5 Replies Latest reply on Jun 6, 2012 12:05 PM by Dave LaRonde
    CS6 render time
    ctakah27
      Ladies & gentlemen, I work on a 2 y.o. top of the line imac, 16G of RAM running snow leopard. A comp takes 15 min to render in 5.5 and same comp when opened in CS6 takes 40 minutes to render (same settings - 1080, photojpeg).
      Mmmmm?
        • 1. Re: CS6 render time
          caseyinhd
          Ummm...
          Did you make sure to set your Memory settings to use the desired ammount of ram?
          Were you using different GPU settings/prefs in CS5.5?
          • 2. Re: CS6 render time
            ctakah27 Level 1
            Actually that was probably the case, I adjusted the memory settings to what I think they should be in cs6 and now the render is actually faster than in 5.5.
            Also, this is a MBP:
            if i want ae to be as fast as possible, what should i do here?
            thanks
            • 3. Re: CS6 render time
              Todd_Kopriva Level 8
              You said that you have 16GB of RAM installed, but this shows that you only have 4GB.
              • 4. Re: CS6 render time
                ctakah27 Level 1
                I am sorry about the confusion. The first post was about an Imac, and the second one is about a macbook pro... I understand that with 4GB of ram I won't be making the next prometheus movie, but it would be nice to get the most out of it...
                • 5. Re: CS6 render time
                  Dave LaRonde Level 6
                  ....and that would be to turn multiprocessing OFF, and leave it off.  In AE terms, 4 gigs is enough to run the operating system and AE alone.  It doesn't get you efficient use of multiprocessing, but it does give you headaches if you try to use multiprocessing.
