I have a condition integer for conditional text that is applied to text. How do I convert the integer to a Condition Format object? Thanks in advance.
Rick Quatro
Hi Rick,
I would try looping through the CondFmt objects in the document and see if you can match their id property to the condition integer you found for yout text.
Good luck
Jang
Rick,
It appears that Jang's idea is the general solution to converting an FDK object handle integer to an ES object. I imaging you were probably following this thread already, but this was the general answer to the same question about a document object.
http://forums.adobe.com/message/4476098
Russ
