Issue: I have topic with link to an MS-Excel file. When I perform an item view, the link action behaves correctly, displaying the File Download dialog box. When I generate the layout (WebHelp), the link's action doesn't respond.
Notes:
(unsure if case of filenames matters)
Any ideas?
Thank you,
-bruce.
Hi there
This is likely the result of having Mark Of The Web (MOTW) enabled while publishing and you are viewing using Microsoft Internet Explorer as your browser.
If you are planning on copying the files to a web server for your end users to open them, the links should work fine.
If you want to test from your local PC to ensure things will work, you may turn off MOTW and deal with the dialogs IE issues, or you may relax the security of IE so as to allow active content to run. Your call.
What versio
...Copy link to clipboard
Hi there
What version of IE are you using?
Cheers... Rick
Hi Captiv8r,
Thank you for your feedback.
I'm testing on IE7 and see where to relax the IE security. I tried it and the result was succesful. Then, I reactivated the security.
Tomorrow, I'll test everything on the test server to be certain. Finally, for my edification, what's the procedure for turning the MOTW on and off? I searched the Rh help and other sources but didn't find any specific procedure.
Thanks again for your help.
-bruce.
Hi Bruce
Try opening your Single Source Layouts pod (View > Pods > Single Source Layouts) and double-click your WebHelp layout. Then choose the Navigation section as shown below:
Cheers... Rick
