1. Re: Multi Camera in CS5.5 What is wrong?
JSS1138 Jun 12, 2012 7:09 PM (in response to ferdinandNGC)My best suggestion it to adjust your work flow. Always use original media, don't export out 'edits' for further use.
2. Re: Multi Camera in CS5.5 What is wrong?
ferdinandNGC Jun 13, 2012 7:10 AM (in response to JSS1138)Thanks Jim but I feel safer when I export to another HD on my system and perform the Bluray and DVD copies from one large file.
I have been working on another job and everything seems good.
My best guess is that I had difficulty not giving CS5.5 time to Index and Conform before I used the video.
3. Re: Multi Camera in CS5.5 What is wrong?
Jason R Brandt Jun 13, 2012 11:23 AM (in response to ferdinandNGC)ferdinandNGC,
I'm curious why you "feel safer" with your workflow.
I feel you're adding time and energy to your production that you don't need to. I have edited 50+ dance recitals (2 camera) with 1 project and never had any issues. If you're worried about your source footage, my suggestion is to add a backup drive to your system. (external) I have a 3TB WD My Book Live that plugs directly into my router, and does a backup once a week automatically. This keeps all of my source footage safe without taking the time export it out myself.
Just a thought, I know how dance parents can get waiting for their DVD.
4. Re: Multi Camera in CS5.5 What is wrong?
JSS1138 Jun 13, 2012 12:51 PM (in response to Jason R Brandt)I feel you're adding time and energy to your production that you don't need to.
Agreed.
5. Re: Multi Camera in CS5.5 What is wrong?
ferdinandNGC Jun 22, 2012 9:47 PM (in response to JSS1138)Jim or Jason there must be a solution or should I talk to Adobe?
Multi Camera Editing in CS5.5 will not hold edit
Jun 22, 2012 10:31 AM
This problem occurrs on two computers so I can't blame it on one CS5.5 install. When I make a multi camera edit and export the file it won't hold the settings I have chosen. Sometimes it takes the second audio track and sometimes the second video track with the first audio track. When I import the file again the settings are wrong. I have gone back and made a file again from the original setting, renamed it and it works sometimes. I don't get it! In CS3 I never had a problem holding the edit when I export it to a new file. Is this a problem with CS5.5 because I follow the same workflow I used with CS3. Any suggestion would be helpful.
Sorry I posted twice on same topic.
6. Re: Multi Camera in CS5.5 What is wrong?
ComputerNovice25 Jun 22, 2012 10:15 PM (in response to Jason R Brandt)Exporting things and then re-editing them also loses quality unless you chose a "lossless" codec. You also start running the risk of other issues such as export errors that occur sometimes etc.
7. Re: Multi Camera in CS5.5 What is wrong?
ferdinandNGC Jun 23, 2012 4:12 PM (in response to ComputerNovice25)My workflow is:
A. Do a multicam edit of for example a dance.
B. Export the finished dance and start a new Sequence for the next dance.
C. Because I use HDV tape which sometimes has drop outs I need to start a new Sequence for each dance or it would take even longer.
D. At the end I bring back all the sequences and line them up for the final product.
This has worked perfectly for me with CS3 and my Matrox RT.X2 for the past 4 years.
Now with CS5.5 I am having these new problems. I will speak to Adobe on Monday for a possible solution.
8. Re: Multi Camera in CS5.5 What is wrong?
BOSU BABU Jun 23, 2012 9:59 PM (in response to ferdinandNGC)When I make a multi camera edit and export the file it won't hold the settings I have chosen. Sometimes it takes the second audio track and sometimes the second video track with the first audio track. When I import the file again the settings are wrong.
I am a novice with no hands on experience with multicameras. However while learning from Lynda(Premer Pro cs6 Essential Trg with Abba Shapiro) I observed the following and this may be useful for selection of right audio track.
"When you select the clips,the order that you select them in your project panel is going to be the order that they are organised in this multicam source clip that you are creating, and the reason -this is important is that your primary audio is going to come from that very first selection.So whether you have 2 cameras or more,make sure you select the camera angle that has the master audio first"
9. Re: Multi Camera in CS5.5 What is wrong?
Jason R Brandt Jul 4, 2012 2:06 PM (in response to ferdinandNGC)My workflow is:
1. Import all footage (HDV)
2. Place all footage on timeline, syncing both cameras (this is for an entire show, 2 hours average duration) If I have any dropouts I find them where the audio of both tracks do not line up, so I make adjustments to the track that has the dropout and re-sync from that point on. If your second/alternative shot will not cover the dropout of the other camera, re import just the dropout section.
3. Nest into new sequence and do multicam edit
4. Close multicam and go back into the nested sequence and perform the fine edits, add titles and credits, cut out dead space, etc...
5. Export that sequence for DVD/Blu-Ray production.
For audio, I usually copy the audio from the first sequence (original) and paste it to the nested sequence after the multicam edit. Then I can choose which track of audio to use as I go, or make adjustments, etc...
I've never had any issues with cuts not holding, or audio being incorrect, with this workflow.
