Hi all,
is used to be possible to call the starting page of a Webhelp and hand over the topic ID or file name of a topic using a hash.
Examples:
index.htm#123
index.htm#my_folder/my_topic.htm
Is this still supported? I recently had problems but I am not sure whether this feature was officially dropped or whether there are any other problems with the project.
Robert
Hi Robert
To my knowledge, the topic ID method you are stating was never a feature. Only the hash+PathAndFileName was.
Wondering here if you are confusing the WebHelp API method of calling Context Sensitive Help? I believe the WebHelp API method does use topic IDs, but they are called in a slightly different way. Something like this:
javascript:RH_ShowHelp(0,'HelpFolder/SomeFile.htm>SomeWindow', HH_HELP_CONTEXT, TopicIdHere)
Cheers... Rick
Hi Robert,
The method of adding a number after the # works with the csh start file. Check my overview to see all the possibilities that WebHelp supports: http://www.wvanweelden.eu/robohelp/contextsensitivity_in_webhelp
Greets,
Willam
Hi William,
yes that is what I meant. So it still works in Robohelp 9? Thanks for confirming!
@Rick Actually I really meant calling the help via the start file. You are right the API is more comfortable but some developers always prefer a plain link. Sorry for causing confusion.
Robert
#id will not work with the default start file. #filename will work. For #id you must use the XXX_csh.htm start file.
Greets,
Willam
