1. Re: CS6 Bridge freeze using Homegroup network
rob_ashcroft Jun 23, 2012 10:55 PM (in response to rob_ashcroft)... and I just switched on the laptop and Bridge comes back with no problems. I can access the files in RAW folder on the laptop, no problem... So, to recap, if both machines are on then Bridge works fine and I can access anything. If I turn off the laptop then Bridge freezes, and if it's not loaded at shutdown of the laptop then I can't even start Bridge.
2. Re: CS6 Bridge freeze using Homegroup network
Curt Y Jun 24, 2012 7:58 AM (in response to rob_ashcroft)When it comes to networks I know zip. But from posts I have read what you are experiencing is normal. Bridge does search for all the pieces and if it can not find them will keep searching.
If the laptop is off, perhaps if you unplugged the desktop from the network things would work normally. If unplugged it would not consider the network pieces that it can not find.
I remember one post not too long ago where a network of many computers the user had problems using Bridge and finally discovered one computer was switched off.
Hopefully someone with network experience will chime in an give you better advice on what to do.
3. Re: CS6 Bridge freeze using Homegroup network
rob_ashcroft Jun 25, 2012 3:57 AM (in response to Curt Y)Thanks for the reply, Curt.
I have made some progress, but still don't know what's going wrong.
1. I can load CS5 Bridge OK and it works fine, even with the other PC (laptop) switched off. As soon as I try CS6 Bridge it freezes.
2. I just unistalled all of CS5 (Photoshop and Bridge). So now I just have CS6. That made no difference - still freezing on Bridge when laptop swithed off. When laptop is on, Bridge works fine. I loaded Bridge with the laptop on then switched off the laptop while Bridge still loaded. As soon as the laptop went off, Bridge stopped. When I switched laptop back on Bridge resumed working - without me touching bridge (I just watched the PC screen). Bridge is definitely trying to look at the whole of my network, and if it finds the laptop off it freezes.
3. Getting desperate... I went to my Broadband router (BT) and did a router restart with the switch on the side. That fixes it! Bridge runs OK with the laptop off. One might assume it's a router problem - but why was it working OK on CS5?
I suppose doing a router restart is an easy work-around, but it shouldn't happen. Anyone else have a problem in this area?
