Data Management Services with Cairngorm 2.1
Avatar
Level 2
Hello.
I have been using cairngorm 2.0 for a while, and I am now
trying to convert the 2.1 stuff over, including using cairngorm to
manage my DataServices. However I have some questions about it if
you have used it.
Using the command, and passing the command into the delegate,
and then firing the service from the delegate, there is a problem
trying to catch faults. Even though I have a fault method defined
on my command, and I am setting up the responder on the delegate as
the command which called it, the fault handler is not being fired.
I am generating a runtime exception on the java assembler just to
see what happens, and the delegate never fires the fault handler.
However if I remove the runtime excpetion from the java
assembler, and put a simple alert on the result, the delegate sends
to the commands result function, and the alert fires.
If you have any code examples, even if they dont have the
actual assembler behind them, I would really appreciate it. I dont
know if you are supposed to define commands which call DataServices
the same way you would declare a command that calls a RemoteObject.
If so how do you do that? What do you declare on the command to get
it to work?
If you have any ideas, please help.
1 Reply
Avatar
Level 3
Has this question already been answered on flexcoders? I
think the Cairngorm folks may be more plugged in there than here:
www.yahoogroups.com/group/flexcoders/
Seth
