Hello everyone.
I own a copy of Photoshop CS6.
Switching from Photoshop CS to CS6, I have found this version to be extremely slow and I can not find a reason why it is like this. It is impossible for me to work on it.
Problem: Slow performance, when using the brush tool there is a long delay - lag. The brush takes more than 8 seconds to catch up with my strokes.
Software: | Adobe Photoshop CS6 x64 |
OS: | Windows 7 x64 SP1 |
CPU: | AMD Phenom II X4 965 BE |
GPU: | Radeon 6790 OC @ 920Mhz |
RAM: | A-Data DDR3 1333Mhz CAS9 4GB (x2) |
SSD: | A-Data 510 128GB SATA3 |
HDD: | Samsung SATA 1TB |
Tried:
- Memory usage allowed upgraded to 6GB, nothing changed.
- Default selected "Scratch Disk" is the main SSD which has over 58GB of free space, I've tried selecting the secondary HDD as well but nothing changes.
- Disabled the "Use Graphic Processor" square. nothing changed.
- Disabled the "Use open CL" square in advanced Graphic Processor Settings. Nothing changed.
- Changed power management settings in windows to "High Performance". nothing changed.
- Disabling tablet pc service doesn't help.
Notes:
- Graphic drivers are the latest release on AMD website
- Windows is completely updated
- SSD Firmware is the latest available.
- The issue happens both with mouse and tablet.
- 1px brush and 5000px brush lag just alike in zoomed and not zoomed canvas.
- This happens on both x64 and x86 versions of the software.
Any help is aprecihated.
Thank you in advance.
Download and install the ATI Catalyst version 12.2 drivers specifically (though they will end up saying 12.3 once you install them). At the moment, though it is not the latest release, 12.2 appears to be the best recent driver set to work with Photoshop.
http://support.amd.com/us/gpudownload/windows/previous/Pages/radeonaiw_vista64.aspx
Also, there appear to be several settings you have not tried, and you have to be sure to close and restart Photoshop when you make such changes, or you might not be testing with the changed settings. Specifically, in the Performances preference dialog, press the [ Advanced ] button and try the different Drawing Modes.
-Noel
By the way, since you have newer drivers already installed, here's specific information on how to remove a newer version of ATI drivers and install 12.2:
-Noel
Thank you for your fast reply Noel,
Thanks for suggesting to try those drivers out, I had them before upgrading to v12.4 but they did not make any difference.
I did see that Advanced Settings window and it is from there I had tried to disable the OpenCL, however had not tried different Drawing Modes.
I have tried them just now on your suggestion but sadly there was no difference.
UPDATE: Here is my System Info dump.
Thank you again,
Keep the suggestions and doubts coming please, really want to fix this!
Right off the bat something seems incomplete or wrong with your display driver setup:
Video Card: Unknown Video Card Name.
Driver Version: Unknown Video Driver Version.
Video Card Driver: Unknown Video Card Driver.
Video Mode: Unknown Video Mode.
Video Card Caption: Unknown Video Card.
Video Card Memory: Unknown. MB
This is what I see, with an ATI 5670, for those same fields:
Video Card: ATI Radeon HD 5670
Driver Version: 8.950.0.0
Driver Date: 20120214000000.000000-000
Video Card Driver: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Video Mode: 1600 x 1200 x 4294967296 colors
Video Card Caption: ATI Radeon HD 5670
Video Card Memory: 1024 MB
I really would suggest trying going through the uninstall and install I noted above.
-Noel
I have no idea why that happened. I had installed new drivers but didn't retsart the computer after that. Yesterday it would have correct fields but there would have no difference.
UPDATE: I have restarted the computer and the System Info shows this:
Video Card Number: 1
Video Card: AMD Radeon HD 6700 Series
OpenCL Unavailable
Driver Version: 8.961.0.0
Driver Date: 20120405000000.000000-000
Video Card Driver:aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Video Mode: 1280 x 1024 x 4294967296 colors
Video Card Caption: AMD Radeon HD 6700 Series
But that doesn't really solve my problem
Thank you again for the help.
I really, really, really think you need to uninstall 12.4 and install 12.2. I don't know how to be more clear.
Even if it doesn't directly solve this problem, it will poise you for MUCH better stability once you do solve it.
-Noel
I have tried with 12.2 but it didn't change anything.
I can't talk about stability tough, I can not use such a slow software...
I'm using 12.2 Catalyst now:
It seems that unchecking "Use graphic processor" fixes the problem,
I also have noticed that switching between drawing modes has a certain impact on the performance. Advanced is terribly slow while Basic is just slow.
Although I do not understand why a graphic card like mine (HD 6790) would cause slowdowns in photoshop. I read of people with slower graphic cards having absolutely no lags.
I have also noticed that moving layers is slow and lagghy even with "Use Graphic Processor" unchecked.
Has anybody got any idea on how to fix this and the previous issue up?
Please.
I have the same problems as you have and my specs are:
Motherboard: Asrock Fatality P67 Performance
Cpu: Intel Core i7 2600k 3.4 Ghz
Graphic Card: Nvidia Geforce GTX 460 OC
Ram: 6.0GB
Hard Drives: 60gb intel 520 SSD - system and photoshop here
977GB Western Digital WDC WD10EAVS-00D7B1 ATA Device (IDE)
Audio: Realtek High Definition Audio
when i turn off graphic processor then it works almost fine, brush is fast and responsive and anything else on the layout
but when using liquify then the mouse keeps moving laggy until i hold down the button O.o
it's strange and i do not have these problems in CS5.
This definately says it is a graphics card/driver problem. Lifquify underwent a major change in CS6 to rely more on features of the video card. So just because it worked in CS5 means nothing.
I am sure Nvidia is working full time to update drivers to meet this new challenge. If latest driver does not work send them a bug report.
Curt,
We (Metallicfist and I) seem to have the same problem on different graphic cards (NVIDIA and AMD)
A friend of mine has a Radeon HD 6850 OC and it works fine with Catalyst 12.4
These facts make me think that it doesn't seem like a GPU driver problem.
Also, there are a sheepload of nvidia GTX 460 around, how come this is the first time I read about an user having problems like these?
I have tried to bring the clock of the GPU down to factory default but that didn't change anything.
P.S. This message makes me sound like an ass but I'm not trying to be mean, just telling my opinion on the matter. ❤️ Curt.
In CS6 they added the Mecury Grahics Engine and some features require more of the graphics card. Min VRAM is now 512 m. Here is a link http://forums.adobe.com/thread/979969
HD6790 has 1GB DDR5 RAM
GTX 460 has either 756MB or 1GB RAM
Features that require the power of mercury engine are obviously going to be slower when "use graphics processor" is unchecked. However with such graphic cards there should be no slowdown when it is checked.
There are slower graphic cards that work no problem with it, some people have our same graphic cards and have no issues whatsoever...
I believe there is something else that either doesn't work properly or is missing...
What does the GTX prefex stand for. Just had another user with graphics card problems and after 90 min. on line with Nvidia they said the GT240 was not compatable with CS6.
Beats me, all I know is that GTX 460 is faster than my HD 6790 and it is almost the top of the line on NVIDIA's 400 series...
It is a recent card. GT240 is f-old, for that one to be non compatible doesn't surprise me, even though at the bottom of the link you gave us NVIDIA series 200 is supposed to be supported by CS6's Mercury...
Is it even possible that my HD6790, which shares the same processor as an HD6870 and HD6850, is not compatible with CS6 while those 2 are?
What softwares does photoshop requires to run correctly on any W7 computer? Could it be that a third party software which is required to make PS work correctly is not working correctly or is outdated?
Do you have more than one card installed? This can cause problems.
Anti-virus can also cause problems. Temporarliy disable it and see if performace improves.
Only one (AMD 880G chipset). No antivirus at all
Here is a note from the person with the GT240.
According to NVIDIA Tech Support,on Adobe's website it tells what cards are compatible. Tech said GT240 was not and that Adobe lists the GT470 as the minimum.
Just as a spot of perspective - I'm using a Nvidia GTX 560Ti 1024Mb with the latest 301.24 driver and everything is working fine - no brush lags, CL ok.
Lucky you. Seriously.
Yup that's pretty lucky...
well my GTX 460 is a 1gb and anyway photoshop should not behave like that, i would consider it as a bug and not user hardware/software related.
i also tried to install the latest version of Geforce 301.24 driver yesterday after i wrote my first post here, but it didn't change anything. Still having the same issue :S
also GTX is just a name of a serie of graphic cards, it doesnt mean anything
Is the slowdown only affecting Liquify? Or does it also affect other GPU features like Oil Paint, Warp and Puppet Warp, canvas rotation? I have only seen Liquify slowdowns rarely and they are very hard to reproduce here. Are the slowdowns on machines with tablets attached?
Hello Jworthin,
The slowdowns, as I said earlier in my first post, happen with brush tool and when moving layers around.
It is so slow I couldn't even bring myself to test any other feature...
On a new document, A4 size 300dpi, brush tool lags incredibly much.
And I can't bring myself to believe it is caused by having a slow graphic card because this card isn't slow at all.
I have tried both, there is no difference and yes it only happens with Liquify or very soft and big brushes.
didn't notice any kind of slowdown using vanishing point, oil paint, dynamic zoom or anything else.
my brush is delayed and behind the mouse when going quick.
