My project running without problem, but when I'm click my object in the stage, I'm taking "TypeError: Error #1009: Cannot access a property or method." error. Here my project https://rapidshare.com/files/1556610915/Proje.rar
my code in fla:
import Gosterge;
var gosterg:Gosterge = new Gosterge();
gosterg.gostergeleriEkle(a,c,k1);
my code in Gosterge.as:
package
import flash.display.Sprite;
import flash.events.MouseEvent;
public class Gosterge extends Sprite
public var cerceve:Sprite = new Sprite ;
public function Gosterge():void
// constructor code
private function tikla(evt:MouseEvent):void
trace("tikla çalıştı");
cerceve.graphics.lineStyle(1, 0x0000FF, 1);
cerceve.graphics.lineTo(100,0);
cerceve.graphics.lineTo(100,100);
cerceve.graphics.lineTo(0,100);
cerceve.graphics.lineTo(0,0);
cerceve.x = evt.currentTarget.x - 5;
cerceve.y = evt.currentTarget.y - 5;
stage.addChild(cerceve);
public function gostergeleriEkle(... args):void
for (var i:uint = 0; i < args.length; i++)
args.addEventListener(MouseEvent.CLICK, tikla);
Please help, I can't find problem.
Will itsolve your problem if you pass the stage to the function as an argument. Since the class is not added to the stage, then it probably needs to be provided a reference to it. See the bolded changes/additions to the code below...
import Gosterge;
gosterg.gostergeleriEkle(this.stage,a,c,k1);
package
import flash.display.Stage;
...Copy link to clipboard
Chances are the stage is not a defined entity for the class. You might need to add an event listener for ADDED_TO_STAGE wherein the event handler establishes the stage for the class. See if the following tutorial helps solve anything, and if niot, try searching Google using "AS3 ADDED_TO_STAGE"
http://www.emanueleferonato.com/2009/12/03/understand-added_to_stage-event/
I tried your advice, but I can't solve problem. Can you edit my project? if you help me, I would greatful.
import Gosterge;
package
public var _stage;
// constructor code
_stage.addChild(cerceve);
public function gostergeleriEkle(stag:Stage,... args):void
_stage = args[0];
for (var i:uint = 1; i < args.length; i++)
Thank you very much, thank you very much, really thank you very much , I finally understood. It works now . My class couldn't reach the stage. Mr. Ned, you're the best , I'm so grateful
You're welcome
