CFB2 RDS Connection Error
May 31, 2012 May 31, 2012
Hi Everyone,
Ok I'm using a trial version of the CFB2 connecting to a trial version of CFX.  Now my CFB2 connects to CF9 servers find via RDS but just can't connect to my CFX trial server via RDS.  My CFX is running on W2K8R2 IIS7.  I get the following message when I try the test connection "Could not initialize class com.adobe.rds.core.services.Messages"  Please help because we're going to be purchasing CFX and if RDS doesn't work for us then it's a complete waste of money.
thanks
Builder
1.8K
Jun 01, 2012 Jun 01, 2012
I've had the same issue too.  I made Adobe aware of it, but they weren't particularly forthcoming or helpful in getting it sorted.
I gave up.
You def have RDS enabled, yeah?  The bits 'n' pieces you need to uncomment in web.xml are uncommented?  This was not the cause of my problem, but it has been the cause of other people's problems in the same area.
Adam
Hi Adam,
thanks for the reply.  Since yesterday I found out that it may have something to do with my Firewall/Proxy.  I'm using Microsoft TMG.  The reasoning behind this is when I VPN in and then connect to RDS, the connection is fine, however if I try connecting from outside the network it talks to the server but I get the "com" error message.  The thing is that everything works fine for previous versions of CF just not this one, very strange.
Any ideas or suggestions is very helpful, I need this working ASAP.  BTW are there any specific ports that CF X uses for RDS other than port 80?
John
Ok I found out what my issue was and resolved it.  For some reason in my situation, in order to connect to the RDS the host's FQDN must be the same domain as my network.
So if my domain is abc.com
then webserver.123.com won't work (even though the 123.com is pointing to the correct IP and routed correctly to the server).
It must be webserver.abc.com (even though the settings are exactly the same as webserver.123.com).
Anyway, didn't have this issue before with CF 8 or 9.  Weird, just thought I'd let everyone know what my result is.
thanks,
John
Jun 04, 2012 Jun 04, 2012
Sounds like a regression bug to me.  You might wanna raise it with Adobe:
https://bugbase.adobe.com/
But don't hold yer breath for them to fix it in a hurry...
Adam
Documentation
