First video editing + server use build
CaillinAU Jun 8, 2012 7:04 AMSo I'm in the process of getting myself a new machine that will be used as a general purpose (low use) personal server, but also as a multimedia editing machine (so PPro,AE,PS etc, (also dreamweaver but that shouldn't be too taxing))[CS6 versions]. I don't really care about gaming on it, and I'll be using a sony bravia as the primary screen.
I've had at Harm's and ADK's sites and have come up with the following:
OS: Win7 Pro 64bit (I'll also be virtualising ubuntu).
Motherboard: Asus P9X79 WS
CPU: i7 3930K
Cooling: Based on the default ADK build, the intel water system.
Video Card: Either a GTX 670 or a GTX680. I've had a look at reviews and the 670 seems to be able to boost up to similar levels as the 680, but what's the PPro comparison like? I've seen Harm suggest a 4GB GTX670.
RAM: 4x4GB (the P9X79 appears to have 8 ram slots so I can bump up to 8x4 at a later stage if needed). What about brands? I've seen that it needs to be a lower voltage than normal, and that samsung has been mentioned (http://forums.adobe.com/message/4464921), and newegg talks about ripjaw (http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231505)
Optical Drives: Bluray burner. (any preferred brands?)
Storage:
I was thinking of going with a SSD for the system drive (Crucial 256GB M4). From what I can tell, this would mainly help the boot times and the server side of things rather than the media side of things.
For the data drives I was thinking of at least initially, a pair of 2TB HDDs (unraided). Not sure about the brand. Since I'm not using raid I don't need to worry about the spindown issue if I use greens.
PSU: Well, that'd partially depend on the components chosen above. I put it through the eXtreme power supply calculator and got 455W, but that was excluding fans and the water cooler, and assuming green drives.
On that note: Fans. Harm's beast has a lot of them. Of course, I'm not trying to cool a a massive stack of drives.
I may also put a wifi card and a tv tuner in too.
I think that just leaves the case. I don't care about it looking flashy, but I'd prefer something that doesn't have funny wings or handles sticking out of the top, front or side (ala alienware).
So. Over to the professionals.
Suggestions?
