Locked
How to open a native PDF file in Android using AIR?
Jun 24, 2012 Jun 24, 2012
Hello.I have created a flex mobile project to open and show a native PDF file in Android. I have tried three different methods below , but  I failed.
1. I created a stagewebview and used "stageWebView.loadURL". I can see the PDF View in emulator but it didn't work in Android Pad (SAMSUNG Galaxy Tab 10.1). It showed blank screen.
Note that I have installed AIR 3.3.
stageWebView1.loadURL(new File(new File("app:/assets/ZUGH-2P.pdf").nativePath).url);
2. I created a stagewebview and used stagewebview to load javascript. The javascript could run in emulator, but it didn't work in Android Pad. I failed again.
stageWebView1.loadURL(new File(new File("app:/assets/JavaScripthtml.html").nativePath).url);
3.  I imported stagewebviewbridge, which is the extended version of stagewebviewbridge. I created a stagewebviewbridge , but it could not run in emulator. I failed again.
stageWebViewbridge1.loadLocalURL( "appfile:/assets/pdf.html");
could any one give me some suggestions? Many thanks.
Development
7.9K
Contributor ,
Jun 25, 2012 Jun 25, 2012
I don't think Android supports that functionality.
Try opening any PDF on the web with the browser on an Android device, it will download the PDF instead of displaying it.
Adobe Employee ,
Jun 26, 2012 Jun 26, 2012
I think that @PierreSolutions is correct. Does your app exhibit that behavior (that is, does it download the PDF?) when running on the device?
Randy Nielsen
Senior Content and Community Manager
Adobe Systems Incorporated
Many thanks for your reply!
I just want to open a native PDF file rather than a remote one .
Jun 27, 2012 Jun 27, 2012
Dear jrunrandy,
I have work on this problem for a long time.But I was unable to
solve it. How can I open a native PDF file? The browser showed that
file path was incorrect. How can I  form the right file path?My
codes are below.
navigateToURL(new URLRequest("app:/assets/ZUGH-2P.pdf"),"_blank");
It worked very well in emulator, but failed in Android Pad.
I noticed that you are an employee of  Adobe company.
Could you please give me some suggestion in detail? Thank you very
much.
Adobe Employee ,
@peterpan_cafuc,
Sorry to say that I'm not sure of the answer, either.
One suggestion would be to try something like File.openWithDefaultApplication(), although I've never tried it on mobile.
Also, I poked around stackoverflow, and it looks like people have done this using Android Intents, but you might have to use a Native Extension  to do this in AIR.
Apologies that I can't be more helpful.
-Randy
Dear Randy,
I have tried the methods above, but failed.
Thank you for your help anyway.
Peter Pan
Guest
Sep 21, 2012 Sep 21, 2012
Has anybody found a solution to this problem? Thanks, Neil
Contributor ,
I think the solution is an Android Native Extension to which you pass the path and file name. It would in turn call Android's file handling routines which would trigger the dialog asking which application should be used ... or if one was already associated with that file type, it would launch it.
Contributor ,
Sep 26, 2012 Sep 26, 2012
I found such an extension here http://activeden.net/item/document-launcher-native-extension-for-android/2015733 I have not tried it and can't vouch for it, but it seems to do what you are looking for.
Mar 08, 2014 Mar 08, 2014
I know it has been a very long time, but air on android still does not allow PDFs opening on the device. I have used the above ane and just wanted to provide an update for anyone else seeking info..
That ane does open PDF files as long as there is a reader available. It is also very easy to implement using two lines of code, or two lines and a basic function to tell the user that it needs a reader installed.
Thanks a lot!
I have tried your method, and I used "navigateToURL" to open the web with the browser. I could open a remote PDF file in http website.
Unfortunately, I could not open the native PDF file.
The codes are below.
It worked well in emulator, but failed in Android Pad. The OS alerted "file path error".
Is anything wrong in my codes?
