6 Replies Latest reply on Jun 15, 2012 11:21 AM by jetrased
    TitleWindow PopUp Tab/Focus problem
    jetrased
      Hi
      I am wondering if anyone can help me. There is a titleWindow popup created. A login form is loaded into it. With 2 text input fields: Username and Password and one Button, OK.
      The problem I am having is that I cannot get tabbing to work inside the new titleWindow. When I click on the user input field and then press tab, the cursor disappears. I have searched the net and there are numerous instances of this happening, but no actual solution that I can see.
      The Login Component is of type VBox.
      The weird thing is, if I enter the wrong details or no details and click ok. Then The tabbing wors the second time around. It is just when it is initially loaded. I have no idea why this could be?
      Can anyone help as it is driving nuts.
        • 1. Re: TitleWindow PopUp Tab/Focus problem
          Flex harUI Adobe Employee
          So there is a SWFLoader in the TitleWindow?  Maybe show the MXML for the TitleWindow?
          • 2. Re: TitleWindow PopUp Tab/Focus problem
            jetrased Level 1
            Here is the MXML for the title windoew to be popped up
            private function popupLogOnDlg(evt:Event=null):void
                                                    stwLogOn = new StwLogOn();
                                                    stwLogOn.addEventListener("clickOK", handleCloseLogOnDlg);
                                                    titleWindow= TitleWindow.show(stwLogOn, "Log On", 0, true, null, handleCloseLogOnDlg);
                                                    titleWindow.isResizable=false;
            And here is the MXML for the Login Component
            <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml"
                                  width="280" height="115" defaultButton = "{okBtn}">
                      <mx:Script>
                                <![CDATA[
                                          private function handleClickOK():void
                                                    dispatchEvent(new Event("clickOK"))
                      </mx:Script>
                      <mx:Form width="100%">
                                <mx:FormItem width="100%" label="User name:" horizontalAlign="right">
                                    <mx:TextInput width="100%" restrict="A-Za-z0-9_." id="nameTextInput"/>
                                </mx:FormItem>
                                <mx:FormItem width="100%" label="Password:" horizontalAlign="right">
                                    <mx:TextInput width="100%" id="keywordTextInput" displayAsPassword="true"/>
                                </mx:FormItem>
                      </mx:Form>
                      <mx:HBox horizontalAlign="right" width="100%">
                                <mx:Button label="Log On" id="okBtn" click="handleClickOK()"/>
                                <mx:Spacer width="10"/>
                      </mx:HBox>
            </mx:VBox>
            • 3. Re: TitleWindow PopUp Tab/Focus problem
              The Flex SDK TitleWindow doesn’t have a show method.  Maybe your TitleWindow is not the one from the Flex SDK and doesn’t implement IFocusManagerContainer.
              • 5. Re: TitleWindow PopUp Tab/Focus problem
                StephaniesHusband
                How did you resolve this?  I have the exact same issue and cannot find ANY way to fix it.  I've tried everything I know to do and everything from the Adobe site cited.
                • 6. Re: TitleWindow PopUp Tab/Focus problem
                  jetrased Level 1
                  Hi
                  I added applicationComplete method and tin here is where I called my login to pop up. Worked for me.
                  protected function applicationComplete():void
                            addEventListener(FlexEvent.SHOW,popupLogOnDlg);
                  The here is the method I call.
                                                          stwLogOn = StwLogOn(PopUpManager.createPopUp(this, StwLogOn, true));
                                                          PopUpManager.centerPopUp(stwLogOn);
