24 Replies Latest reply on Jun 23, 2012 6:57 PM by CarlosCanto
    How to Snap
    jarlabs
      Hi everyone,
      I am newbie here.
      Can someone please tell me how to snap such as the attached image?
      Please notify me by email when there is a reply.
      Thank you
      Jarlabs
      http://s11.postimage.org/eznfpmu83/Adobe_Illustrator.png
        • 1. Re: How to Snap
          MikeGondek Adobe Community Professional & MVP
          From your screen shot, looks like you want to know how to distort a transformation not snap.
          1. Select your object to transform
          2. Select the Free transform tool
          3. Begin to drag the bottom right handle, keep holding down the mouse button
          4. Add shift to constrain angle of drag to interval of 45°, add CMD(or CTRL on PC) key to free transform that corner only
          5. pull then release mouse button when ready
          • 2. Re: How to Snap
            jarlabs Level 1
            Hi Mike Gondek,
            Thank you very much for your help.
            However, I still can not snap the four corners of the ellipse to the four corners of the rectangle because when I try to snap one corner of the ellipse to the one corner of the rectangle, the other corners are moving too, won't fix at their position.
            Can you please tell me more detail about it?
            Thank you
            Jarlabs
            • 3. Re: How to Snap
              emil emil Level 4
              Turn the smart guides on (Ctrl + U) and refer to the image below. In the last step, after you start dragging with the Free Transform tool (E) the lower right point of the transform box, hold Ctrl to engage the free transform.
              • 4. Re: How to Snap
                jarlabs Level 1
                I still can not snap the four corners of the ellipse to the four corners of the rectangle.
                If I pull one corner of the ellipse, the other corners are moving too.
                The edge doesn't want to be an oblique edge instead of keep straight.
                Can you please tell me this by step-by-step and ordered?
                • 5. Re: How to Snap
                  emil emil Level 4
                  From the View menu make sure the Smart Guides are checked.
                  With the Selection tools (black  pointer) click anywhere on the ellipse and try to position it as shown in the first step from my previous message. Drop the ellipse when the Smart Guides say  "intersect" as shown in the image.
                  Click and drag the bottom left point of the transform box of the ellipse  to the cursor position  shown in the second step. Drop it when the Smart Guides say "anchor"
                  Pick the Free Transform tool (as shown in the image below), click and drag the bottom right point of the transform box of the ellipse to the cursor position  shown in the third step. Hold Ctrl key before (while) dropping and make sure the Smart Guides say "anchor"
                  http://digitalartanddesign.org/assets/illustrator/images/free-transform.jpg
                  • 6. Re: How to Snap
                    jarlabs Level 1
                    Hi emil emil,
                    I appreciate your help.
                    However, it still doesn't works.
                    This is what it looks like when I use the Free Transform Tool and holding the ctrl button:
                    http://s18.postimage.org/iotuorqcp/Snap1.png
                    And this is what it looks like when I release the ctrl button:
                    http://s14.postimage.org/wwlbvf4a9/Snap2.png
                    What should I do next?
                    Jarlabs
                    • 7. Re: How to Snap
                      emil emil Level 4
                      my instructions were valid for the shapes and scenario shown in the image in your original post. Did you try that?  Your last post shows that you are doing something quite different. In this case you can't use the same steps and approach.
                      Also when using the Free Transform tool you don't release the Ctrl button before releasing the mouse button if you want to retain the free transformation.
                      For your last case, I would put a box fitting around the ellipse and manipulate them together using the box as a guide for the Free Transform tool. Snapping is not possible in this case but with a few adjustments you can reshape the box and the containing ellipse to fit in the target shape.
                      Another way is to use Envelope distorted made with a Mesh but while this can give you precise snapping of the corners of the box to the corners of the target shape, the ellipse itself will be reshaped by the length of the handles which takes more manual adjustments and subjective shape decision to make the deformation. For this reason I would use the first method.
                      • 8. Re: How to Snap
                        jarlabs Level 1
                        Hi emil emil,
                        I am 100% sure that I already follow your instruction correctly.
                        Yes, I am not release the ctrl button before release the mouse button when using the Free Transform Tool.
                        What I would like to do is to fit the box around the ellipse, to the rectangle.
                        However, it still doesn't work.
                        Btw, I am using the Adobe Illustrator CS3.
                        Jarlabs
                        • 9. Re: How to Snap
                          [scott] Level 6
                          Free Transform tool.... click a handle, THEN hold down CTRL, THEN move the handle. You have to do it in that specific order for it to work.
                          • 10. Re: How to Snap
                            emil emil Level 4
                            Scott, in post #6 jarlabs shows in the images that there is no problem with engaging the free transformation but with retaining it when releasing the mouse.
                            Jarlabs, I'm running out of ideas how to help, it works fine here.
                            • 11. Re: How to Snap
                              Monika Gause Adobe Community Professional & MVP
                              • 12. Re: How to Snap
                                [scott] Level 6
                                Missed that.
                                If things "snap back to position" when trying to free transform it means one of two things....
                                1) You're trying to free transform a raster image. You can't.
                                2) You're trying to free transform Live Type. You can't.
                                In either case.. do this.....
                                First select the image or the live type with the Selection Tool.
                                Choose Object > Envelope Distort > Make with Mesh.
                                Insert 1 row and 1 column and click OK.
                                Now you can use the Free Transform Tool on the envelope (which contains the raster image or the live type)
                                You can edit the contents later if needed via Object > Envelope Distort > Edit Contents.
                                Also, reviewing post #6 it appears that the standard bounding box is being used, not hte Free Transform tool. Be certain you are using the Free Trnasform tool (hit e on the keyboard)
                                • 13. Re: How to Snap
                                  jarlabs Level 1
                                  Below tutorial is too complicated for me:
                                  http://www.automotiveillustrations.com/tutorials/adobe-illustrator-free-transform-tool.htm l
                                  I can not follow it.
                                  Does anyone here can explain me in the simple way?
                                  • 14. Re: How to Snap
                                    JETalmage Level 6
                                    This is what it looks like when I use the Free Transform Tool and holding the ctrl button....And this is what it looks like when I release the ctrl button:
                                    You have to release things in the correct order, too.
                                    1. Mousedown on the corner you want to move.
                                    2. Press and hold Ctrl.
                                    3. Move it.
                                    4. Release tthe mouse button, then release the key.
                                    JET
                                    • 15. Re: How to Snap
                                      jarlabs Level 1
                                      It still doesn't work.
                                      • 16. Re: How to Snap
                                        Larry G. Schneider Adobe Community Professional & MVP
                                        Try this...   Go to the View Menu and look for Hide Bounding Box. If it's there, click on that line so it says Show Bounding Box. Go back to your file and select your object. There should be no corner or side adjusting boxes visible, just the small anchor points. Hit the e-key on your keyboard. A new set of selection boxes should appear. Then follow JET's instructions above.
                                        • 17. Re: How to Snap
                                          jarlabs Level 1
                                          I am looking for some help.
                                          It looks like you guys are trying to toying with me.
                                          • 18. Re: How to Snap
                                            To us it looks like you are toying with us.
                                            What exactly are you doing? Please describe every single step.
                                            what exactly are you expecting to achieve?
                                            What exactly does not work?
                                            Can you post a screenshot of your results?
                                            and have you thought about taking classes to learn this stuff?
                                            • 19. Re: How to Snap
                                              No, we're trying to help but without seeing what you have and what you are doing we are shooting blind. What don't you understand about the tutorial you referenced or did you try the one that Monica suggested?
                                              • 20. Re: How to Snap
                                                CarlosCanto Adobe Community Professional & MVP
                                                jarlabs wrote:
                                                Hi everyone,
                                                I am newbie here.
                                                you've been given plenty of help here...if you can't follow, as a newbie, you should try to walk before you attempt to run. Start by reading the help files, you need to put some effort if you want to learn.
                                                • 21. Re: How to Snap
                                                  jarlabs Level 1
                                                  If you guys can not describe it as a word and sentence, do you mind to provide it by using a video clip?
                                                  • 22. Re: How to Snap
                                                    Try Lynda.com. Plenty of Illustrator online courses there.
                                                    • 23. Re: How to Snap
                                                      jarlabs Level 1
                                                      Excuse me, but, I am looking for the one that free-of-charge.
                                                      • 24. Re: How to Snap
                                                        hahaha, ok try this underground site, only known to hardcore illustrator users, and of course free of charge
                                                        http://www.youtube.com/watch?v=oGRz7mPhv7Q
                                                        ...anything else? coffe? ice cream?
