This question was posted in response to the following article: http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7c66.html
I just learned that fileExists() also works with a URL and can validate that a remote resource exists.
fileExists always returns a false for me - even when the file and path are correct. Anyone have any ideas on this one?
@Balddog4: Does the following return YES or NO for you?
writeOutput(fileExists("http://upload.wikimedia.org/wikipedia/commons/thumb/3/30/Googlelogo.png/250px-Googlelogo.png"))
-Aaron
Thanks, Aaron. It returned NOYES
I did some research, and it does look like fileExists had/has a bug with only returning a False/No response. I wasn't sure if it had been fixed or if there was a workaround. I was curious if the original poster had success with this tag.
Really? Where did you read this?
Do you mean "in general" or "when using a URL as an argument"?
Adam
I suspect it's because the user the CF service is running as doesn't have permissions to see the file you are testing.
Or the path actually isn't correct.
What's an example of how you're using using?
NB: it's bad form to ask a different question on someone else's thread. You should start your own thread.
Adam
It could be a permissions issue. I'll look into that.
Back 15 years ago, there were only a handful on the forums. I'm not sure when the new forum etiquettes came to be, but I was not aware that it was not appropriate to respond to a common thread. Actually, at one point, it was encouraged on some forums so as not to have so many redundant and loose threads . I can repost this on a new topic if preferred.
It's always been the case on any forum anywhere. It's the forum equivalent of walking up to someone else's conversation and changing the subject.
It's not a big issue at all, I just meant it as a reminder, but it's always been "etiquette" on any assistance forum I have encountered.
Adam
Thanks for letting me know, Adam. I was oblivous and certainly don't want to add to a forum faux paus.
I see now what it's so important. I need to be able to reply that it was resolved, etc. Thanks for the tip!
It was a permissions issue. Thanks so much, Guys!
