1. Re: Setting the Crop Tool Dimensions Automatically in the Middle of a Script
JJMack Jun 14, 2012 7:57 PM (in response to apmaui808)Yes but not so much with the crop tool. Your better off with a selection then image crop http://forums.adobe.com/message/4476999#4476999
Once you set the selection you can also make the action interactive by adding a interactive transform selection step the you turn on its dialog. While recording the action you rotate the transform 180 degree which actuallu doe not change the selection. However it let the user to just hit enter to accept the selection. If you fail to rotate the selection when you record the action. Just hitting enter would cancel the transform selection and the action would stop at the transform selection step. You can also cancel the transform to stop the action because you made a manual error not holding the shift key to maintaim the selection 4:5(8:10) aspect ratio and you moved a cornor or side. Once you cancel the transform selection you can click play the action will start pyaying from the transfor selection and you can retry transforming the 4:5 selection correctly.
