hi,
I was just about to ask this question, glad this has been answered. However, in my project I need to add multiple instance of the class from library dynamically, I know how to do it in AS2 way, can anyone elighten me with AS3 way, specifically with this new addchild(movieclip) function?
thanks!
First check whether you gave the instance name for the button as "mc" in your myMovieClip.
Then write your code same
myMovieClip.mc.addEventListener(MouseEvent.MOUSE_DOWN,showans); // You can write CLICK event also...
In showans, You have to write like this.
function showans(e:MouseEvent):void
e.currentTarget.parent.atext.visible = true;
Can you paste your code here.
Kartik.
import flash.display.MovieClip;
for (var i:int=0; i<12; i++) {
// accessing the mc from libray here qmc is linkage name
myMovieClip = new qmc();
myMovieClip.x=stage.stageWidth/10;
myMovieClip.y=stage.stageHeight/3;
addChild(myMovieClip);
i think all 12 mc are loading in same place, i want to display the mc one by one
You can use it in following way :-
var myMovieClip:qmc = new qmc();// accessing the mc from libray here qmc is linkage name
myMovieClip.x=stage.stageWidth/10;//assigning x property
myMovieClip.y=stage.stageHeight/3;//assigning y property
addChild(myMovieClip);//adding to stage
Sorry am not finding any difference it is showing the same output
What kind of output you want?
As i have seen your code you are doing it correct apart from the line 1 in for loop which i have corrected.
Kartik.
hi i got the solution for my problem. it is worlking fine.
But i got another problem i don't know how to control the each mc.I want to perform different action with those mc.
for (var i:int=1; i<(len+1); i++) {
if (i==1) {
var yval:int=stage.stageHeight/3;
} else {
yval=yval+myMovieClip.height+5;
myMovieClip.y=yval+10;
myMovieClip.qtext.text=i+". "+ques_arr[i-1];
myMovieClip.atext.autoSize="center"
myMovieClip.atext.text=ans_arr[i-1];
myMovieClip.atext.visible=false;
// here is the problem
Hello,
Please try the below mentioned code :-
if (i==1) {
} else {
myMovieClip.name = "mc"+i // adding name to movieclip
trace(e.currentTarget.name)//here you will get the name of movieclip you have defined above here you can put a condition check. output will be like "mc1" "mc2" ...
//here you can write your code to handle different movieclip events
This program is not working, when i trace e.currentTarget.name am getting the output as mc, can you please give me another solution.I think problem with for loop
Because when i press any of the mc the out put is coming as mc4
Can you please change this line myMovieClip.mc.addEventListener(MouseEvent.MOUSE_DOWN,showans); to myMovieClip.addEventListener(MouseEvent.MOUSE_DOWN,showans); and try again.
Sorry it is not working
Please explain the problem clearly. I have some doubts, What do you mean by mc? Whether it is myMovieClip or something else. And different action means for each mc you want to create a seperate action right?
mc is instance of name one button it is there inside the myMovieClip.
For the my myMovieClip when i gave the different name like this myMovieClip.name = "mc"+i
am getting the myMovieClip name as mc1 ,mc2,mc3,mc4
I want to perform one action when i press mc1.mc the myMovieClip.atext should be visible true like wise for mc2..
But it is not happening
Thanks Its working fine
You are welcome.
Please mark at the answer as Correct Answer.
