5 Replies Latest reply on Jun 22, 2012 7:06 AM by Jeffrey54 Lane
    drop down menu
    Jeffrey54 Lane Level 1
      Hi I have an harisontal spry bar, and in Firefox and Chrome UK in IE when you go to the more links button the drop down menu opens over the top of an image rotator and as the image start to fade so dose the drop down menu, this as probrsbly been happening for some time but I have only just noticed it, can anyone help please. Thanks Jeff
      http://petsalive.net
        • 1. Re: drop down menu
          BenPleysier Adobe Community Professional & MVP
          I think it better to find a solution here http://www.projectseven.com/support/forums.htm
          Gramps
          • 2. Re: drop down menu
            ALsp Adobe Community Professional
            It seems fine to me in IE9 in stadards mode and in compatibility mode. The menu you are using is an Adobe Spry menu so I'm not sure why anyone on this forum would not want to help you. If anything it is a simple z-index problem - though I cann duplicate it. If you still have problems send us a direct mail or telephone us and I'll try to duplicate your issue and give you a correct solution.
            Al Sparber - PVII
            The Finest Dreamweaver Menus | Galleries | Widgets
            Since 1998
            • 3. Re: drop down menu
              As usual, Mr Sparber has come with the correct cause, he knows his products better than I do.
              A pity that he did not give you a solution as he is also on this forum.
              The overlay for his product shows a rediculously high z-index value.
              .p7IRM01 .overlay {
                    position: absolute;
                    left: 0px;
                   z-index: 999999;
                    padding: 6px;
                    width: 100%;
                    background-image: url(img/p7IRMDark_transtotal.gif);
                    background-color: transparent;
                    text-align: left;
              The SpryMenuBar shows a modest value
              #MenuBar.MenuBar .SubMenuVisible {/* For Horizontal menubar only */
                  top: 100%;    /* 100% is at the bottom of parent menuItemContainer */
                  left:0px; /* 'left' may need tuning depending upon borders or padding applied to menubar MenuItemContainer or MenuItem,
                                  and your personal taste.
                                  0px will left align the dropdown with the content area of the MenuItemContainer. Assuming you keep the margins 0
                                  on MenuItemContainer and MenuItem on the parent
                                  menubar, making this equal the sum of the MenuItemContainer & MenuItem padding-left will align
                                  the dropdown with the left of the menu item label.*/
                 z-index:10;
              Either increase the value for the menubar or decrease the value for the PVII widget or maybe a bit of both. In the end, the SpryMenuBar should have the higher value.
              Gramps
              • 4. Re: drop down menu
                A rediculously (sic) high z-index it is. We usually try to compensate
                for other scripts folks might use on a page and the overlay class does
                not really need one that high. That value must have gotten overlooked,
                so thanks - we'll change that in the next free update. In any event, the
                user also needs to update to the latest version to ensure optimal
                performance against known Mozilla and Webkit image handling bugs:
                http://www.projectseven.com/support/updatepages/irm.htm
                Thanks again, but you really can stop with the subtle digs. You may be
                altruistic by brand, but it would seem your heart is an entirely
                different matter. I'm not your enemy. The poster is free to contact us
                directly for a number of reasons, not the least of which to escape the
                drama that seems to be around when you, me, or my company intersect.
                This forum is still extremely tedious for me to monitor nearly as much
                as you do so I probably should have just not posted once I saw you were
                involved in the thread.
                Al Sparber - PVII
                • 5. Re: drop down menu
                  Hi Al I’ve done that and it’s working great thanks mate Jeff
