The syntax in the RoboHelp 9 help topic "Call a context-sensitive function for WebHelp or FlashHelp" seems wrong:
http://servername>/robohelp/rest/robowindow?wtype=ctx&context=<MAP ID>
Is this correct?
https://<servername>:<port>/<path to WebHelp>/<WebHelp start page>.htm?wtype=ctx&context=<MAP ID>
Is there any alternative syntax I should consider? Are there advantages or disadvantages to using the RoboHelp_csh.js functions?
I cannot help you on this one but maybe this link will provide the information you need. http://www.wvanweelden.eu/robohelp/context_sensitivity_in_webhelp
Unfortunately, that article is only about regular WebHelp, not WebHelp Pro.
As far as I can make out from the JavaScript API, the correct synax would be:
window)(&cmd=newwnd&rtype=iefrm)
Replace italic text with correct value. Text between parentheses is optional. I do not use RoboHelp server so this is purely based on what I can gather from the API. Hopefully Column or another RH Server power user can tell you more.
Greet,
Willam
The comments in RoboHelp_CSH.js (in C:\Program Files (x86)\Adobe\Adobe RoboHelp 9\CSH API\JavaScript on my system) are helpful. I guess JavaScript is the way to go since the URL approach is not not really documented.
