19 Replies Latest reply on Oct 22, 2012 10:40 AM by Hudechrome
    Memory and performance
    community help Level 1
      This question was posted in response to the following article: http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e41001031ab64-748aa.h tml
        • 1. Re:  Memory and performance
          rickwsmith@att.net
          I am currently using a GE Force GTX 589 video card with CS5. I have updated the video drivers to the latest version but am still unable to "Enable OpenGL Drawing" When I do a shiftctlalt to "Delete the Adobe Photoshop Settings File"  the "Enable OpenGL Drawing" box is checked and everything looks fine. However when I close the CS5 and reopen it the "Enable OpenGL Drawing" box is unchecked and turned off. Anyone have any suggestions to this issue?
          • 2. Re:  Memory and performance
            Level 5
            Sounds like the "GPU Sniffer" is crashing, as it's supposed to.
            Read more about it here:
            http://forums.adobe.com/message/4289204
            The GPU Sniffer
            To help guard against Photoshop crashes related to bad GPU hardware or drivers, Photoshop employs a small program called the GPU Sniffer. Every time Photoshop is launched, Photoshop launches the sniffer. The sniffer runs rudimentary tests of the GPU and reports the results to Photoshop. If the sniffer crashes or reports a failure status to Photoshop, Photoshop will not use the GPU. The Use Graphics Hardware checkbox in the Performance panel of the Preferences will be unchecked and disabled.
            The first time the sniffer fails, Photoshop will display a dialog indicating that it has detected a problem with the GPU. On subsequent launches the dialog will not appear unless the Photoshop preferences are reset.
            If the user corrects the problem, either by replacing the video card or by updating the driver, then the sniffer will pass on the next launch and the Use Graphics Hardware checkbox will be enabled and returned to its previous state (enabled or disabled).
            [emphasis added]
            • 3. Re:  Memory and performance
              PECourtejoie Adobe Community Professional
              Hello, it seems that either the video card, or rather its drivers are not supported.
              Could you post the contents of help>system info (remove your serial number) so that we can see what is the driver version?
              Or better, try to update your Graphic card drivers.
              • 4. Re:  Memory and performance
                rickwsmith@att.net Level 1
                Adobe Photoshop Version: 12.0.4 (12.0.4x20110407 ) x64
                Operating System: Windows 7 64-bit
                Version: 6.1 Service Pack 1
                System architecture: Intel CPU Family:6, Model:12, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
                Physical processor count: 12
                Processor speed: 3381 MHz
                Built-in memory: 24567 MB
                Free memory: 19681 MB
                Memory available to Photoshop: 22199 MB
                Memory used by Photoshop: 70 %
                Image tile size: 128K
                Image cache levels: 4
                OpenGL Drawing: Enabled.
                OpenGL Drawing Mode: Basic
                OpenGL Allow Normal Mode: False.
                OpenGL Allow Advanced Mode: False.
                OpenGL Crash File: Not Detected.
                OpenGL Allow Old GPUs: Not Detected.
                Video Card Vendor: NVIDIA Corporation
                Video Card Renderer: GeForce GTX 580/PCIe/SSE2
                Display: 1
                Display Bounds:=  top: 0, left: 0, bottom: 1080, right: 1920
                Video Card Number: 1
                Video Card: LogMeIn Mirror Driver
                Driver Version: 7.1.542.0
                Driver Date: 20060522000000.000000-000
                Video Card Driver:
                Video Mode: 1920 x 1080 x 4294967296 colors
                Video Card Caption: LogMeIn Mirror Driver
                Video Card Memory: 1536 MB
                Video Card Driver:
                Video Card Memory: ^0 MB
                Serial number:
                Application folder: C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\
                Temporary file path: C:\Users\RICK\AppData\Local\Temp\
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  H:\, 93.2G, 92.2G free
                Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Plug-ins\
                Additional Plug-ins folder: not set
                Installed components:
                   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                   ACE.dll   ACE 2010/10/04-23:36:11   64.441628   64.441628
                   adbeape.dll   Adobe APE 2010/02/23-12:40:58   61.421986   61.421986
                   AdobeLinguistic.dll   Adobe Linguisitc Library   5.0.0
                   AdobeOwl.dll   Adobe Owl 2010/06/03-13:43:23   3.0.93   61.433187
                   AdobeOwlCanvas.dll   Adobe Owl Canvas   3.0.68   61.2954
                   AdobePDFL.dll   PDFL 2010/12/13-23:37:10   64.341419   64.341419
                   AdobePIP.dll   Adobe Product Improvement Program   5.0.0.2021
                   AdobeXMP.dll   Adobe XMP Core   5.0   61.134777
                   AdobeXMPFiles.dll   Adobe XMP Files   5.0   61.134777
                   AdobeXMPScript.dll   Adobe XMP Script   5.0   61.134777
                   adobe_caps.dll   Adobe CAPS   3,0,116,0
                   adobe_OOBE_Launcher.dll   Adobe OOBE Launcher   1.0.0.64 (BuildVersion: 1.0; BuildDate: Mon Jan 26 2010 21:49:00)   1.000000
                   AFlame.dll   AFlame 2010/02/23-17:27:33   61.421976   61.421976
                   AFlamingo.dll   AFlamingo 2010/02/23-17:27:33   61.421978   61.421978
                   AGM.dll   AGM 2010/10/04-23:36:11   64.441628   64.441628
                   ahclient.dll    AdobeHelp Dynamic Link Library   1,5,0,30
                   aif_core.dll   AIF   2.0   53.422628
                   aif_ogl.dll   AIF   2.0   53.422628
                   amtlib.dll   AMTLib (64 Bit)   3.0.0.64 (BuildVersion: 3.0; BuildDate:  Mon Jan 26 2010 21:49:00)   1.000000
                   amtservices.dll   AMTServices (64 Bit)   3.0.0.64 (BuildVersion: 3.0; BuildDate:  Mon Jan 26 2010 21:49:00)   1.000000
                   ARE.dll   ARE 2010/10/04-23:36:11   64.441628   64.441628
                   asneu.dll    AsnEndUser Dynamic Link Library   1, 7, 0, 1
                   AXE8SharedExpat.dll   AXE8SharedExpat 2010/02/23-17:27:33   61.421978   61.421978
                   AXEDOMCore.dll   AXEDOMCore 2010/02/23-17:27:33   61.421978   61.421978
                   Bib.dll   BIB 2010/10/04-23:36:11   64.441628   64.441628
                   BIBUtils.dll   BIBUtils 2010/10/04-23:36:11   64.441628   64.441628
                   boost_threads.dll   DVA Product   5.0.0
                   cg.dll   NVIDIA Cg Runtime   2.0.0015
                   cgGL.dll   NVIDIA Cg Runtime   2.0.0015
                   CoolType.dll   CoolType 2010/10/04-23:36:11   64.441628   64.441628
                   data_flow.dll   AIF   2.0   53.422628
                   dvaadameve.dll   DVA Product   5.0.0
                   dvacore.dll   DVA Product   5.0.0
                   dvaui.dll   DVA Product   5.0.0
                   ExtendScript.dll   ExtendScript 2010/10/19-10:22:12   61.445301   61.445301
                   FileInfo.dll   Adobe XMP FileInfo   5.0   61.134777
                   icucnv36.dll   International Components for Unicode 2009/06/17-13:21:03    Build gtlib_main.9896
                   icudt36.dll   International Components for Unicode 2009/06/17-13:21:03    Build gtlib_main.9896
                   icudt42.dll   International Components for Unicode   4, 2, 0, 0
                   icuin42.dll   International Components for Unicode   4, 2, 0, 0
                   icuuc42.dll   International Components for Unicode   4, 2, 0, 0
                   image_flow.dll   AIF   2.0   53.422628
                   image_runtime.dll   AIF   2.0   53.422628
                   JP2KLib.dll   JP2KLib 2010/12/13-23:37:10   64.181312   64.181312
                   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
                   LogSession.dll   LogSession   2, 0, 1, 11
                   MPS.dll   MPS 2010/12/13-23:37:10   64.450375   64.450375
                   msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                   msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.6161
                   msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                   msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.6161
                   msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                   msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.6161
                   onOneActivationToolbox.dll   onOneActivationToolbox   1.1
                   onOneToolbox2.dll   onOne Toolbox2 Dynamic Link Library   2.2.0
                   onOneToolboxPlus.dll   onOne Toolbox2 Dynamic Link Library   2.2.0
                   onOneWelcomeDialog.dll   Essentials   1.0.0.1
                   OnOneWidgets.dll    OnOneWidgets dll   2.5
                   ONProxySupport.dll   TODO:    1.0.0.1
                   pdfsettings.dll   Adobe PDFSettings   1.04
                   Photoshop.dll   Adobe Photoshop CS5   CS5
                   Plugin.dll   Adobe Photoshop CS5   CS5
                   PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   2.0.0.746
                   PSArt.dll   Adobe Photoshop CS5   CS5
                   PSViews.dll   Adobe Photoshop CS5   CS5
                   SCCore.dll   ScCore 2010/10/19-10:22:12   61.445301   61.445301
                   tbb.dll   Threading Building Blocks   2, 1, 2009, 0201
                   TfFontMgr.dll   FontMgr   9.3.0.113
                   TfKernel.dll   Kernel   9.3.0.113
                   TFKGEOM.dll   Kernel Geom   9.3.0.113
                   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                   updaternotifications.dll   Adobe Updater Notifications Library   1.0.0.68 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   1.0.0.68
                   WRServices.dll   WRServices Thursday January 21 2010 12:13:3   Build 0.11423   0.11423
                   wu3d.dll   U3D Writer   9.3.0.113
                   zlib.dll   zlib   1.2.5
                Installed plug-ins:
                   3D Studio 12.0.4 (12.0.4x20110407 )
                   Accented Edges 12.0
                   ADM 3.11x01
                   Angled Strokes 12.0
                   Average 12.0.4 (12.0.4x20110407 )
                   BackgroundFilter NO VERSION
                   Bas Relief 12.0
                   BMP 12.0.2
                   Camera Raw 6.7
                   Chalk & Charcoal 12.0
                   Charcoal 12.0
                   Chrome 12.0
                   Cineon 12.0.4 (12.0.4x20110407 )
                   Clouds 12.0.4 (12.0.4x20110407 )
                   Collada 12.0.4 (12.0.4x20110407 )
                   Color Efex Pro 4 NO VERSION
                   Color Halftone 12.0.2
                   Colored Pencil 12.0
                   CompuServe GIF 12.0.2
                   Conté Crayon 12.0
                   Craquelure 12.0
                   Crop and Straighten Photos 12.0.4 (12.0.4x20110407 )
                   Crop and Straighten Photos Filter 12.0.2
                   Crosshatch 12.0
                   Crystallize 12.0.2
                   Cutout 12.0
                   Dark Strokes 12.0
                   De-Interlace 12.0.2
                   Dfine 2.0 NO VERSION
                   Dicom 12.0
                   Difference Clouds 12.0.4 (12.0.4x20110407 )
                   Diffuse Glow 12.0
                   Displace 12.0.2
                   Dry Brush 12.0
                   Eazel Acquire 12.0.4 (12.0.4x20110407 )
                   Embed Watermark 4.0
                   Entropy 12.0.4 (12.0.4x20110407 )
                   Extrude 12.0.2
                   FastCore Routines 12.0.4 (12.0.4x20110407 )
                   Fibers 12.0.2
                   Film Grain 12.0
                   Filter Forge 3 3.007.23938.8402 Release, March 19, 2012 12:21
                   Filter Gallery 12.0
                   FineStructuresFilter NO VERSION
                   Fluid Mask 3 3.2.3.8537
                   FocalPoint 2 2.0.9b (Suite 6.1)
                   FocalPoint 2 Filter 2.0.9b (Suite 6.1)
                   FocalPoint 2 Hidden NO VERSION
                   FreePack 1 - Metals 2.009.19529.39970 FreePack1-Release, January 26, 2011 14:03
                   FreePack 2 - Photo Effects 2.009.19530.41074 FreePack2-Release, January 26, 2011 14:39
                   FreePack 3 - Frames 2.009.19530.42402 FreePack3-Release, January 26, 2011 15:24
                   FreePack 4 - Distortions 2.009.19530.43506 FreePack4-Release, January 26, 2011 16:00
                   FreePack 5 - Hearts 2.009.19665.7266 FreePack5-Release, February 08, 2011 11:33
                   FreePack 6 - Patterns 2.009.19653.23330 FreePack6-Release, February 07, 2011 08:04
                   Fresco 12.0
                   Glass 12.0
                   Glowing Edges 12.0
                   Google Earth 4 12.0.4 (12.0.4x20110407 )
                   Grain 12.0
                   Graphic Pen 12.0
                   Halftone Pattern 12.0
                   HDR Efex Pro 1,203
                   HDR Efex Pro Metadata 1,203
                   HDRMergeUI 12.0
                   HotPixelsFilter NO VERSION
                   IFF Format 12.0.2
                   Imacon 3f NO VERSION
                   Ink Outlines 12.0
                   JPEG 2000 2.0
                   Kurtosis 12.0.4 (12.0.4x20110407 )
                   Lens Blur 12.0
                   Lens Correction 12.0.2
                   Lens Flare 12.0.2
                   Lighting Effects 12.0.4 (12.0.4x20110407 )
                   Liquify 12.0.1
                   Matlab Operation 12.0.4 (12.0.4x20110407 )
                   Maximum 12.0.4 (12.0.4x20110407 )
                   Mean 12.0.4 (12.0.4x20110407 )
                   Measurement Core 12.0.4 (12.0.4x20110407 )
                   Median 12.0.4 (12.0.4x20110407 )
                   Merge to HDR Efex Pro 1,203
                   Mezzotint 12.0.2
                   Minimum 12.0.4 (12.0.4x20110407 )
                   MMXCore Routines 12.0.4 (12.0.4x20110407 )
                   Mosaic Tiles 12.0
                   Multiprocessor Support 12.0.4 (12.0.4x20110407 )
                   Neon Glow 12.0
                   Nik Selective Tool 2.1.3.17710
                   Note Paper 12.0
                   NTSC Colors 12.0.4 (12.0.4x20110407 )
                   Ocean Ripple 12.0
                   OpenEXR 12.0.2
                   Paint Daubs 12.0
                   Palette Knife 12.0
                   Patchwork 12.0
                   Paths to Illustrator 12.0.2
                   PCX 12.0.4 (12.0.4x20110407 )
                   Perfect Effects 6.1
                   Perfect Effects Filter 6.1
                   Perfect Effects Smart Filter 6.1
                   Perfect Mask 6.1
                   Perfect Mask Filter 6.1
                   Perfect Mask Smart Filter 6.1
                   Perfect Portrait 6.1
                   Perfect Portrait Filter 6.1
                   Perfect Portrait Smart Filter 6.1
                   Perfect Resize 7.0 Professional Edition 7.0.7 (Suite 6.1)
                   Perfect Resize 7.0 Professional Edition Batch 7.0.7 (Suite 6.1)
                   Perfect Resize 7.0 Professional Edition Filter 6.1
                   Perfect Resize 7.0 Professional Edition Format 7.0.7 (Suite 6.1)
                   Photocopy 12.0
                   PhotoFrame 4.6 Professional Edition 4.6.6
                   PhotoFrame 4.6 Professional Edition Batch 4.6.6
                   PhotoFrame 4.6 Professional Edition Hidden 4.6.6
                   Photoshop 3D Engine 12.0.4 (12.0.4x20110407 )
                   Picture Package Filter 12.0.4 (12.0.4x20110407 )
                   Pinch 12.0.2
                   Pixar 12.0.4 (12.0.4x20110407 )
                   Plaster 12.0
                   Plastic Wrap 12.0
                   PNG 12.0.2
                   Pointillize 12.0.2
                   Polar Coordinates 12.0.2
                   Portable Bit Map 12.0.4 (12.0.4x20110407 )
                   Poster Edges 12.0
                   Radial Blur 12.0.2
                   Radiance 12.0.4 (12.0.4x20110407 )
                   Range 12.0.4 (12.0.4x20110407 )
                   Read Watermark 4.0
                   Reticulation 12.0
                   Ripple 12.0.2
                   Rough Pastels 12.0
                   Save for Web & Devices 12.0
                   ScriptingSupport 12.0.4
                   search 3DVIA 10.0
                   ShadowsFilter NO VERSION
                   Sharpener Pro 3.0: (1) RAW Presharpener 3.0.8.17631
                   Sharpener Pro 3.0: (2) Output Sharpener 3.0.8.17631
                   Shear 12.0.2
                   Silver Efex Pro 2 2,004
                   Skewness 12.0.4 (12.0.4x20110407 )
                   SkinFilter NO VERSION
                   SkyFilter NO VERSION
                   Smart Blur 12.0.2
                   Smudge Stick 12.0
                   Solarize 12.0.4 (12.0.4x20110407 )
                   Spatter 12.0
                   Spherize 12.0.2
                   Sponge 12.0
                   Sprayed Strokes 12.0
                   Stained Glass 12.0
                   Stamp 12.0
                   Standard Deviation 12.0.4 (12.0.4x20110407 )
                   StarFilter Pro 2 2.0.4.1
                   StarSpikes Pro 1, 3, 3, 0
                   StrongNoiseFilter NO VERSION
                   Sumi-e 12.0
                   Summation 12.0.4 (12.0.4x20110407 )
                   Targa 12.0.2
                   Texturizer 12.0
                   Tiles 12.0.2
                   Topaz Adjust 5 10.0
                   Topaz BW Effects 10.0
                   Topaz Clean 3 10.0
                   Topaz DeJpeg 4 10.0
                   Topaz DeNoise 5 10.0
                   Topaz Detail 2 10.0
                   Topaz InFocus 10.0
                   Topaz Lens Effects 10.0
                   Topaz photoFXlab 10.0
                   Topaz ReMask 3 10.0
                   Topaz Simplify 3 10.0
                   Topaz Star Effects 10.0
                   TopazRemaskAutomate NO VERSION
                   Torn Edges 12.0
                   Twirl 12.0.2
                   U3D 12.0.4 (12.0.4x20110407 )
                   Underpainting 12.0
                   Vanishing Point 12.0
                   Variance 12.0.4 (12.0.4x20110407 )
                   Variations 12.0.4 (12.0.4x20110407 )
                   Viveza 2 2.0.7.17631
                   Water Paper 12.0
                   Watercolor 12.0
                   Wave 12.0.2
                   Wavefront|OBJ 12.0.4 (12.0.4x20110407 )
                   WIA Support 12.0.4 (12.0.4x20110407 )
                   Wind 12.0.2
                   Wireless Bitmap 12.0.4 (12.0.4x20110407 )
                   ZigZag 12.0.2
                Plug-ins that failed to load: NONE
                Flash: 0
                Installed TWAIN devices: NONE
                • 5. Re:  Memory and performance
                  Bob Rickert Level 1
                  Has Adobe addressed the optimum set-up for Photoshop CS6 and Lightroom V4 when they are used together?  I have less problems with slowness and crashes when I run either program on its own but when I have them both open the system really slows down.
                  • 6. Re:  Memory and performance
                    Noel Carboni Level 8
                    Optimum?  How do you define that?
                    In general, at any given time you need next year's computer model, maxed-out with the best possible hardware resources.
                    -Noel
                    • 7. Re:  Memory and performance
                      DragonKoko94
                      hey , i have Photoshop cs6 and i have a video card of 2GB (nvidia gt 6450) and a 16GB RAM and i7 processor (3.4MHz) and i have the latest version of my drivers and i also ensured that " use graphic processor " sign is checked and use " OpenGl " , yet when i press create in the 3D panel it tells me " the 3D feature require that " use graphic processor is enabled " in performance preference . your video card must meet the requirements and you may need to check that your driver is running correctly ."
                      so what should i do to enable this feature
                      N.B. : when i press the 3D button in the type tool panel it changes the text into 3D but i cant rotate or move it
                      and it opens some 3d files i have easily with no problems
                      • 8. Re:  Memory and performance
                        I cannot find any reference to a "nvidia gt 6450".  I suspect you've either made a typo or confused two different brands.
                        What version of display driver do you have, specifically.
                        You can find this information in the Photoshop Help - System Info display.
                        -Noel
                        • 9. Re:  Memory and performance
                          clemsquicktrip
                          I am building a new PC for PS CS6. I have  been getting some feedback on a couple forums that seems to contradict what I have read here.  "For best performance, scratch disks should be on a different drive than any large files you are editing." Also, "Scratch disks should be on a different drive than the one your operating system uses for virtual memory.
                          I have assumed from these statments (and other sources on the web) that a separate drive or partition is best for a scratch disk. I had, therefore, planned on dedicating small SSD (64 GB) as a scratch disk and a larger SSD (256 GB) as a system disk (OS and apps).  Responses to this arrangement have been negative.  It was suggested that a 64 GB SSD is  too small to be effective (small drive = slow read/wtrite times), Windows likes to run everthing off C drive and I should stripe two  256 GB SSDs in Raid 0 and point every thing towards C drive.
                          So now I am confused.  What am I missing?
                          • 10. Re:  Memory and performance
                            Curt Y Level 7
                            The advice to have a seperate scratch disk is based on physics.  A HD only has one read/write head.  So it can not be in two spots at the same time.  This makes a partition no better than nothing.  So you want seperate disk drives so the program can be reading on one and the scratch can be writing on the other at the same time.
                            Since an SSD does not have a read/write head the above does not apply, and you can have everything on the same drive if large enough.  Since the SSD is like a large flash drive the read/write times are extremely fast.
                            The size of your scratch disk needed depends on what type of editing you do and the size of the file.  One  suggestion is to have the scratch disk 100 times larger than your largest file.
                            If you do not do anything too serious 64 gig might work, but you would be cutting it close.
                            • 11. Re:  Memory and performance
                              Lundberg02 Level 3
                              I don't know where you get the idea that flash drives are fast. Do you own one?
                              My 64GB Sandisk is glacially slow even compared to USB 2. About the same speed as a cable modem.  As Chris said in another thread, huge RAM is the future. I can remember an old PC with I think DOS 5 that had enough memory to make a RAM disk big enough to be useful.  For the 90s that was really really fast.
                              Apps are so damn big now that my measly 8Gb couldn't support the OS and a RAM disk. If I put in another 8 GB, maybe. My next box if I ever get one will have 64 or 128.
                              • 12. Re:  Memory and performance
                                Level 7
                                Not huge RAM - huge non-volatile memory.
                                SSDs are flash based, and use an SATA or PCIE interface.
                                The non-volatile memory will get faster, and the interface will change to get out of the way.
                                Maybe if it's fast and cheap enough, the new non-volatile memory will replace RAM.
                                • 13. Re:  Memory and performance
                                  It's an important point to note that the controller in an SSD isn't by any means simple; it's almost more like a file server attached with a networking (SATA) connection vs. a disk drive, which is traditionally kind of dumb and just does what the computer tells it to.  This is necessary in part to conform to the existing legacy SATA protocol, and also to manage the different nature of flash memory (i.e,. that a block has to be erased before being written-to, and that erasure takes a loooong time, not to mention wear leveling).
                                  -Noel
                                  • 14. Re:  Memory and performance
                                    Hudechrome Level 2
                                    If one is planning to put scratch on an HD and situations dictate combining scratch with a storage drive then absolutely partition and put the scratch first. An HDD reads like an LP record, starting at the outside edge. It also runs at a steady RPM, like an LP. Therefore the speediest read/write will be at the beginning (as any test of an HDD confirms). The partition is advised to keep scratch free of fragmenting, which does become a factor if scratch is merely part of an overall disk.
                                    If the 64G too small is based on an SSD, then I see the logic. But for an HDD scratch, I run just under 40G and have jet to use 1/2 of that. My files can exceed 1.5G
                                    • 15. Re:  Memory and performance
                                      NO!   I would say do not partition a drive.
                                      Partitioning it virtually GUARANTEES inefficiency as the head has to seek back and forth to access things on the different partitions, and seeking is bad.  Are you postulating that the increased data rate because the data is on the outside edge of the drive overcomes the seek overhead under some conditions (e.g., if no other data is accessed on the other partition simultaneously)?
                                      Also, pooling the free space seems better than forcing a limit, in exceptional circumstances where Photoshop wants to create a truly huge scratch file.
                                      Why would you want to separate a scratch volume from other data on the drive?  The one thing I've not seen Photoshop do is corrupt a scratch drive.
                                      -Noel
                                      • 16. Re:  Memory and performance
                                        Curt Y Level 7
                                        The theory is that a partiton for a scratch drive will reduce fragmentation on the drive, due to the constant read/write by confining it to one partition.  Not sure there is any science there, as many have the scratch on C and don't see any problems.
                                        • 17. Re:  Memory and performance
                                          Hudechrome Level 2
                                          Scratch is on a physical drive I use for legacy storage. If a file on that drive is called up for editing, it is moved to the Edit drive, which has only one partition. I am cognizant of the drive seek problems, which is why I do what I do. After all, there are only so many sata connections as well.
                                          So there is no simultaneous seek functions going on at least over 90% of the time. What's to seek from long term storage?
                                          • 18. Re:  Memory and performance
                                            Windows has been defragging its own drives automatically on Wednesday morning for years now.
                                            -Noel
                                            • 19. Re:  Memory and performance
                                              Hudechrome Level 2
                                              Of course, quitting PS "should" delete the file and therefore, defrag is not needed. Certainly, if one leaves PS on and the drive builds up fragmentation can set in. So far, it hasn't been an issue here. Works nicely.
