1 2 3 Previous Next 202 Replies Latest reply on Jan 8, 2018 3:46 AM by Rexgom
    CS6 E Bridge Slow to load thumbnails, 'building criteria'
    SandraChung Level 1
      When Bridge opens on the folder it was last opened/closed in, it takes a long time to load, constantly 'building criteria' as if all the images are newly imported. I've searched the forums, have tried all the tweaks and settings, but it's still iceberg slow.  Bridge CS5 is noticeably quicker, as if the cache info is being read immediately. CS6 is behaving as if the cache file has been deleted. It hasn't. I have tried the "flush the cache" to see if maybe it's corrupted. No joy. I have boosted cache size. No joy. I've compacted, automatically exported cache to folders, everything... Nothing seems to fix the snail slowness.
      All Adobe updates have been applied.
      i7-2600s @2.80GHz
      8 gb DDRw ram
      Nvidia GeForce GT420 1gb DDR3
      6+ tbs hd space.
        • 1. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
          Curt Y Level 7
          I noticed the same thing with mine and the default setting was for HQ and generate 100% previews.  Changed to embedded like I have in CS5 and still seems a little slower to build cache.
          What thumbnail settings do you use?  In cache preferences do you have any of the options checked?  I don't.
          1 person found this helpful
          • 2. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
            SandraChung Level 1
            Thanks for the reply.
            I tried just about every combination of settings imaginable. I've had options checked, and not checked. Used small thumbnails, medium and large, adjusting the slider up or down, closing bridge, opening it. No joy.  I even took screen cap of CS5 Bridge settings and duplicated them in CS6.. still snail slow.  Every time I open a folder it behaves as if they are all newly imported.  it's as if the caches is being wiped/erased when CS6 Bridge is closed.
            • 3. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
              Curt Y Level 7
              You did not say what you are using for thumbnails.  This is the option in toolbar below the word filmstrip.  Choice of Embedded, and HQ options.
              THe size of the thumbnails on the screen has nothing to do with it.
              When you open a folder do you wait for the spinning arrow in the lower left corner to stop?  If not you have not fulling indexed the folder.
              • 4. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                SandraChung Level 1
                I tried all of them (as in every combination imaginable), sorry I wasn't clear. I've tried Essentials, Film Strip, meta data.  I've tried havign the thumbnails at their smallest, to largest to every size in between.
                "When you open a folder do you wait for the spinning arrow in the lower left corner to stop?  If not you have not fulling indexed the folder."
                That's just it, it does that all the time with the message "Building Criteria"  right above it, as if all the images are newly imported. I have to wait anywhere from 1 minute to almost 3 minutes, even if I've thoroughly indexed the folder, closed Bridge down, then reopened it on the same folder. Again, I don't get this behavior with CS5 E bridge.
                • 5. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                  Curt Y Level 7
                  Not sure if we are looking at same thing.
                  I open a new unindexed folder of 700 jpeg pictures.  In lower left corner  it says 700 items (700 thumbnail extractions) and the arrow spins as extractions counted down to zero.  Takes about 12 seconds.  Video files take longer.  I am using Embedded thumbnals and 100% previews is not checked.
                  Don't know what this "building Criteria" is or where you see it.  On my screen "right above it" would be in the folders panel.
                  • 6. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                    SandraChung Level 1
                    Yes, we are.. the building criteria is in the Filters tab.  We're describing the same thing using different words.
                    I have accessed this folder several times. It shows all the thumbnails in CS5 in under 15 seconds.  As I am typing this CS6 Bridge still has the spinning arrow going round and round (688 images), and I have accessed this folder in CS6 before. Several times. It shouldn't be behaving as if this a newly imported/freshly viewed folder of images.
                    • 7. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                      Curt Y Level 7
                      OK, again not sure what the "building critera" is all about.  Have not seen that on my system.  Perhaps it has something to do with raw images.  That could be the slowdown.  But not sure if that is the reason it has to rebuild each time.
                      One issue at a time I guess.  Lets figure out the loading time first.
                      Do you have a folder that just has jpeg that you could try?
                      • 8. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                        SandraChung Level 1
                        I gave it a try on a JPG only directory, 313 images.
                        Still slower to load than Bridge in CS5
                        The Building Criteria is filtering by File type, Keywords, Date Created, ISO. I've tried shutting it down, and it makes no difference in speed if that filter tab is open or closed in CS6.
                        • 9. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                          Curt Y Level 7
                          Well I am stumped.  You must be doing something different in CS5 than in CS6.
                          Do you have the option checked to export cache to folders checked.
                          Look closely at what CS5 does and CS6.  Go to Tools/cache/ purge cache for the above folder.  When it re-indexes in CS5 does it say "building criteria"?
                          Try same with CS6 and see if you can spot difference.  Remember CS6 and CS5 use different cache.
                          • 10. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                            SandraChung Level 1
                            *sigh* No, I'm not doing anything different in CS5 than I'm doing in CS6, except not waiting as long.
                            Yes.
                            I've done this, for both versions, a few times now. And yes, CS5 also says "Building Criteria"  but it doesn't take anywhere near as long.  Also, the 'little circling arrow' on the left stops a helluva lot sooner than in CS6.
                            I know they do, and the only difference I can see is it takes longer for CS6.
                            I do thank you for your time and effort, but it seems I was doing all the right troubleshooting methods.
                            • 11. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                              Curt Y Level 7
                              Here is a link from 2009 with the same problem you are seeing.  http://forums.adobe.com/thread/310547
                              They also used a Cannon, but alas there is no posted solution so don't know if problem ever solved.
                              • 12. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                SandraChung Level 1
                                This would apply, if I hadn't been using Adobe Photoshot CS since version 2 and have never had this problem.  I do remember reading about this for v3&4.  Also, I posed this question to Canon AU and they said that CTG doesn't affect how Adobe Bridge reads/collates/indexes the thumbnails.
                                I do thank you for trying to assist, and if you hear of anything else that could fix this snail slow problem with Bridge, please reply again.
                                • 13. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                  Curt Y Level 7
                                  You might send a note by Personal Mail (in Your Stuff above) to the OP and see if the resolved issue.
                                  I just don't get the "building criteria" as I have purged several folders and have never seen that message.  I use NEF raw images.
                                  If it is tied to raw images ACR 7.x uses a different profile that previous versions of ACR.  Perhaps there is a bug that affects Cannon.  If so perhaps someone else with Cannon will weigh in.  But to confuse the issue I had you select a folder with just jpegs and you still had "building criteria".  Did you adjust any of these images with ACR?
                                  It is also confusing as you say CS5 also has "building criteria".  Like I say I have never seen it.  Might try a web search and see if you can find out why Bridge does this.
                                  Post back if you find cause and solution.
                                  • 14. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                    Travelphotog1959 Level 1
                                    Just wanted to add that I also get this "building criteria" message in a black bubble as I wait for my files to appear. Never used to happen before in the previous versions I've had, including the CS6 Beta.
                                    • 15. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                      SandraChung Level 1
                                      Good to know that I'm not the only person.  This "Building Criteria" happens in CS5 E also, but not so snail slow. It' can't be caused by Canon RAW format, because it happens with my Lumix RAW files and Pentax. And the Pentax only shoots JPG. The issue is with CS6 Bridge.
                                      And to Curt, 'OP'?   Also, I searched the web for two weeks, using different search phrases with 'Building Criteria" before posting about it here. Not that much of a noob.
                                      • 16. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                        It's definitely a Bridge issue, and for me it started in CS6. I also can't view my photos in full screen mode, either with the space bar or menu bar command. Very frustrating.
                                        • 17. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                          Yammer Level 4
                                          I think that "Building Criteria" is just Bridge 'collecting' all the different metadata from each image in the folder in order to building up the filter lists. If I select thousands of images, Building Criteria can take quite a long time, but is usually only a matter of seconds for a few hundred images, in CS5 or CS6. I usually select the Collections and Metadata panels, in order to hide the Filter and Keywords panels. I find that things happen faster with these panels hidden.
                                          Smaller thumbnails seem to make a faster system, and certain raw defaults will slow things down.
                                          I don't think it makes any difference to Building Criteria if the folder has already been indexed. I reckon that filter criteria is probably built 'on the fly', although it's possible that a copy of some of the metadata is kept in the Bridge database.
                                          Working on this premise, it's possible that the problem is related to CS6 Bridge's ability to parse metadata from large numbers of files. On my system it's fine, so I'd suggest that there is something unusual about your setup. Here's a few things worth checking:
                                          1. if your raw files are taking a long time to generate previews/thumbnails, consider setting 0 noise reduction in your defaults and maybe disabling lens corrections by default. ACR7 is slower than ACR6.
                                          2. make sure your CS6 cache is located on a defragged partition.
                                          3. Don't generate 100% previews by default, but allow them to be saved if necessary.
                                          4. there is a known bug with layered TIFFs causing havoc with Bridge CS6
                                          Bridge CS6 uses a different database system to CS5. This may be part of the problem. Try disabling your anti-virus to see if this is affecting operation of the program.
                                          Have you tried both 32-bit and 64-bit Bridge? Is there any difference?
                                          • 18. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                            SandraChung Level 1
                                            There is no difference in speed, regardless of thumbnail size. I do believe I mentioned that in a previous post.  There was no increase in speed with panels shut with CS6 Bridge, and again, I mentioned that in a previous post.  I expect it to take a long time the first time a folder is opened and wait for that. What isn't normal, is Bridge behaving as if it's a newly imported group of photos after it's been closed. Again, I mentioned that earlier. The Building Criteria and the long 2 to 3 minute wait happens each and every time Bridge is started.
                                            1: I never allow the cameras to use noise reduction. That's for post processing. The beta version of CS6 and ARC7 beta wasn't anywhere near this slow. .  As for it working fine for you, I'm happy for you, but that's no help for me (and others who have this problem).  There's nothing 'unusual' about my set up. I know blaming the user is the easiest thing to presume, but this isn't the case.
                                            2: Hard drive isn't fragmented. I do regular checking and defragging.
                                            3: That isn't the problem either.
                                            4: I know about the layered tiffs, but I don't use them.
                                            Yes, I've tried it in both 64bit and 32bit versions on this computer, and also on another totally different machine (that was fun, deactivating, installing, activating, running, deactivating and putting it back on this computre) and still having the same problem. That machine is running Windows 7 Ultimate, 32bit.
                                            I did disable anti-virus (weeks ago) and tried, and still getting snail slow loading.  And before you ask, I started Bridge with the Three Finger Salute (Shift+Ctrl+Alt while starting) , resetting to defaults and purged the CS6 Bridge cache.  Didn't make a bit of difference.
                                            • 19. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                              Yammer Level 4
                                              Apologies. I didn't read every word; I have work to do. No more suggestions.
                                              • 20. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                                MichaelWentworth-Bell
                                                I'm having this problem too. I'm using both Bridge CS6 32-bit and 64-bit (latest updates) on this rig:
                                                Windows 7 64-bit
                                                24GB Ram
                                                Core i7 960
                                                ATI Firepro v5800
                                                Bridge CS6 is extremely slow when opening folders i've already cached, trying to use spacebar to go to fullscreen, right-clicking files...basically all the time!
                                                I've reverted back to Bridge CS5.1 for now, i'm using the exact same settings between the two, but CS5.1 is extremely quick and reliable.
                                                Very Dissapointed!
                                                AS a side-note: I've found that Bridge CS6 64-bit does not create correct thumbnails or previews for Images & Videos that have an embedded alpha channel. 32-bit CS6 version is fine.
                                                • 21. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                                  SandraChung Level 1
                                                  I'm also launching CS5 Bridge and using it with CS6.  No more waiting for CS6 Bridge to reload thumbnails of already visited folders as if they are newly imported images.  It's a bit of a hassle to have to do this, but until Adobe answers me, or someone here on the forums comes up with a viable solution, it's the only thing I can think to do.
                                                  • 22. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                                    Level 5
                                                    AnysiaC wrote:
                                                    …until Adobe answers me, or someone here on the forums comes up with a viable solution…
                                                    If there's anything we have come to learn during years of reading this forum, that lesson is that Bridge does not get the attention and resources from Adobe that it so badly needs.
                                                    When Adobe launched Lightroom, it became apparent that Bridge would be further relegated to the back burner.
                                                    Up until this version, CS6, the worst version of Bridge had been the one that came with CS3.
                                                    What I'm trying to tell you is don't hold your breath waiting for Adobe to respond in a meaningful way.
                                                    • 23. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                                      SandraChung Level 1
                                                      Not planning to hold my breath. I look good in blue, but don't think I would look good cadaver blue.
                                                      • 24. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                                        narikin Level 1
                                                        I've had the same problem for a year or two now. Bridge CS6 (& CS4 before that) ridiculously slow, thinking its building thumbnails, when they are already there in exported cache. (Win 7/64, 24Gb RAM)
                                                        Open Bridge and everything is quick and instant. however, navigate to another folder you've regularly uised prior, which you know has cache built, 99% of the time it balks/stalls with spinning wheels, like its building cache over again. though it never appears to finish that.  BUT if you close bridge while on this stalled folder, then re-open, it immediately recognises the existing cache and all previews are present. Bingo. That is my sad work-around at present. choose new folder. close bridge. reopen.
                                                        Yes, all cache is stored and exported to folders.
                                                        I've given up on Adobe ever fixing this. Been looking for an answer for 3 years now, but they just don't care or read the problems people are having. Give us your money and go away seems to be their answer.
                                                        • 25. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                                          Alphageek_Ps
                                                          Hi Sandra,
                                                          This may or not be connected, but I too had Bridge CS6 begin to run like a snail, with all the problems you mentioned, and "white screen" (not responding), minutes instead of seconds to display thumbnails. Then,.... I noticed I had a video (CD) in my onboard DVD/CD, and that the access light was going crazy.
                                                          Removed the video, and bingo, all problems dissappeared. Put another CD with just files, not video, and problems reappeared.
                                                          Don't know if there is a way to exclude DVD/CD drives from the indexing function, but for now, Bridge CS6 is running as fast as when first installed.
                                                          • 26. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                                            SandraChung Level 1
                                                            I'm glad that solved the problem for you, but I had no discs, video or otherwise, in either of the drives. I even went so far as to unplug external drives/devices to see if that would speed it up. No joy.
                                                            • 27. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
                                                              SandraChung Level 1
                                                              I tried your solution, and there was no difference in loading speed.  :-/  Thank you, though.
                                                              I could understand the glacial slowness if the beta version had also been so slow. Or if CS5 Bridge was also as slow.
                                                              • 28. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        Omke Oudeman Level 5
        Did not read this whole (long) thread but in general when a previous version of Bridge did work faster then the following this almost certainly is related to your system itself.
        While building criteria in filter panel has a mind of its own and especially when opening a second window to fast (when first window is just finished caching or building filter panel) it may take ages. closing this window and open a new one usually succeeds.
        However when this always takes a long time the problem seems related to the cache (most Bridge problems are...)
        Purging cache using preferences or menu commands is not always the correct solution. Using Bridge CS5 and PS CS6 is also not the perfect solution.
        If you can spare the time you should consider a proper back up of custom settings, actions tools, keywords, templates etc. and a complete reinstall.
        I don't have the correct info for Windows and searching on Adobe.com isn't easy anymore. Here are some old Knowledge base articles (it's about CS4 but changes are locations are still the same)
        http://helpx.adobe.com/photoshop/kb/move-actions-presets-workspaces-photoshop.html
        http://helpx.adobe.com/photoshop/kb/preference-file-functions-names-locations-1.html
        and also read about the Adobe Cleaner Tool and decide if this is an option for you.
        http://www.adobe.com/support/contact/cscleanertool.html
        If you decide to reinstall:
        Deactivate the software and use the official uninstaller that comes with the application itself and then use the clean tool for Adobe:
        Double check if your Cache folder has been deleted (I'm on Mac, don't know the location for Windows but on Mac it is in the user library caches folder)
        Install CS6 again. Obvious you have to set your custom preferences again and also need to recache your files but if you have a main folder with many subfolders containing the files just select the main folder and in the menu View select 'show items for subfolders' and let it do it's caching overnight.
        In my experience every new version of CS has been faster and more stable (well, except the disaster CS3 version for Bridge...) then its predecessor.
        • 29. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        SandraChung Level 1
        Seeing as my 'system' is the same one I ran the beta version, your idea of that it's the computer has no basis.  And, seeing as this system is twice the machine in resources, memory, CPU/GPU that CS5 was running on (Core 2 Duo), makes your statement kind of silly.
        As for uninstalling and reinstalling: I've spent days doing all the above (deactivating, uninstalling, reinstalling, activating, the most recent attempt was on a high end Sony Vaio i7 laptop, with 16gb ram), deleting the cache folder, on three different computers, different specfications/hardware, two running 64bit (both i7) , one running 32bit (Core 2 Duo)Windows 7, each computer had a minimum of 8 gigs ram, max of 24 gigs, and nothing changed. Glacially slow.  And I'm not the only one, and this isn't the only forum with pages of this issue listed.
        Disable spyware scanner? done
        Disable virus scanner? Done
        Disable Malware Protection? Done
        Exacts same settings as in CS5? Done
        Step Taken:
        Deactivated, Uninstalled, deleted Cache folder.
        Reinstalled. Activated. Started it up, loaded bridge, picked folder with 483  images. Waited close to 10 minutes. Closed Bridge, Closed photoshope.  Reopened PS and Bridge on the same folder.. and again slow slow slow load.
        Checked cache folder: all thumbnails were there.
        Purge the cache and try again? Did it, no change.
        Use embedded JPGs? Did.. no change
        Show Items for subfolders? Did it, no change
        I know the easiest thing is to to blame the user, or the user's computer set up, but sorry, you're way off.
        I know using CS5 Bridge isn't a perfect solution. If I try to open a JPG in ACR via right clicking, I get the "Missing Parent Program" error message. This isn't a huge problem, as I tend to work with CR2 and other RAW formats. As for Photoshop itself being stable, no problem, but this issue with Bridge needs to be rectified.  Instead of trying to fix the blame, the problem is what needs to be fixed.
        • 30. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        Maybe I did not express my self well and sorry you feel offended.
        I only wanted to point to your system as in the way of some old files or prefs or cache interfering with each other, not to blame you but just pointing to the possible way your problem might lie.
        Also said, I'm on Mac and no next to nothing about PC. I leave it to the PC experts.
        • 31. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        SandraChung Level 1
        • Maybe I did not express my self well and sorry you feel offended.
        No, no, I wasn't offended. Frustrated, yes, but not offended.  I've done everything possible about it.
        Also, it's not just PC users that are having this problem. I'm on another forum where there is over a dozen Mac users having the same problem. Makes me wonder how many other CS6 users, ones who didn't use the previous version, just accept the slowness as normal.
        • 32. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        Well, that was my point, it is not normal behavior for Bridge CS6 to be slow, for me it works faster then CS5 on a Mac
        Via iPhone
        Regards
        Omke
        • 33. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        One other thought, you state to also have tried with export cache.
        For me the option to export cache when possible has always resulted in a warning message with 'problem writing CacheT' and I have never used it since long (by default it is set to off in the preferences).
        The fact that every cycle of Bridge uses different cache type or method also did not help to convince me of the pro's of writing cache to folders. If I have to look shortly I prefer the 'prefer embedded' quality option that provides visible thumbnail, just good enough to find what you are looking for.
        So now I wonder if you still have left some cache and old cache files in this folder that might be causing your problems in speed.
        If you look at a problem folder and choose show hidden files in the menu view this will reveal all files, including cache files in the folder itself.
        Since you use CR2 there will also appear a lot of XMP side car files for the raw files but especially look for files with a blank document icon showing.
        Can you tell what different hidden files are showing?
        • 34. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        redcrown on guard
        I believe the issue discussed here is related to a Bridge CS6 re-caching problem I first reported in this thread:
        http://forums.adobe.com/message/4421310#4421310
        And claimed it still exists after the latest (and first) update here:
        http://forums.adobe.com/message/4739441#4739441
        My tests indicated the re-caching problem was caused only by layered tif files. Yet the OP of this discussion implies that there may be other causes, i.e., other file types that cause the re-caching, but I'm not sure. For the OP, can you verify that your system repeatedly re-caches or rebuilds criteria on a folder of jpeg only images.
        • 35. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        SandraChung Level 1
        I did my system is always set to show hidden files. Also, I do know about the XMP side car files. Since there seems to be chewing of old soup here, or just missing things:
        1: Even if I haven't done a single edit on any of the CR2, RAW or ORF files, just opening a folder with them freshly imported from the CF or SD card, closing bridge, then opening it again, it's slow.
        2: If I've done edits, said CR2/RAW/ORF files, close PS and Bridge, re-open PS and then bridge on that folder, it's slow.
        3: If I open on folder of nothing but jpgs in Bridge, it's slow.
        After each attempt of every variety, when the thumbnails are built, when I close PS and bridge, reopen on that recently visited folder, it still behaving as if it's a newly imported folder.
        As to the cache: I have, with each deactivation, unistall, reinstall, reactivation,  tried every setting with each.  I purged, exported to thumbnails. No joy.  I've manually deleted (holding shift while pressing del to permanently delete the cache), opened folder, waiting for the first import reading, closed bridge, opened again on that same folder, and guess what? Still slow, as if it's a newly imported group. I've tried embedding edit data in the camera raw, and I've tried side car. Still slow.
        Since this problem didn't happen with CS5, I even tried duplicating the same settings, other than the same cache file folders of course, and still slow.
        During the mulitple deactivations, unistalls, reinstalls, reactivations, I have tried every trouble shooting idea/suggestion/method.
        • 36. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        SandraChung Level 1
        I can verify it's re-building criteria on folders with just jpgs.  And no, the bridge update has not corrected the issue.  I had thought that maybe cache was corrupted somehows, so purged it. Nothing changed, still CS6 Bridge is snail's pace slow.
        thanks for the links, but I'd already checked those as possible solutions.
        • 37. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        brightboxcreative
        Has anyone found a solution to this miserable mess? I'm about ready to uninstall all CS6 before I loose my temper and accidently put my hand through my nice Cinema Display!
        PSD, if I ope more than 10 files at once, I'm asking for it, even 1mb files.
        InDesign? Good grief! I feel like I've never used the damn program before and I've been using for years and years.
        Bridge? Its just miserable.
        • 38. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        SandraChung Level 1
        That's why I ended up using CS5 bridge while using CS6 Photoshop. Not a perfect solution, but it does work.  I could understand if the beta version, "Superstition" was equally slow, but it wasn't.
        I feel that Adobe just doesn't care. They have our money, we just get to put up with it.
        • 39. Re: CS6 E Bridge Slow to load thumbnails, 'building criteria'
        Level 5
        SandraChung wrote:
        ...Adobe just doesn't care. They have our money, we just get to put up with it.
        That's a succinct and accurate description of reality.
        1 2 3 Previous Next
