11 Replies Latest reply on Jun 27, 2012 3:52 PM by esdebon
    Help with a whiteboard!
    jerm8352
      Hello, I am making a whiteboard math app.  The program has a whiteboard in the middle and the top and bottom of the program have a bar that will have various buttons and text fields for displaying the question, entering an answer, help, and the person's score.  I have pretty much everything working how I want it except that the "pen" for the whiteboard writes all over the top and bottom bars, buttons, text fields, etc.  How do I stop this?  The top and botttom bars are movie clips named "top" and "bottom" if that helps.
      Here is the code:
      import flash.display.MovieClip;
      import flash.events.MouseEvent;
      var lines:MovieClip;
      var isMoving:Boolean = false;
      var linesColor:Number = 0x000000;
      var linesSize:uint = 1;
      var equations:Array = new Array;
      var equationsAnswers:Array = new Array;
      var score:uint = 0;
      var questionsAsked:uint = 0;
      var answer:String = new String;
      equations = ["x + 7 = 13", "x - 8 = 23"];
      equationsAnswers = ["6", "31"];
      lines = new MovieClip();
      stage.addEventListener(MouseEvent.MOUSE_DOWN, startLines);
      stage.addEventListener(MouseEvent.MOUSE_MOVE, drawLines);
      stage.addEventListener(MouseEvent.MOUSE_UP, stopLines);
      checkbtn.addEventListener(MouseEvent.CLICK, newquestion);
      stage.addChild(lines);
      function startLines(e:MouseEvent) : void {
          isMoving = true;
          lines.graphics.lineStyle(linesSize, linesColor, 1.0);
          lines.graphics.moveTo(mouseX, mouseY);
      function drawLines(e:MouseEvent):void {
          if (isMoving){
              lines.graphics.lineTo(mouseX, mouseY);
      function stopLines(e:MouseEvent):void {
          isMoving = false;
      function newquestion(e:MouseEvent):void {
          answer = inputAnswer.text;
          if (answer == equationsAnswers[questionsAsked]){
              score ++;
          questionsAsked++;
          scoreshow.text = score + ":" + questionsAsked;
          question.text = equations[questionsAsked];
          inputAnswer.text = "";
      Any help would be very appreciated!
        • 1. Re: Help with a whiteboard!
          esdebon Level 4
          Ypu can create a MovieClip to get inside the "lines" an the use a mask to show only the "drawable" area
          var drawable:MovieClip=new MovieClip();
          drawable.addChild(lines);
          drawable.mask=maskWhiteboard
          (maskWhiteboard is other Movie Clip)
          • 2. Re: Help with a whiteboard!
            jerm8352 Level 1
            Thank you for the reply.  maskWhiteboard is which  other movie clip?  I'm a little confused
            • 3. Re: Help with a whiteboard!
              esdebon Level 4
              maskWhiteboard is a movieclip that you create with the size and shape of the area where you can draw, excluding your buttons
              • 4. Re: Help with a whiteboard!
                jerm8352 Level 1
                Thank you again.  However, when I do this, it won't draw anywhere.  I put a new movie clip on the stage with an instance name of whiteboardMask.  Then, I put the code, changing it to whiteboardMask instead of maskWhiteboard.  Now, when I test it, it will not draw anywhere.
                var score:uint = 0;
                var drawable:MovieClip = new MovieClip;
                drawable.mask=whiteboardMask;
                    isMoving = true;
                    if (isMoving){
                    isMoving = false;
                        score ++;
                    questionsAsked++;
                Any help would be appreciated.
                • 5. Re: Help with a whiteboard!
                  esdebon Level 4
                  stage.addChild(drawable);
                  you need add to the stage the Movieclip named drawable
                  var score:uint=0;
                  var questionsAsked:uint=0;
                  var answer:String=new String();
                  equations=["x + 7 = 13","x - 8 = 23"];
                  equationsAnswers=["6","31"];
                  function startLines(e:MouseEvent):void {
                      isMoving=true;
                      if (isMoving) {
                      isMoving=false;
                      answer=inputAnswer.text;
                      if (answer == equationsAnswers[questionsAsked]) {
                          score++;
                      questionsAsked++;
                      scoreshow.text=score+":"+questionsAsked;
                      question.text=equations[questionsAsked];
                      inputAnswer.text="";
                  • 6. Re: Help with a whiteboard!
                    jerm8352 Level 1
                    thank you, I'm an idiot.
                    It works perfectly now.
                    • 7. Re: Help with a whiteboard!
                      esdebon Level 4
                      you're welcome
                      It's just a detail that went unnoticed
                      • 8. Re: Help with a whiteboard!
                        jerm8352 Level 1
                        Thank you again.  Is there an easy way to erase the entire whiteboard?  to get rid of all the "lines" on the whiteboard?
                        • 9. Re: Help with a whiteboard!
                          esdebon Level 4
                          • 10. Re: Help with a whiteboard!
                            jerm8352 Level 1
                            Thank you. WOW again I completely miss the obvious.
                            • 11. Re: Help with a whiteboard!
                              esdebon Level 4
                              do not worry sometimes happens
