I would like to provide my users with additional information through Tool tips which work inconsistently for me. If I want a cell in a Table that either requires no input or displays a value from another cell or displays the results of a calculation cell what do I have to do? I select the Accessibility tab, add a tool tip text and then have tried all sorts of combinations of selections for the Screen Reader Precedences - tool tip, custom text, name, none. The cells range from protected to calculated- read only, text, text fields and numeric fields.
Any suggestions?
Tucson102
Total Likes
Tool tips are a function of accessibility to support screen readers and follow accessibility guidelines, for example, Section 508 in the U.S. If a field does not have to be filled I believe the general accessibility practice is too exclude the field from a screen reader. Thus, fields that are not "user entered" do not generate tool tips.
Here's what I have done in the past. The question mark icon is an image field with a button laid over top. The button has no visual properties.
When you hover over the image you get a tool tip.
When you click the button you get help using xfa.host.messageBox.
The script on the button is as follows:
// form1.page1.helpBtn::click - (JavaScript, client)
var msg = "Please complete the table by..." + "\n"
+ "and then..." + "\n"
+ "to complete." + "\n";
xfa.host.messageBox(msg,"Table Help",2);
Total Likes
With a little experimenting, this works nicely. Thank you. Christina
Total Likes
Ya this is quite a nice idea but the drawback is: "Warning: JavaScript Window" appears in all the alert boxes. Is there a a way to hide that text? Do keep me posted. Thanks!
Total Likes
Hi Balaji,
Please see the below mentioned thread. It would help
Total Likes
Thanks very much for your reply. It works nicely.
Balaji
Total Likes
