small (4 / 32768).
        But something is making it more visible on your system, and so far I haven't gotten it to be visible without using two extreme levels or curves adjustments.
        • 35. Re: Weird Crop tool behaviour with 16-bit files
        FYI, the transparency channel gains the same minor transparency glitches with just Image - Image Rotation - Arbitrary.
        Note that these glitches don't really look like what Eric and Peter are seeing.  That *could* be another issue entirely.
        -Noel
        • 36. Re: Weird Crop tool behaviour with 16-bit files
        Paulo Skylar Community Member
        I will add my observation on the unexpected behavior of the transparency channel. While I do not see the behavior noted in the original posting, I do see the transparency error reported by Chris and Noel. It is only present in 16-bit mode and only with  my graphics processor turned on ( Nvidia 9600 GT, CS6).
        In my case I see someting not yet mentioned. I can readily see the error on the display, which should be displaying pure black (Fill canvas with black, crop tool, rotate). It appears to be an error of a few percent on the display so if the calculation error is in fact only two LSBs in the mask data, then it appears as if the higher & lower order bytes are switched in writing the transparency channel ....... or some other error.
        Paulo
        • 37. Re: Weird Crop tool behaviour with 16-bit files
        Paulo - can you get a screenshot of what you're seeing?  I'm starting to suspect this is a display pipeline error, but it may only happen in certain circumstances (which I haven't yet reproduced).
        • 38. Re: Weird Crop tool behaviour with 16-bit files
        Here are  screen shots at 100% magnification.  The canvas was 100 x 100 pixels and using the crop tool I "straightened" the image by 40 degrees (if I remember correctly) - different angles yield different patterns, of course.
        Here is another view with a levels adjustment
        I had a medium, blue transparency  grid, which can be resolved.
        Paulo
        • 39. Re: Weird Crop tool behaviour with 16-bit files
        I'm only barely seeing the pattern you are seeing in the first of the two images you posted, Paulo - it looks almost perfectly black from here.  If I work at it I can just barely see the pattern, especially if I zoom in.  Looks like just a 1 or 2 level shift above pure black in that image.
        It occured to me the appearance / absence of this might just be differing responses to very dim level changes with different display systems, so I purposefully reproduced the issue and did a screen grab, but nope - I'm still getting a perfectly black display.  I think Chris must be right - something not right in the display pipeline on only some systems.
        -Noel
        1 2 3 Previous Next
