So I was using Premier Pro and After Effects CS6 allot because I’m in the middle of my final video for college there is allot of effects so I’ve been sending allot of the clips to after effects. They were both working really smoothly no problems and they were running very fast.
Then all of a sudden they both slowed down allot I cant even watch my project in premier pro because it is running so slow the video stutters along and the whole program is just very un responsive, also the After Effects dynamic links aren�t updating in Premier Pro.
I have a MacBook Pro 15" late 2011 core i7. I noticed they both started to go very slow after I had updated my mac but I’m not sure if this is the sole cause of Premier Pro and After Effects running slow. After a while of attempting to edit on Premier Pro and After Effects it seems to slow my whole computer down so I’m confused as to weather something has happened to my computer or if it was the latest Mac os X update or if its the software.
Anyway I really need help and I cant seem to find anyone ells having the same problem plus I’ve only got till the 12th of June to finish editing and hand the video in, so I really need help. Thank you in advanced.
I've been seeing random smatterings of posts like this. The first thing I'd ask is whether or not you have the Mercury GPU (openCL) mode enabled or not (check under your project settings). If so, does it start to behave if you flip it back to software mode?
I'm starting to suspect that a lot of the openCL issues people have been seeing on macbooks may actually be related to heat issues & GPU throttling. Apparently this is a well known thing in gaming circles. I did happen to trip across this link where someone is trying to tinker with the power management system to keep it from throttling. I don't know whether or not this applies, but I think it's potentially an interesting angle to pursue.
http://www.chromescreen.com/get-rid-of-osx-lag-and-run-your-macbook-pro-gpu-at-full-speed/
Wow yes i changed it from GPU Aceloration to just Softawre only and its running alot smoother i can actually preview my video now thank you.
I have my GTX285 set for higher fan speeds when I open Premiere to keep it from getting to hot.
It's a program that comes with the video card.
Hmm... I have a GTX 285 and do not change fan speeds
But, I have a Cooler Master Scout case, which has two (optional) case fans on the side, right over the motherboard and graphics card... so I have a LOT of air blowing onto the components
Doesn't help the OP, but I am a firm believer that more cooling fans is a good thing
Yet another case with the GPU MPE causing problems on a mac/CS6/Lion. It's adding up...
Stab in the dark: How much free space do you have on your boot disk? If less than 100 GB, free up some room for VM swaps.
I thought it might be that as well so i did free up some space I now have 233 GB free space but the issue is still there so I don't think its to do with disk space I have a feeling its a Premier Pro and Mac OSX updates battling each other witch is causing GPU problems.
Recently encountered the same issue. Found changing the 'Project Settings' under the 'File' tab worked for me as well (File->project settings->general->renderer->software only). OpenCL must be causing the GPU to work to the point of failure or something; hence the system crashes.
Feel free emailing me if you need help solving this issue: chrisalexkay@gmail.com
Hi R Mayhem,
Have you updated your GPU drivers lately? Newer drivers will no longer be supporting older CUDA cards. See my blog post: New NVIDIA drivers will no longer support older CUDA GPUs
Kevin
i have the exact question today is 9/12/2017
My Illustrator all of a sudden is lagging incredibly slow to the point i cant use it.
I have it installed on my laptop (monster 6 cores, 32 gb ram) and on my pc (6 cores, 64 gb ram)
Both are crawling. i could understand it on one machine but 2.
something is going on!!!!!!!!
