Hi all
I have the following code, how can I cfloop and dynamically output this info instead of having to have each meeting time? Thanks
<cfselect name="MEETINGTIME" width="90" label="Time"onchange="UsersGrid.dataProvider.editField(UsersGrid.selectedIndex, 'MEETINGTIME', MEETINGTIME.selectedItem.data);">
<option value="None">None</OPTION>
<option value="05:30 AM">05:30 AM</option>
<option value="06:00 AM">06:00 AM</option>
<option value="06:30 AM">06:30 AM</option>
<option value="07:00 AM">07:00 AM</option>
<option value="07:30 AM">07:30 AM</option>
<option value="08:00 AM">08:00 AM</option>
<option value="08:30 AM">08:30 AM</option>
<option value="09:00 AM">09:00 AM</option>
<option value="09:30 AM">09:30 AM</option>
<option value="10:00 AM">10:00 AM</option>
<option value="10:30 AM">10:30 AM</option>
<option value="11:00 AM">11:00 AM</option>
<option value="11:30 AM">11:30 AM</option>
<option value="12:00 AM">12:00 AM</option>
<option value="12:30 AM">12:30 AM</option>
<option value="01:00 AM">01:00 AM</option>
<option value="12:00 PM">12:00 PM</option>
<option value="12:30 PM">12:30 PM</option>
<option value="01:00 PM">01:00 PM</option>
<option value="01:30 PM">01:30 PM</option>
<option value="02:00 PM">02:00 PM</option>
<option value="02:30 PM">02:30 PM</option>
<option value="03:00 PM">03:00 PM</option>
<option value="03:30 PM">03:30 PM</option>
<option value="04:00 PM">04:00 PM</option>
<option value="04:30 PM">04:30 PM</option>
<option value="05:00 PM">05:00 PM</option>
<option value="05:30 PM">05:30 PM</option>
<option value="06:00 PM">06:00 PM</option>
<option value="06:30 PM">06:30 PM</option>
<option value="07:00 PM">07:00 PM</option>
<option value="07:30 PM">07:30 PM</option>
<option value="08:00 PM">08:00 PM</option>
<option value="08:30 PM">08:30 PM</option>
<option value="09:00 PM">09:00 PM</option>
<option value="09:30 PM">09:30 PM</option>
<option value="10:00 PM">10:00 PM</option>
<option value="10:30 PM">10:30 PM</option>
<option value="11:00 PM">11:00 PM</option>
<option value="11:30 PM">11:30 PM</option>
</cfselect>
I get all the times in half hour intervals from 8 - 5.30 but in the wrong date!! {ts '1899-12-30 08:00:00'}
It is not the wrong date. Since you only specified a time (ie "07:30AM") the "date" portion defaults to 0 or 12/30/1899 . If you needed a specific time and date, you must specify it when creating the variables. For example:
<cfset YourDateTime = createDateTime(2012, 6, 25, 7, 30, 0)> ... or
<cfset YourDateTime = parseDateTime("2012-06-25 07:30AM")>
BUT .. in your case it does not
...Copy link to clipboard
Use cfloop condition = "YourDateTime lte #MaxDateTime#"
inside your loop use DateAdd to increment YourDateTime and use TimeFormat to display it.
Like this Dan? Thanks
<cfset YourDateTime = "7:30AM">
<cfset MaxDateTime = "11:30PM">
<cfloop condition = "YourDateTime lte #MaxDateTime#">
#timeFormat(dateAdd('n', 30, YourDateTime),'hh:mm:ss tt')#
</cfloop>
Did it work when you ran it?
When I add the code I get a nasty screen of death, when I take it away the error goes. Error:
IIS 7.5 Detailed Error
HTTP Error 500.0 - Java heap space
The page cannot be displayed because an internal server error has occurred.
That's probably because you have an infinite loop. Also, you are setting your two variables to strings instead of datetime objects. This might cause unexpected results.
Hi Dan, thanks I tried this it is almost working, I get all the times in half hour intervals from 8 - 5.30 but in the wrong date!! {ts '1899-12-30 08:00:00'}
<cfset startweek_dt = TimeFormat(YourDateTime, "hh:mm") >
<cfloop index="ii" from="1" to="20">
<cfset startweek_dt = DateAdd('n',30, startweek_dt)>
<cfoutput>#startweek_dt#</cfoutput><br>
</cfloop>
BUT .. in your case it does not make a difference because you are not using the date for anything. So just use timeFormat() to display the time only.
ie #timeFormat( yourVariableName, 'hh:mm:ss tt')#
That does not change the value of the #YourDateTime# variable. So the loop just runs until it crashes because
the value of #YourDateTime# is always less than 11:30PM. You need to increment the value on each loop and assign the new value to #YourDateTime#.
<cfloop ....>
<cfset YourDateTime = dateAdd('n', 30, YourDateTime)>
</cfloop>
Thanks cfsearching, I don't understand where I use YourDateTime variable if it is inside the cfloop, I tried using the variable in the to and from parts of cfloop but I kept getting errors
<cfloop condition = "YourDateTime lte #MaxDateTime#" >
</cfloop>
Thanks cfsearching, this code works great for outputting the times:
<cfset YourDateTime = "7:00AM">
<cfset startweek_dt = #timeFormat( YourDateTime, 'hh:mm tt')# >
<cfloop index="ii" from="1" to="23">
<cfoutput>#timeFormat( startweek_dt, 'hh:mm tt')#</cfoutput><br>
</cfloop>
This code works great for outputting them in a cfselect:
<option value="<cfoutput>#timeFormat( startweek_dt, 'hh:mm tt')#</cfoutput>"><cfoutput>#timeFormat( startweek_dt, 'hh:mm tt')#</cfoutput></option>
</cfloop>
