Thanks for the info. Knowing what WON’T work is
helpful!
Here’s what I’m trying to do. I’m rewriting
one of my apps, switching out conventional HTML form controls for
<cfform> controls in Flash format. Many of the existing forms
in my app are for updating data contained in a central database.
When such a form is rendered to the screen, each form control is
pre-populated with existing data. All form controls are named
dynamically based upon the unique ID of the record being updated.
Here’s a streamlined but typical example:
<!--- User selected projects 14, 15, 16, and 17 for
update. Get existing project data. --->
<cfquery name="get_project_detail"
datasource="#application.DataSource#">
SELECT project_oid_nbr, project_nm
FROM project_table
WHERE project_oid_nbr IN (14,15,16,17)
ORDER BY project_oid_nbr
</cfquery>
<!--- Initialize the project_nm form control. Form names
are dynamic, based upon get_project_detail.project_oid_nbr. --->
<cfloop query="get_project_detail">
<cfparam name="form.project_nm_#project_oid_nbr#"
default="#get_project_detail.project_nm#">
</cfloop>
<!--- Create HTML form control. --->
<table>
<tr>
<td>
<cfoutput>
Project #project_oid_nbr#:
<input type="text" name="project_nm_#project_oid_nbr#"
value="#Evaluate("form.project_nm_#project_oid_nbr#")#">
</cfoutput>
</td>
</tr>
</cfloop>
</table>
This has been working just fine. However, I’m wondering
if using the Evaluate() function is the most efficient way to go.
Therefore I wanted to use structure notation to avoid the
Evaluate() function, but as mentioned in my original post, this
naming convention won’t work with <cfform> tags.
Any suggestions as to the most efficient way to get the same
result while still using <cfform> tags? Thanks so much!
