4 Replies Latest reply on Jun 28, 2012 8:22 AM by tygerfarr
    if/else statement help
    tygerfarr Level 1
           This is the script that i have, and it works, I just need to add something to it.
      if  (this.rawValue == "1" && SSN.isNull) {
      SSN.mandatory = "error";
      app.alert ("Dependents 1 year and older must have a valid SSN to be eligible for Dental coverage.");
      this.rawValue == 0;
      else if (this.rawValue == 1){
      SSN.mandatory = "disabled";
      I need to make this also verify that AgeVerify field is greater than 1. if not return an unchecked box and have pop up message.
      in other words, the person has to be 1 year old and have a SSN entered in order to check the box or they get a message saying error and the box does not check.  I can't figure out the "greater than 1" code.
      Any help is greatly appreciated.
        • 1. Re: if/else statement help
          BR001 Adobe Community Professional & MVP
          I think you need something like;
          if  (this.rawValue == "1" && (SSN.isNull || AgeVerify.rawValue < 1))
              this.rawValue = 0;
          else
              if (this.rawValue == "1")
          You will probably also need to add some code in the exit event of SSN and AgeVerify so that this code also gets called if the blank out the SSN or change the Age to less than one, something like;
          CheckBox1.execEvent("click");
          Just change CheckBox1 to whatever you have called your checkbox.
          Regards
          Bruce
          • 2. Re: if/else statement help
            tygerfarr Level 1
            When i put this script in, and put like 2 weeks ago as the DOB, i still can't check the dental box unless i have a valid SSN.  If they are less than one year, we won't need a SSN.
            • 3. Re: if/else statement help
              My code was expecting the user to enter thier age in AgeVerify as a number. If they are entering the date of birth then you can calculate the age with the following code;
              var valid = false;
                  var d = /(\d\d\d\d)-(\d\d)-(\d\d)/.exec(AgeVerify.rawValue);
                  if (d !== null)
                      var dob = new Date(d[1], d[2]-1, d[3]);
                      var today = new Date();
                      var age = today.getFullYear() - dob.getFullYear();
                      var m = today.getMonth() - dob.getMonth();
                      if (m < 0 || (m === 0 && today.getDate() < dob.getDate()))
                          age--;
                      if (age >= 1)
                          if (!SSN.isNull)
                              valid = true;
                      else
                          valid = true;
              else
                  valid = true;
              if (!valid)
                  this.rawValue = 0;
              Hope that helps
              Bruce
              • 4. Re: if/else statement help
                tygerfarr Level 1
                AgeVerify has a script that calcualtes the actual age.  it is hidden in the form and only there for calculation purposes for this script.  So i suppose technically, it does contain an actual age. eg. 31
