1. Re: Folio Builder keeps telling me I do not have a compatible Plugin
BobLevine Jun 21, 2012 5:46 AM (in response to Macnimation)These things need to be installed in the default location. You can’t just put them anywhere.
Bob
2. Re: Folio Builder keeps telling me I do not have a compatible Plugin
Anil@Siemens Jun 21, 2012 7:27 AM (in response to BobLevine)Now what is the solution except re-install again on "C:\" drive? There are lots of end user who works on two different OS in one machine. Please suggest on the solution side. Thanks in advance
3. Re: Folio Builder keeps telling me I do not have a compatible Plugin
Bob Bringhurst - Adobe Jun 21, 2012 7:40 AM (in response to Anil@Siemens)Try solution 2 in this tech note: http://helpx.adobe.com/digital-publishing-suite/kb/error-do-have-compatible-digital.html
4. Re: Folio Builder keeps telling me I do not have a compatible Plugin
Anil@Siemens Jun 21, 2012 8:01 AM (in response to Bob Bringhurst - Adobe)Thanks a lot Bob Bringhurst!
I'll check this when I'll be at home and get back to you in case of any problem. Once again thanks!
5. Re: Folio Builder keeps telling me I do not have a compatible Plugin
robtaylo@adobe.com Jun 22, 2012 11:16 AM (in response to Macnimation)"Indesign CS5 is installed on the D Drive, but I install the two files to the default C drive, could this be the issue?"
Yes, it is the issue. When installing Folio Producer Tools, you must select the folder and drive in which InDesign is installed if it is not the default location where Windows installs applications: C:\Program Files (x86 if on x64). If you just click buttons and select defaults the installer will default to the C:\Program Files (x86 if on x64) directory.
We do not at this time have the ability to detect where CS5.x is installed.
