compiled file does not function
Jun 19, 2012 Jun 19, 2012
Here it is again: Warning: The size of stop file has to be limited in 512 bytes. Working in RH9 (corporate desktop). Have been generating this project file fine for a week, but started getting the relentless "stop file...512 bytes" message. The file is generated but the executable file opens to a frozen front screen. Please help.
733
The Stop message always appears regardless of whether the file is under or over the size. Ignore it unless you have created a truly massive Stop list.
It's almost impossible to help you with that amount of information. Please read the Before You Post sticky topic. Are you using RoboHelp HTML or RoboHelp for Word and which version?
Is you project local?
What executable file? In other words, what sort of help are you creating? A CHM, WebHelp or what?
Where are you generating to, local drive or network?
I'm guessing you are generating a CHM to a network drive or moving it there. Correct?
@petergrainge
Jun 20, 2012 Jun 20, 2012
Sent: June 20, 2012 02:30
To: Livingstone, Lloyd
Subject: compiled file does not function
Re: compiled file does not function
created by Peter Grainge <http://forums.adobe.com/people/Peter+Grainge> in RoboHelp - View the full discussion <http://forums.adobe.com/message/4506542#4506542
@ttcuser - your response didn't post - try again using the web interface of the forum
Using RH9 HTML
Not local.
Generating MS HTML file.
To corporate network drive.
Sorry for vagueness earlier. Not fully tech savvy, obviously.
Could space or memory be an issue?
Got a couple of problems there - your project needs to be local (c:\projects\{project_name}\ ) - RH doesn't play well over networks; generating your .chm locally and then copying it will work better, but you still can run into security issues when you try to run it (depends on where it's going to live).
CHMs on a network drive are a known issue. See http://www.grainge.org/pages/authoring/chm_mspatch/896358.htm
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
