Help with a whiteboard!
Jun 19, 2012 Jun 19, 2012
Hello, I am making a whiteboard math app.  The program has a whiteboard in the middle and the top and bottom of the program have a bar that will have various buttons and text fields for displaying the question, entering an answer, help, and the person's score.  I have pretty much everything working how I want it except that the "pen" for the whiteboard writes all over the top and bottom bars, buttons, text fields, etc.  How do I stop this?  The top and botttom bars are movie clips named "top" and "bottom" if that helps.
Here is the code:
import flash.display.MovieClip;
import flash.events.MouseEvent;
var lines:MovieClip;
var isMoving:Boolean = false;
var linesColor:Number = 0x000000;
var linesSize:uint = 1;
var equations:Array = new Array;
var equationsAnswers:Array = new Array;
var score:uint = 0;
var questionsAsked:uint = 0;
var answer:String = new String;
equations = ["x + 7 = 13", "x - 8 = 23"];
equationsAnswers = ["6", "31"];
lines = new MovieClip();
stage.addEventListener(MouseEvent.MOUSE_DOWN, startLines);
stage.addEventListener(MouseEvent.MOUSE_MOVE, drawLines);
stage.addEventListener(MouseEvent.MOUSE_UP, stopLines);
checkbtn.addEventListener(MouseEvent.CLICK, newquestion);
stage.addChild(lines);
function startLines(e:MouseEvent) : void {
    isMoving = true;
    lines.graphics.lineStyle(linesSize, linesColor, 1.0);
    lines.graphics.moveTo(mouseX, mouseY);
function drawLines(e:MouseEvent):void {
    if (isMoving){
        lines.graphics.lineTo(mouseX, mouseY);
function stopLines(e:MouseEvent):void {
    isMoving = false;
function newquestion(e:MouseEvent):void {
    answer = inputAnswer.text;
    if (answer == equationsAnswers[questionsAsked]){
        score ++;
    questionsAsked++;
    scoreshow.text = score + ":" + questionsAsked;
    question.text = equations[questionsAsked];
    inputAnswer.text = "";
Any help would be very appreciated!
ActionScript
1.7K
Enthusiast , Jun 20, 2012 Jun 20, 2012
stage.addChild(drawable);
you need add to the stage the Movieclip named drawable
var score:uint=0;
var questionsAsked:uint=0;
var answer:String=new String();
var drawable:MovieClip=new MovieClip();
equations=["x + 7 = 13","x - 8 = 23"];
equationsAnswers=["6","31"];
Enthusiast ,
Ypu can create a MovieClip to get inside the "lines" an the use a mask to show only the "drawable" area
drawable.addChild(lines);
drawable.mask=maskWhiteboard
(maskWhiteboard is other Movie Clip)
Thank you for the reply.  maskWhiteboard is which  other movie clip?  I'm a little confused
Enthusiast ,
maskWhiteboard is a movieclip that you create with the size and shape of the area where you can draw, excluding your buttons
Thank you again.  However, when I do this, it won't draw anywhere.  I put a new movie clip on the stage with an instance name of whiteboardMask.  Then, I put the code, changing it to whiteboardMask instead of maskWhiteboard.  Now, when I test it, it will not draw anywhere.
var score:uint = 0;
var drawable:MovieClip = new MovieClip;
drawable.mask=whiteboardMask;
    isMoving = true;
    if (isMoving){
    isMoving = false;
        score ++;
    questionsAsked++;
Any help would be appreciated.
Enthusiast ,
var score:uint=0;
function startLines(e:MouseEvent):void {
    isMoving=true;
    if (isMoving) {
    isMoving=false;
    answer=inputAnswer.text;
    if (answer == equationsAnswers[questionsAsked]) {
        score++;
    questionsAsked++;
    scoreshow.text=score+":"+questionsAsked;
    question.text=equations[questionsAsked];
    inputAnswer.text="";
thank you, I'm an idiot.
It works perfectly now.
Enthusiast ,
you're welcome
It's just a detail that went unnoticed
Jun 27, 2012 Jun 27, 2012
Thank you again.  Is there an easy way to erase the entire whiteboard?  to get rid of all the "lines" on the whiteboard?
Enthusiast ,
Thank you. WOW again I completely miss the obvious.
Enthusiast ,
do not worry sometimes happens
