1 2 Previous Next 40 Replies Latest reply on Sep 30, 2015 3:12 AM by grantlee3000
    missing sequence presets or codec
    flounder house Level 1
      I cannot open saved projects! Instead, when I open a saved Premiere Pro project I get the error message: "This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type."
      I am running Premiere CS6 on a MacBook Pro 10.7.4. I am not subscribed to creative cloud. I do not have any previous versions of Premiere installed (ie. CS5, CS5.5).
      This message seems to be a pretty common problem among CS6 users. Here is a recent thread for creative cloud users experiencing this error message: http://forums.adobe.com/message/4496308 Like others, I am unable to open old projects, but I can still start new projects. However, when creating a new project, my  sequence settings seem to be missing  presets:Pr sequence presets.jpg
      any ideas?
        • 1. Re: missing sequence presets or codec
          Harm Millaard Level 7
          Deactivate, uninstall, run Clean Script several times, rebooting between runs, install, activate and update.
          • 2. Re: missing sequence presets or codec
            Zac Lam Adobe Employee
            Is the application still activated?  If you start a new project, then go to the Help menu, do you see a Deactivate menu item?  Or does the menu item allow to activate the application again?
            • 3. Re: missing sequence presets or codec
              eday_2010 Level 1
              I reinstalled Windows and installed PrePro CS6 again and it was still missing presets.
              • 4. Re: missing sequence presets or codec
                Did you run Clean Script several times?
                • 5. Re: missing sequence presets or codec
                  Shadreck Rukweza Level 2
                  Did you try pressing and hold the shift key while launching Premiere Pro?
                  • 6. Re: missing sequence presets or codec
                    eday_2010 Level 1
                    No, because it was a clean install on a clean OS. there were no remnants of anything Adobe on the install
                    • 7. Re: missing sequence presets or codec
                      eday_2010 Level 1
                      No. I'll give that a whirl.
                      • 8. Re: missing sequence presets or codec
                        Do you have the physical install disks, or did you use a download version? In the latter case, I would try a new download. Maybe the download you have is corrupted.
                        • 9. Re: missing sequence presets or codec
                          Jesse Zibble Adobe Employee
                          In the New Sequence dialog, if you go to the "Settings" tab is "Custom" an available choice at the top of the list of editing modes?  If yes, what choices are available in the "Preview File Format" popup?  I suspect that I-Frame Only MPEG is absent.
                          • 10. Re: missing sequence presets or codec
                            eday_2010 Level 1
                            There isn't much under custom. I didn't see I-Frame Only MPEG, but what I did notice right away was the absence of all the AVCHD presets, which is what I had previously used.
                            • 11. Re: missing sequence presets or codec
                              David_V_Clarke Level 3
                              I had this and spent ages trying to sort it out.  What solved it was going into Adobe Encore where it suddenly popped up demanding a serial number.  I hae already done this when I installed my software (in may case the master collection) and had previously used Encore.  I was getting no other information telling me there was a problem with activation etc..  However I entered my serial number again, got into Encore, and when I went back to Premiere I had all the presets.  I fiddle a lot with my computers so I just assumed I had done something which messed it up in some way.  Try opening Encore and see what happens.  Unfortunately this is no help if you are running the trial version since you won't be able to open Encore.
                              • 12. Re: missing sequence presets or codec
                                Russell450F
                                I have an international show that needs to ship out in a couple of days.  Worked till 1.30am then arose to find this not so pleaseant surprise that Premier couldn't see / understand my RED .R3D sequence all of a sudden.  Spent the entire day on this.  I uninstalled, used cleaner & re-installed countless times.  Finally uninstalled everything via Adobe cleaner, went through and deleted other adobe folders that I found.  I downloaded & Installed a fresh stand alone version of Premier 6 & all of the normal slew of sequences settings were back.  Then I went & seperately installed AE, Photoshop & Audition from the Master Suite.  Did Not install Encore or anything else & I'm now back up & running with some new grey hair... Frustrating.  I hope this infor perhaps helps someone in the same bind... Good luck!
                                • 13. Re: missing sequence presets or codec
                                  Fluxcrou
                                  Ugh, I had a problem importing AC3 audio that held me back from working on my already late project, and now I have this exact same problem out of the blue!
                                  I cannot access animations I have saved in a project.  I need to copy the animations into a project that is thankfully operational, but the dreaded error message appears whenI try to open it.  Several other project files I have saved will not open either.
                                  My sequence presets list is bare, exactly like the OP's screenshot.  But, I can see the full compliment of sequence presets is still at C:\Program Files\Adobe\Adobe Premiere Pro CS6\Settings\SequencePresets.  For some reason, only DV and Mobile&Devices presets show in Premiere.
                                  I have uninstalled the CS6 suite, ran the Adobe cleaner, reinstalled and updated.  No effect, whatsoever.  The sequence presets are still in the folder, but cannot be recognized.
                                  I do not have Creative Cloud.
                                  • 14. Re: missing sequence presets or codec
                                    browndoggin
                                    I too am having this soul destroying message. I am running OS 10.6.8, no creative cloud and using CS6.00. I have now had it happen twice on projects all created using ProRes 422 files and had a reasonably complicated edit. all opens and closes fine and then just randomly wont open. Thought it would go away but hasn't. Has Adobe come up with a bug fix for this as its a pretty monumentally tragic fault. I have switched over form FCP and was stoked with CS6 until this. Luckily I had virtually finished both projects and could get around it with the draft mastered ProRes file.
                                    I see no reply to Fluxcrou's last response so i wont get my hopes up.
                                    My confidence in Adobe is at a low.
                                    • 15. Re: missing sequence presets or codec
                                      Todd_Kopriva Level 8
                                      The underlying problem here is with the activation and licensing system. Several codecs and the sequence presets that they rely on must be unlocked by the activation and licensing system. The problem is that sometimes the activation gets messed up in some way, and these codecs aren't unlocked.
                                      For most people on this thread, the issue should be fixed by a new version of the activation system that was release in late June.
                                      Try this to get your activation back into the right state:
                                      1) Fully deactivate your software (Help > Deactivate).
                                      2) Quite all Adobe applications.
                                      3) Restart your computer.
                                      4) Restart the application.
                                      5) Choose Help > Activate to re-activate the software.
                                      6) Create a new project.
                                      7) Create a new sequence.
                                      The above should restore all of your codecs and the sequence presets that depend on them, and you should be able to work normally with all of your codecs.
                                      If not, write back, and we'll see if we can figure out what's up.
                                      • 16. Re: missing sequence presets or codec
                                        gmizzle39s
                                        I have downloaded the 6.0.1 Update for all of the CS6 applications and I stil get this problem. When opening Encore I get an error that says:
                                        Adobe Encore CS6 cannot run in a non-royalty serialized mode. The application needs to be serialized with a royalty bearing serial number.
                                        I have uninstalled and reinstalled and still get the same issue. We are government so I am not cnnected to the internet because of regulations. The deactivate option in Premiere Pro CS6 is greyed out and unavailable as well.
                                        We purchased a volume license for 2 edit stations and both have this problem. We are on Windows 7 SP1 x64.
                                        Sorry just wanted to give as much info as possible to help resolve this. I literally can't do any work until this is resolved!
                                        • 17. Re: missing sequence presets or codec
                                          As far as I know, you must be connected to the internet for registration/activation to complete
                                          Since this is a user to user forum, not Adobe support, I think you are going to have to contact Adobe on this one... unless someone comes along with information on how to make Encore work without internet to complete registration/activation
                                          • 18. Re: missing sequence presets or codec
                                            There is an offline activation option. You don't need to be connected to the Internet. There is more information about offline activation here:
                                            http://helpx.adobe.com/x-productkb/policy-pricing/activation-deactivation-products.html
                                            For issues with activation, this forum is very useful:
                                            http://forums.adobe.com/community/download_install_setup
                                            • 19. Re: missing sequence presets or codec
                                              lorraineyoga Level 1
                                              Todd,
                                              Thank you for recognizing that the problem is with the activation and licensing system. I have called Adobe technical support many times about this issue--the latest being twice today--and it is still not resolved.
                                              I have a new Windows 7 computer on which I installed the disk version of CS6 and the disk version of Captivate 5.5. I mention this because I had Media Encoder 5.5 and 6 (5.5 I think may have installed with the Captivate), but otherwise I have no older CS products on this computer.
                                              If I enter my serial number when the trial window comes up (which it shouldn't), I  can open my projects, but this is just a temporary fix until I close the program and the problem shows up again.
                                              For my first call to Adobe today, the technician took over my computer and tried to update to version 6.0.1 (which was running anyway). It took about 3 attempts from her. She told me that my problem was solved and closed the case. Ten minutes later I tried to open a pdf file and saw the trial window again.
                                              For my second call to Adobe, the technician assured me he had solved this problem 6 times by having customers reinstall CS6. He then told that there was an internal document which had the solution to the problem. He tried to tell me that my problem might be caused by incorrect information in my Adobe ID, such as birth date (my information is correct and has not changed). He told me that my problem would be fixed if I turned off my anti-virus software and then entered my serial number in the trial window. He also kept telling me not to trust forums and I kept telling him that the forums served as a way for Adobe to recognize that there is a problem.
                                              I have reopened my case and requested an escalation to second level.
                                              Update: I haven't heard anything further from Adobe. In the meantime I uninstalled Captivate 5.5 and tried to remove Media Encoder 5.5, I also used the Adobe Cleanup tool. Then I reinstalled Captivate 5.5 but declined to install Media Encoder 5.5 with it (I have Media Encoder 6 with CS6). I also uninstalled and reinstalled Premiere Pro and updated it. So far far I haven't encountered the dreaded Trial Version window again so I'm holding thumbs.
                                              • 20. Re: missing sequence presets or codec
                                                If you're having problems with sequence presets and codecs missing from Premiere Pro, see this document for solutions for this activation issue:
                                                http://helpx.adobe.com/premiere-pro/kb/features-presets-missing-premiere-pro.html
                                                This document relates to the following problems:
                                                - missing sequence presets when creating a new sequence
                                                - Encore error: "Encore will not launch in non-royalty bearing mode. The application needs to be serialized with a royalty bearing serial number."
                                                - When opening a project in Premiere Pro: "Error Adobe Premiere Pro: This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type."
                                                - When importing footage, the footage is missing audio or video.
                                                These failures are all because Premiere Pro and Encore use some codecs that require activation before they can be used. If activation of these codecs has failed, these codecs will not be available to use.
                                                • 21. Re: missing sequence presets or codec
                                                  thizzzordie
                                                  I have been trouble shooting this and I finally found something worked. (for the tl;dr go to Solution: Method 1)
                                                  Here are things I tried and observed
                                                  I opened up the Project within another project.
                                                  1.  It wouldn't allow me to import the the full project because of the default problem of missing presets, but I could open single sequcences.
                                                  2.  I eventually imported each sequence into the new project.
                                                  3.  Unfortunately, after I closed the project, it wouldn't open again for the same previous problem.
                                                  4.  I repeated step 2 and this time I created custom sequences.  I created a dslr preset - 1920x1080, 23.973, progressive...
                                                  5.  Using that preset I created a copy for all the seuqences.
                                                  6.  I cut and pasted all the clips into the new sequence and deleted the old sequences.
                                                  7.  This actually worked, and I can open the projects no problem.
                                                  But this is the most efficient and simple solution -
                                                  Solution: Method 1
                                                  1. Close Premiere Pro.
                                                  2. Open the project file in a text editor (e.g. Windows Wordpad) and replace all instances of "I-Frame Only MPEG" with "Microsoft AVI".
                                                  3. Relaunch Premiere Pro and test it.
                                                  Found Solution here - http://www.mediacollege.com/adobe/premiere/pro/troubleshooter/sequence-could-not-be-opened .html
                                                  • 22. Re: missing sequence presets or codec
                                                    Jim_Simon Level 9
                                                    Seems a lot easier to just fix the actual problem by using Adobe's solution.
                                                    • 23. Re: missing sequence presets or codec
                                                      thizzzordie Level 1
                                                      It took me less than 1 minute to edit the project files in notepad...  Sounds a lot faster than re-installing it
                                                      Note:  My deactivation was greyed out, so I couldn't do that.
                                                      • 24. Re: missing sequence presets or codec
                                                        Jim_Simon Level 9
                                                        Adobe's solution doesn't require a reinstall.
                                                        If Deactivate was grayed out, then all you had to do was reactivate.
                                                        • 25. Re: missing sequence presets or codec
                                                          thizzzordie Level 1
                                                          If you are referring to - http://helpx.adobe.com/premiere-pro/kb/missing-sequence-presets.html
                                                          Deactivition wasn't available
                                                          The alt + ctrl didn't work for me.
                                                          If you are referring to - http://helpx.adobe.com/premiere-pro/kb/features-presets-missing-premiere-pro.html
                                                          I am activated, and I was not give any serial number/activation options
                                                          or Re-installing CS6 which I didn't have to do.
                                                          I'm not aware of any other adobe solutions, but if you have any please share.
                                                          • 26. Re: missing sequence presets or codec
                                                            Jim_Simon Level 9
                                                            Sounds like something got really smurfed up with your installation beyond this issue.
                                                            Your fix might be the easy band-aid, but a reinstall might still be the better option in the long run.
                                                            • 27. Re: missing sequence presets or codec
                                                              thizzzordie Level 1
                                                              Totally agree.  I do miss my presets.
                                                              • 28. Re: missing sequence presets or codec
        This is really a problem with Adobe's  registration and activation system. Adobe needs to fix the bug so that our activation information is retained. We should not be having to resort to all these measures just to use software we have purchased, registered, and activated. I have tried all the "solutions," but none works permanently. They're all just temporary quick fixes. Please report the bug to Adobe.
        • 29. Re: missing sequence presets or codec
        Dan from Atlanta
        This is still an issue as of this morning.  It's happened to me twice in one month for no apparent reason.
        From what I'm reading, it's happening more often with the Creative Cloud.
        Both times, I had to uninstall Premiere Pro, reinstall it, and install the latest updates.
        During the failure, it renders existing projects, that worked minutes before, completely ununsable.  And even after a reinstall, some video clips within a project will work, but some identical-type (AVCHD) clips stay "offline," and won't render.
        Today's solution was a complete uninstall of all CS6 products, running the cleaner and rebooting twice, reinstalling, and updating.  But then, Dreamweaver was missing a dll file until I installed and updated another CS6 applicaion.
        Many hours later, everything's back to "normal," and my original Premiere Pro projects now function properly.
        This is a very serious bug that shouild be addressed immediately, please!!
        • 30. Re: missing sequence presets or codec
        xTLS Level 1
        I felt pretty brilliant when I thought maybe I could edit the .prproj file in a text editor (Premiere Project files are actually just XML) and edit the sequence settings, tried it, and it actually worked. Then I found out other people had figured that out.
        To repeat: in an emergency, where you can't or don't have time to reinstall Premiere repeatedly, you can manually edit the XML file and change all of the sequence settings to common codecs - it's actually pretty easy.
        Found this link in another thread: http://schiho.com/2012/09/25/adobe-premiere-cs6-sequence-cannot-open/
        • 31. Re: missing sequence presets or codec
        44r0n.5 Level 1
        My "preset missing" problem seems to be intermittant.  I started Premire this morning, got the message that "one or more 3rd party items were missing and your sequences will be modified, or quit Premire and reinstall all 3rd party items", and when I looked at my sequence presets, they were mostly gone.
        I found this page and started to follow the easiest of the Adobe directions "unregister and reregister", but when I re-started Premire to unregister, I didn't get the "3rd party items missing" message and all of my sequence presets were back.
        I'm currently using the cloud subscription.
        • 32. Re: missing sequence presets or codec
        Hiddenpictures Ltd Level 1
        I am a Creative Cloud member and I am also getting the same hugely time-wasting nonsense error message: "This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type". The solution seems to be to deactivate and the reactivate but it is not obvious WHERE that can be done - using the help menu - register, licence, license, deactivate produces no results - the Adobe answer is to use 'deactivate'  - OK so WHERE is that on the menus - how do I get to that screen?
        After wasting a lot more time I did get it to come up but not sure how. I reactivated and now it works again - but not sure for how long. I also don't know whether I am now running a trial version or not.
        So in summary - very confusing, total waste of time, gives me a lack of confidence in the product - hello Avid
        • 33. Re: missing sequence presets or codec
        Jim_Simon Level 9
        Help>Deactivate...
        • 34. Re: missing sequence presets or codec
        conferhawks@gmail.com
        I had the same problem, same message.  Finally after reading through all these post it began to sound like an activation issue to me.  Sure enough, it was.  For some reason my folks forgot to talk to their folks and tell 'em I paid. . . or come sort of cyber equivalent.  I just opened a new project and deactivated (under the HELP tab) which closed the program.  I then restarted and all was good as new.  Hope your fix is as easy.
        • 35. Re: missing sequence presets or codec
        JeffRev63
        So what if you can't go "online" to activate? My system has this issuebut it is a standalone machine that is not allowed to hook to any network. I had to do a phone activation when I did my initial install but apparently that doesn't unlock all of the codecs I need because there are only a minimal number available when opening a new project. One critical one is for my Canon MXF files that can longer be opened for editing.
        Any solution would be greatly appreciated by one of your "unplugged" customers.
        • 36. Re: missing sequence presets or codec
        capt_kilgore
        I can't be bothered being polite because this problem has happened far too many times. Fix the problem. Don't tell us we need to de-activated, re-download, re-install, or whatever. Once the software is installed and working it should stay that way.
        You have enough mechanisms in place to staunch pirates as it is; this ******** "activation" of codecs is simply a kick in the shins for those of us who pay for the products. I'm sick of crossing my fingers when I open my projects hoping that the codecs haven't randomly disappeared.
        Fix the problem.
        • 37. Re: missing sequence presets or codec
        I still get that in CC and I think I might not renew my membership because I waste a lot of time about these missing codecs, especially, MTS files and HDV mpeg.
        • 38. Re: missing sequence presets or codec
        247Visuals Level 1
        All in all, it sucks that this problem still exists.
        After trying the free trials of Adobe CC 2014 for a month, I purchased the Creative Cloud subscription today.
        Then problems began. Adobe Premiere did not open the projects I worked on. It missed the proper sequence settings.
        Reinstalled several times, used the cleaner tool....
        Adobe, how happy I was to purchase this CC. How I curse now everytime Adobe Premiere opens after a reinstall without the proper sequence settings.
        Still trying to reinstall to no avail.. This just sucks.
        WHAT ARE YOU GOING TO DO ABOUT THIS ADOBE?
        • 39. Re: missing sequence presets or codec
        This problem have existed for years and continues to exist right now. I edit lots of HDV sequences and I get this very often like once in a fortnight or weekly at times. I will have to sign out and sign back in at times after signing in all the softwares will appear as trial hence I pay every month in this world. Shame on adobe-software! Some Adobe remote technicians pointed that the activation might be bloced by Antivirus softwares. But that being said I remember that the Creative Cloud will only need to check activation once every 90 days or less I don't know. I think it does check activation on a daily bases or every time you launch it.
        Screenshot 2014-10-15 00.29.19.pngScreenshot 2015-01-14 00.17.55.pngScreenshot 2015-01-14 01.38.57.pngScreenshot 2015-01-14 01.54.28.png
        VERY ANNOYING.
        1 2 Previous Next
