Hello,
I have written a query to retrieve some data from my
database. However, it is conditional upon my WHERE clause. The SQL
query iterates over the database records and makes a comparison.
This WHERE clause comparison consists of comparing a date/time
formatted object in a field in the Access database to a date
entered by user via a form.
The problem i am having is that i cannot format the variable
submitted via the form so that it is in the same format as the
date/time entry in the databases field. I need to convert the
string variables submitted by the user via the form to an
ODBCDATETIME i imagine using a CF function, but this didn't work
(unless i was doing something wrong).
My question is: how can i format day/month/year (e.g. 01 01
2006) form variables so that they are the in a format that can be
used to compare them to an Access date/time field variable (e.g.
.1982-07-27 00:00:00.0). N.B. All times in my Access date/time
field are equal to 00:00:00.0
Also note that i cannot simply compare a string to an Access
date/time because it will cause an execution problem within the
query.
Neil
