Here is the thread on the old forum that wasn't moved across..
How do we get rid of the Destination State dropdown?
Australia doesn't even have state taxes and this option is messy and confusing.
Would love to hear if anyone was able to remove this
You can't do that if you're selling to different countries. Instead you need to create NSW, VIC, SA etc. as Tax Codes with 10% tax, so that the 10% tax is applied for customers buying from AU and not applied for those outside AU.
Cheers,
mario
Cheers,
mario
mario, you must be geting sick of having that same question asked al the time. I se it everywhere, I continue to ask it. Is there a roadmap to improve that dropdown menu situation?
cheers - billy
Hi Billy,
I had a look at the roadmap but I can't see this there. That said, I will email the product management and ask them if the tax framework can be improved.
Cheers,
-mario
I think i've found a BC site that has done this Yaye... http://gthloungewear.businesscatalyst.com/OrderRetrievev2.aspx
But does anyone know HOW they did it??
Far out, it does look like they have done it. Mario can you reverse engineer that site for us to find out whats happening and if it some thing that will help out in this area?
I second that... Pretty please Mario
I think they did that by not using GST as a tax code. So they have included GST in the product price and not used the system to calculate it.
We had the same problem here and the only solution was to do what Mario said as we needed to use the system to add GST for invoicing purposes.
Yes please change this...or at the very least have it read Province/State
Those guys don't have any tax codes. If they did you'd see the states in the dropdown.
@river east - you nee to use JS to chnage the text there.
Cheers,
-mario
Are you talking about the alert if the shipping option is not choosen as described here http://forums.adobe.com/docs/DOC-1808 (which I have done) or is there away to change the on page Destination State above the dropdown ? I just need it to say Choose Province if so please let me know how to accomplish this. I am not a JS guru by any means.
Appreciate it, Thanks
You'd need to jQuery to targed that text with something like $('#shippingStateSpan').text("Destination Province");
See http://api.jquery.com/text/ for code examples and more options.
Cheers,
-m
I'm strickly a look and feel developer. Part of the draw of Business Catalyst was not having to code anything but I will give it a shot.
It's just so messy. So many people get confused and confusion results in NO sale!
I thought BC was started in Australia so the developers must be aware of this issue.
It's just sad that there is no ability to hide that confusing second dropdown. If you are an Australia supplier you charge 10% GST to local customers and do not charge GST to overseas - simple.
I have a customer asking for this same feature, removing destination state, and though it appears it can not be removed I found this site featured on the AdobeTV system that did remove it (see below). Any thoughts on how that is possible? My client is in the US, and would prefer that tax be applied when someone enters their information on the checkout page - so we can remove the Destination State on the cart page. Thanks!
www.bogsfootwear.com
You can remove the state dropdown by changing {tag_shippingoptions,true} to {tag_shippingoptions}, but there's no way to apply the tax on the registration page.
-m
I'm sorry, I might have misread above because I thought that if the client was selling to different counries the state drop down could not be removed. This client will be selling to Canada, US, UK and Australia. Does that create a potential problem?
The following are some details I copied out of the old onlinebusinessWiki which was so full of good stuff that has now been lost...
Shipping option details
Monday, 20 July 2009
5:43 PM
To change how Shipping options are presented / displayed - The definitive answer....
Through CSS styling and some javascript it is possible to change which elements are displayed and to change the label text associated with each of the elements
To turn display of any element off you include <style> code at the beginning of your shopping cart template. The elements (NOTE: the names are case sensitive !) that can be turned off are:
shippingCountry (the drop down field listing you country(s))
shippingCountrySpan (The label for the country drop down field)
shippingSpan
ShippingOptions
shippingState
shippingStateSpan
Example of achieving this is shown below
<style>
#shippingCountry {display:none;}
#shippingCountrySpan {display:none;}
#shippingSpan {display:none;}
</style>
To change the value of the label associated with each element you place the following javascript code at the end of your layout selecting the relevant element being
shippingCountrySpan
shippingSpan
shippinStateSpan
Example of how I changed the lebel on the Destination State to choose type of GST in Australia is
</script>
<script type="text/javascript">
</script>
Replacing Shipping options with custom text
var sel = document.getElementById('ShippingOptions')
for(var i=sel.options.length-1;i>=0;i--)
if(sel.options.value == "-1")
sel.options.text = "Here goes the text of whatever you want to replace Choose Shipping Options to";
</script>
Auto-Selecting one Shipping Option
Needs to be added to the Check Out Layout -
var shippingOptions = document.getElementById('ShippingOptions');
if (shippingOptions) {
shippingOptions.selectedIndex = 1;
shippingOptions.onchange();
</script>
I hope this is still relevant and helpful....
If you want to see this implimented go to www.blackandblue.com.au - we set up a single tax code called GST and have hiddent this DIV per above after presetting the shippingState to the 1st (and only) choice.
In the shopping cart layout we used the following... {tag_shippingoptions,true,true,AU;NZ;US} to limit our shipping to just AU, NZ and USA at present. We have shipping rates set up for the 3 different zones.
The end result is that the shopping cart only applies GST if the buyer is is Aust and then only asks for shipping rates in NZ or US and at no time do we ask for a State or GST code.
Hi Greg,
Thank you for this post.
I was able to get the 'Select State' to disappear by inserting
<style>
#shippingStateSpan {display:none;}
</style>
into the <head></head> area of my Cart Template.
I am unable to get the new text to display.
Do I place the js code into the <head></head> area of the Cart Template (after the <style> tag used above)?
Or do I go into Module Templates - Online Shop Layouts - Shopping Cart?
Is the code correct? (I was going to replace Select GST type with 'Select Province' and I'm guessing the words I insert can be anything I choose).
document.getElementById('shippingStateSpan').innerHTML = 'Select GST type';
</script>
I've tried this a few places but I must be doing something wrong.
Thank you for your help,
Tricia
Any update on this?
I desperately need to be able to remove the destination state dropdown as it is confusing and my client does not understand why it is there (it is very hard to reason when I don't understand either!).
I can easily hide the field but I need to be able to use javascript to auto populate if Australia is selected as tax needs to be applied.
Can anyone please help with this?
Madeleine
Hi Suppor team,
Are you able to provide an update on this?
I was told by one of your support team members that someone in the Dev team would be able to post a solution in the forum.
It would be great if you could get back to me ASAP as this is really important to my client.
Madeleine
HI Madeleine and everyone else
Did anyone ever have any luck with this? (remove destination state so tax is on for local orders and not charged for international?)
DD
Nope I never heard back from BC or anyone in the community.
Fingers crossed we can get a solution
Hi everyone,
Has there been any improvement in this 1 and a half years later??
Also on another note if you do use the {tag_shippingoptions,true} and asign the products with tax not applicable so it only shows on the shopping cart... then if you edit/add to the order in admin or even create an order in Admin then you will not be able to add any tax... i'm pulling my hair out over this as it breaches tax laws and causes a world of problems. I've posted another forum question on this but if anyone has any advice I'd love to know as we really don't want the tax office after us!
DandyDahlia, I am here simple to back you up. This has been going for more than 1.5 years I can assure you. I can only hope that BC recognise forum threads that get a lot of attention... and fix the issues therein.
Adobe BC has a track record of taking about 5 years to address anything seriously. Before Adobe, the team at BC listened to Partners, and got the job done...
I am baffled at how a juggernaut like Adobe can't deliver on these kinds of things.
I have been a Partner for over 6 years... and I miss the days before Adobe.
