16 Replies Latest reply on Nov 3, 2014 11:35 PM by JopWheelz
    Flash Pro CS6 - not enough JVM memory - change 128 to 256, flash doesn't start.
    Filippo Gregoretti
      working on very large projects, I often get the "flash ran out of memory for the jvm" error.
      Restarting flash does the trick for another couple of hours, until I get that error again.
      It opens the jvm.ini file to let me increase Xmx memory value.
      I change it from -Xmx128m to -Xmx256m
      I restart flash, get the error: "Error initializing Java Runtime environment. You may need to reinstall Flash"
      I change it back to -Xmx128m, and flash starts again.
      But obviously, I again get the "not enough memory" error.
      Am I doing something wrong?
      after installing Flash Pro CS6, previously installed Flash Pro CS5.5 does not start, gives me the JVM initialization error all the time, regardless of which Xmx value I put for CS5.5
